The update looks fine. I think it’s probably just FORScan not reading the data.
So I leave it and don’t mess with it, thanks. Regards
Only not work measurements units option in settings?
Did you perform a master reset after the update?
I have seen this before. It’s the versioning of the APIM vs the BCM, etc. It will likely show correct in the BCM and FORScan.
Hi,
I have a 2017 Focus RS MK3 Europe with Sync3 and Sony.
I dont have the Button APIM Firmware Updater!
How can i get the Button?
Fordscan with License Key and Ford VCMII Dongle.
Partnumber Apim: 5S7T-14G380-CA
Calibration S/W : HB5T-14G375-FA
Best regards from Bavarian Germany
Hello, i need the 1U5T-14G374-EM.vbf file to update my apim to the latest firmware. Can someone share me this file. Thanks in advance.
Greetings from Austria ![]()
What are you describing? Can you show a picture?
See your PM…
hey @f150chief can you send me the file 1U5T-14G374-EM.vbf as well? thanks
The APIM module of the 2023 Ford F550 does not have simplified Chinese when modifying the country and region language, but only traditional Chinese. However, the 2022 Ford F350 APIM module has simplified Chinese language by modifying the AB file. Can I write the 2022 model F350 APIM module firmware into the 2023 model F550 APIM module? In this way, the 2023F550 module will have simplified Chinese.
vehicle: Model: Ford F-350 Engine: 2V Capacity: 7.3L Year: 2022 Generation: 2022 MY Fuel: gasoline Transmission: automatic SYNC version: SYNC 3 APIM - Attachment Protocol Interface Module Part number: MU5T-14G371-BBA Calibration level: MU5T-14G371-BBD (latest known: MU5T-14G371-BBE) Strategy: 1U5T-14G374-EL Calibration: 1U5T-14G375-CA
vehicle:
Model: Ford F-550
Engine: 2V
Capacity: 7.3L
Year: 2023
Generation: 2023 MY
SYNC version: SYNC 4
Part number: PU5T-14G670-HCJ
Calibration level: PU5T-14G670-HCJ
Strategy: NU5T-14G676-BB
Calibration: MU5T-14G677-AA
Hi, i’m a little confused about HW versions VS Firmwares versions.
Here my Forscan -config:
Vehicle:
Model: Ford Focus
Engine: Duratorq Turbo Diesel Common Rail Injection Stage VI
Capacity: 2.0L
Year: 2017
Month: 05
Generation: 2015.25MY
Transmission gear: Manual
Part number: HS7T-14G371-FAE
Calibration level: HS7T-14G371-FAE (latest known: JS7T-14G371-NHG)
Strategy : GB5T-14G374-CB
Calibration: GB5T-14G375-FA
I’ve Updated de software to sync3.4, jailbroked and installed some mods, also enabled some options in Forscan.
As I know, its a very old hardware, so may not work with latest firmwares, I want to update to have Calm Screen and Some other features.
Which is the best combination to fit that HW?
Hello.
I have the APIM shown in the photo on my play desk at home. I would like to upload MY18.5, what files should I upload, can someone send them to me?
I’m looking for the Calibration file 1U5T-14G375-DA.vbf to change calibration of my APIM from EU with NAV (-HA) to NA with NAV (-DA).
Also looking for Illumination Strategy file 5U5T-14G379-BB.vbf, as the current loaded version seems incorrect when looking at the APIM Firmware Production Releases thread.
Would be very thankful if anyone can PM the files or point me to them. I tried the Motorcraft Service site, but all I can get from it are unnamed .asp files that do not appear to be valid .vbf files.
Background:
I’m in the process of installing a SYNC2->SYNC3 upgrade in a 2013 F-150 Platinum. The new APIM installed appears to be a 2020 L series EU NAV unit. It came with SW v3.4.20136 loaded already with EU maps and languages. I successfully updated to 3.4.21265 with NA languages and NA maps 2.20 with SYN3 Updater. I have it installed with the updated screen and new hub and I have been able to connect and query via APIM firmware option in Forscan. Forscan lists:
Part number: LU5T-14G371-GKF
Calibration level: LU5T-14G371-GKH
Hardware Number: GU5T-14G380-FE
Secondly Boot Loader: GB5T-14G376-AA
Strategy (CAN, F188): 1U5T-14G374-EH
Calibration (CAN, F124): 1U5T-14G375-HA
ECU Configuration/Sound Profiles (CAN, F10A): GB5T-14G379-AA
ECU Configuration/Illumination Strategy (CAN, F16B): LK4T-14G379-BC
Image (USB, 8033) 5U5T-14G381-EU
Have spent a lot of time reviewing relevant threads on the forum and understand I need to get the NA calibration loaded for this to work, so I haven’t spent much time coding the options in the APIM yet.
Thanks in advance!
Hi,
I have successfully upgraded the calibration and firmware on the APIM to the versions as per below screenshot.
After the upgrade, I had 3 DTCs in the APIM. See below screenshot.
DTC U2100-00-0B went away after about a week after re-writing AS-Built values to the APIM. However, I can’t get rid of U0232-00-0B and U0233-00-0B. Everything seems to be working fine with BLIS and Side Sensors too and I have the calm screen option now. There are no other DTCs in any other modules. Is there a way to get rid of this or do I just have to ignore these? Please let me know if you need any more information. Any advice is hugely appreciated. Thank you.
Reset the SODM’s thru Forscan. You might have to update the firmware on those.
Hello F150Chief,
Thanks for the advise. I did the reset of SODL and SODR modules and the DTCs in APIM for these didn’t go away.
I then checked for updates for the firmware through Forscan for SODL and SODR modules. There were none available as below.
I then downloaded the same and reloaded them again through Forscan. However, the DTCs in APIM didn’t go away even after reloading the firmware. Please see below.
Let me know if there’s anything else I need to try. Thank you.
