Upgrade 3.3 to 3.4 -> INTSL_ERR11
Hi.
Tried to upgrade as follows:
Config:
Current Sync3 version: 3.3.19205
APIM:EU / Maps:Yes / Inst mode: auto
New version:
Region:EU
Version: I have selected 3 different 3.4.99999 versions
Maps: Keep
I have tried with 2 different usb and get always INSTL_ERR11.
DO you think selecting Inst mode: reformat will solve the problem?
If yes do I have do take into account other parameters?
Can I also select the last 3.4.99999 version or do I need to jump to an earlier 3.4 version first?
PS: car is MY2018
Thanks in advance!
Please check your current version…or is that a typo.
Post the log.txt file from the usb drive.
current version = 3.3.19205
Log file follows:
CYANLABS - SYN3 UPDATER - V1.0.1.1
Operating System: Microsoft Windows 10 Home (1903)
Version: 3.3.19205
Mode: autoinstall
USB DETAILS
Model: Corsair Voyager USB Device (Size: 7,6GB)
; CyanLabs Syn3Updater - Autoinstall Mode - Sync 3.4.20196 EU
Item1 = APPS - 5U5T-14G381-EG_1598634070000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G381-EG_1598634070000.TAR.GZ
Item2 = ENH_DAB - 1U5T-14G658-AF_1598633324000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G658-AF_1598633324000.TAR.GZ
Item3 = VOICE - 5U5T-14G391-AM_1598633466000.TAR.GZ
Open3 = SyncMyRide\5U5T-14G391-AM_1598633466000.TAR.GZ
Item1 = GRACENOTES - 4U5T-14G423-AB_1598633764000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-AB_1598633764000.TAR.GZ
SYNCMYRIDE FILES (4)
5U5T-14G381-EG_1598634070000.TAR.GZ (848,6MB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
5U5T-14G391-AM_1598633466000.TAR.GZ (1,5GB)
4U5T-14G423-AB_1598633764000.TAR.GZ (684,9MB)
INFO: Starting process (Sync 3.4.20196 - EU - Keep Existing Maps)
INFO: Verifying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Successfully Verified 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Verifying 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Successfully Verified 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Verifying 5U5T-14G391-AM_1598633466000.TAR.GZ
INFO: Successfully Verified 5U5T-14G391-AM_1598633466000.TAR.GZ
INFO: Verifying 4U5T-14G423-AB_1598633764000.TAR.GZ
INFO: Successfully Verified 4U5T-14G423-AB_1598633764000.TAR.GZ
INFO: Creating autoinstall autoinstall.lst
INFO: Copying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Copying 1U5T-14G658-AF_1598633324000.TAR.GZ
INFO: Copying 5U5T-14G391-AM_1598633466000.TAR.GZ
INFO: Copying 4U5T-14G423-AB_1598633764000.TAR.GZ
INFO: PROCESS COMPLETE!
Thanks in advance!
I believe you might be on either Sync 3.0.19205 or Sync 3.3.19052. Since you are getting INSTL_ERR11 – Error is APPS_UPDATE_PART_ERROR, it looks like you are trying to upgrade from Sync 3.0 to Sync 3.4, since this would trigger the partition error.
Correct your Sync version and run the Syn3 Updater again.
YOU ARE RIGHT! I am at 3.0.19205
So you think it is ok to recreate the usb with params as follows:
***Config:
Current version Info:
Full Sync Version=3.0.19205
APIM:EU / Navigation:Yes / mode:autoinstall
***New SYnc 3 version:
Region:EU
Version=<latest 3.4 version>
Maps: Keep
OK with the above setup???
Thanks again in advance!
Yes, sorry for the delay…you will need new maps, the old ones are not compatible.
Everything ok!
Congrats to all the cyanlabs guys there!
F150chief thnks for your remarks.
You have done an excellent work!
Do you have working maps? if so it’s fine, if not you likely didn’t install maps, you can’t keep the pre 3.2 maps for 3.2+ so if you were on 3.0 before and didn’t install maps you won’t have any.
