Upgraded my non-nav APIM to Nav APIM
What map version did you download?
The license for the latest maps on this site will not work with your vehicle with autoinstall, as the newest maps are VIN/ESN locked, and you cannot use reformat on a MY20 APIM. The Ford version maps will not work since you have a replacement APIM.
You would have to use reformat mode to install the latest maps, but you have an L series APIM so that is out of the question.
LJ6T-14G532-MCM (lu5t-14g371-ckc)
Run the Interrogator Utility in the Syn3 Updater and post it here.
The newest maps that will work for your APIM are the NA 2.20, which do not have the license restriction.
Tutorial: 2020 North America 2.20 Map Installation (Stand-Alone without Reformat) with Updated NAV_Voice 06/21/2021 - Ford / Guides - CyanLabs Official Community
Okay, I’ll run the utility and try to post it tomorrow evening. I noticed the radio ID is different maybe that’s why traffic doesn’t work quite yet.
To answer your question I downloaded the newest one v2.22.
EDIT: I looked up the OEM info, the SiriusXM UID shown above is original to your vehicle. So it’s the right one. If the SiriusXM UID is different than on your account, it will not work.
You have the most current maps (NA 2.21).
okay, here is the log.
VIN: 1FBAX2Y88MKA98165
Version NU5T-14G381-AB
APIM Model: LU5T-14G371-CKC
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 4.2G
12/30/2022 7:39:43 PM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.9M / 951M
/fs/sd/MAP/ = 8.6M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.7M / 1.4G
/fs/Nuance/ = 15M / 1.6G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 24M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 727M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 90M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 4.2G / 25G
Installed Packages
5U5T-14G391-CS
4U5T-14G421-CAE
4U5T-14G421-CHE
4U5T-14G421-CGE
4U5T-14G421-CJE
4U5T-14G421-CFE
4U5T-14G421-CEE
4U5T-14G421-CDE
4U5T-14G421-CCE
4U5T-14G421-CBE
4U5T-14G422-CCK
4U5T-14G422-CBK
4U5T-14G422-CAK
4U5T-14G423-CC
APIM AsBuilt
DE00: 220A010240022904068A
DE01: 55530104C0024490A8B44405
DE02: 0007000200
DE03: 00000C90080100
DE04: 18061810295F
DE05: 90
DE06: 14003300000000A17500005656780088
