Upgraded to Sync 3 and can't hear phone calls on Bluetooth or Apple carplay
I just recently upgraded from Sync 1 to Sync 3 and every time I get a phone call thru Bluetooth or Apple CarPlay they can hear me on their end but all I hear on my end is my radio playing.
Install Type: OEM Replacement
Old SYNC Version: 2.2.16280
No error messages displayed
Syn3 Updater Version: Not sure
Can look them up when I get home later
Does everything else work ok, nav etc?
If you answer a call you should not be able to hear the radio or at least the volume should reduce.
When someone calls or you call someone try turning up your sync volume whilst they are actually speaking to you as the volume works differently to the radio and usb music etc.
The same applies to nav voice, you need to increase volume to the correct level as the voice directions are being given.
Check your FCIM asbuilt for the following:
7A7-01-01 xxXX xxxx xxxx
In your OEM FCDIM asbuilt, it has ‘00’ entered there.
00=No Remote Display, APIM Not Present, ACCT Fixed, ATWU Not Supported, RAF Not Supported. PWMVBCBT VBC
Change the value to ‘60’
60=Touchscreen Display, APIM Present, ACCT Fixed, ATWU Not Supported, RAF Not Supported. PWMVBCBT VBC
Post your FCIM asbuilt and I’ll take a look at it.
Also, look at the ACM, 727-01-01 Xxxx xxxx xxxx
In your OEM ACM asbuilt, it has ‘D’ entered there.
D=Int SDARS Disabled, APIM Gen1, EFP CAN based, APIM Available
Change the value to ‘9’.
9=Int SDARS Disabled, APIM Gen2, EFP CAN based, APIM Available
