I’ve used those for updates with no issues, I was specifically referring to the USB A/USB C dual port hub.
MY2020 APIMs will brick if you use the CyanLabs update tool to reformat them, the only way to reformat MY2020 APIMs is to follow the FMods path which is not supported here.
