USB Hub err... Android Auto no audio, Developer mode fix.
So, I went from 3.0.20204 all the way current. When the install was complete the screen was green and slightly pixelated, but I have nothing else to report on that glitch. I get the USB hub error others have reported and yes I will need to upgrade the hardware. But, I have 3 Android devices, Samsung Flip 4, Flip 5, and a Motorola G Power 5G. All three of these devices charge normally and connect to Android Auto via USB. When I try to play Spotify there is no audio, still plays the old radio or whatever the source prior selected audio is. I just guessed that by going into the Developer Mode options of any of the Androids , select the “Disable USB audio routing; Disable automatic routing to USB audio peripherals” checkbox. This solves my audio issues as it sends the audio signal via the already connected Bluetooth, every time without having to adjust anything else as this setting will remain unless I change it. I still get the message each time I start, but other than seeing that I notice no issues with the Android setting. I hadn’t seen anyone mention that anywhere so I thought I’d drop this.
Now I can’t 100% swear to the update being the cause of this or perhaps I myself changed something prior to the update install. I saw a message once after the install, something about how the system is capable of voice assist but it’s disabled. I also have a vGate vLinker FS USB for Forscan. I’m sure that I can turn this back on somewhere, using that, I just haven’t had time to mess with that yet. But I honestly don’t remember changing anything through Forscan that would have done that.
Sidenote I love this vLinker. My mother was having instrument cluster issues in a Jeep, this adapter worked on that system too.
Questions on Sync 3.4. So I seem to recall that in the setup of the installer there were 4 voice options that were to be added. 2016 Navigator just has the one old timey telephone operator sounding lady. Did these 4 get installed and do I need to do something to select/load a different one? Another Question, I was hoping maybe this upgrade would somehow start letting me see the individual tire pressure readings via the TPMSs. Still seems odd that this model only has a light on the cluster to signify a low tire, or multiple low, or high, or a bad sensor, or I don’t know something with the wheels is up so go see a dealer message…
Is there a post or list somewhere of parts/modules that could be upgraded to unlock features that 3.4 supports that a 3.0 version didn’t come factory equipped with? I’ve seen the 3g to 4g modem ideas but as my vehicle never had a Lincoln connection like that I’m not sure how I could connect with them.
Sorry if this is the wrong place for this post, the message did say the mods are sometimes generous to new posters.
Last note: Thanks to everyone involved with the Cyanlabs Sync Updater and the community for getting us/me to where we/I am today. I saw this site a long time ago and read about the upgrade possibilities that it offered. I was hesitant as this is a big departure from something I had done before. I’m a chef, good with fire and knives, not typically known as a Ford re-programmer. But, for at least a year I was unable to update the Sync system using the standard Ford/Lincoln methods Wifi or download from Lincoln.com support based on VIN to USB. The last successful update was vis USB as the wifi option was pointless and wouldn’t get past the checking for updates message. You all are Wagyu grade Awesome in my book!
Old SYNC Version: 3.0.20204
USB Hub not supported - Please Remove
Version: 3.0.20204
Model: PNY USB 3.2.1 FD USB Device
; CyanLabs Syn3Updater 2.13.0.0 Stable - reformat  Mode - Sync 3.4.23188 NA
FILES (19)
GB5T-14G386-AA_56065.tar.gz (43.1KB)
Sync_WV1W02G4_5LMJJ2HT6GEL08923.xml (10.2KB)
[12/18/2024 10:57:08 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.23 (2023) - NA
[12/18/2024 10:57:08 AM] Install Mode: Auto-Detect (reformat) Forced: False
[12/18/2024 10:57:08 AM] MY20 Protection: Disabled / Not MY20
[12/18/2024 10:57:08 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12/18/2024 10:57:08 AM] Downloading: 1u5t-14g386-cb.tar.gz
[12/18/2024 10:57:11 AM] Validating: 1u5t-14g386-cb.tar.gz
[12/18/2024 10:57:11 AM] Downloaded: 1u5t-14g386-cb.tar.gz
[12/18/2024 10:57:11 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 10:57:11 AM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 10:57:11 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 10:57:11 AM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 10:57:11 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 10:57:11 AM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 10:58:24 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 10:58:25 AM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 10:58:25 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 10:58:25 AM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:00:27 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:00:28 AM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:00:28 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:00:28 AM] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:03:30 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:03:32 AM] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:03:32 AM] Checking Existing File: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:03:32 AM] Downloading: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:05:24 AM] Validating: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:05:25 AM] Downloaded: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:05:25 AM] Checking Existing File: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:05:25 AM] Downloading: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:08:17 AM] Validating: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:08:19 AM] Downloaded: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:08:19 AM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 11:08:19 AM] Downloading: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 11:12:53 AM] Validating: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 11:12:56 AM] Downloaded: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 11:12:56 AM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 11:12:56 AM] Downloading: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 11:15:30 AM] Validating: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 11:15:32 AM] Downloaded: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 11:15:32 AM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 11:15:32 AM] Downloading: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 11:19:24 AM] Validating: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 11:19:27 AM] Downloaded: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 11:19:27 AM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 11:19:27 AM] Downloading: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 11:23:39 AM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 11:23:42 AM] Downloaded: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 11:23:42 AM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 11:23:42 AM] Downloading: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 11:28:05 AM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 11:28:09 AM] Downloaded: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 11:28:09 AM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 11:28:09 AM] Downloading: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 11:32:33 AM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 11:32:37 AM] Downloaded: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 11:32:37 AM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 11:32:37 AM] Downloading: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 11:38:00 AM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 11:38:03 AM] Downloaded: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 11:38:03 AM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 11:38:03 AM] Downloading: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 11:42:32 AM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 11:42:35 AM] Downloaded: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 11:42:35 AM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 11:42:35 AM] Downloading: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 11:46:59 AM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 11:47:02 AM] Downloaded: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 11:47:02 AM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 11:47:02 AM] Downloading: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 11:50:41 AM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 11:50:44 AM] Downloaded: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 11:50:44 AM] Preparing USB drive
[12/18/2024 11:50:44 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[12/18/2024 11:50:44 AM] Copying: 1u5t-14g386-cb.tar.gz
[12/18/2024 11:50:44 AM] Validating: 1u5t-14g386-cb.tar.gz
[12/18/2024 11:50:45 AM] Copied: 1u5t-14g386-cb.tar.gz
[12/18/2024 11:50:45 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 11:50:45 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 11:50:45 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 11:50:45 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[12/18/2024 11:50:45 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 11:50:45 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 11:51:15 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 11:51:24 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[12/18/2024 11:51:24 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:51:24 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:52:36 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:52:49 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[12/18/2024 11:52:49 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:52:49 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:54:45 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:55:05 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[12/18/2024 11:55:05 AM] Checking Existing File: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:55:05 AM] Copying: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:56:14 AM] Validating: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:56:27 AM] Copied: 4U5T-14G422-CCN_1709611788000.TAR.GZ
[12/18/2024 11:56:27 AM] Checking Existing File: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:56:27 AM] Copying: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:58:08 AM] Validating: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:58:26 AM] Copied: 4U5T-14G422-CBN_1709611416000.TAR.GZ
[12/18/2024 11:58:26 AM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 11:58:26 AM] Copying: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 12:01:12 PM] Validating: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 12:01:44 PM] Copied: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[12/18/2024 12:01:44 PM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 12:01:44 PM] Copying: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 12:03:21 PM] Validating: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 12:03:36 PM] Copied: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[12/18/2024 12:03:36 PM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 12:03:36 PM] Copying: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 12:05:49 PM] Validating: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 12:06:03 PM] Copied: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[12/18/2024 12:06:03 PM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 12:06:03 PM] Copying: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 12:08:43 PM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 12:09:15 PM] Copied: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[12/18/2024 12:09:15 PM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 12:09:15 PM] Copying: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 12:11:45 PM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 12:11:51 PM] Copied: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[12/18/2024 12:11:51 PM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 12:11:51 PM] Copying: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 12:14:26 PM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 12:14:29 PM] Copied: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[12/18/2024 12:14:29 PM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 12:14:29 PM] Copying: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 12:17:32 PM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 12:17:36 PM] Copied: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[12/18/2024 12:17:36 PM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 12:17:36 PM] Copying: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 12:20:17 PM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 12:20:48 PM] Copied: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[12/18/2024 12:20:48 PM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 12:20:48 PM] Copying: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 12:23:22 PM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 12:23:25 PM] Copied: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[12/18/2024 12:23:25 PM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 12:23:25 PM] Copying: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 12:25:41 PM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 12:26:03 PM] Copied: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[12/18/2024 12:26:03 PM] Generating reformat.lst
[12/18/2024 12:26:03 PM] Generating autoinstall.lst
[12/18/2024 12:26:03 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
  1. The USB hub issue will go away when you replace the media hub, the pre-2017 hubs are not fully compatible with 3.4
  2. You won’t get TPMS on the APIM just by going to 3.4.x, it comes down to what the other hardware in the car supports. As an example in my 2018 Fusion Platinum, I can enable the remote start screens but none of the options function except for the enable/disable.
  3. Factory NAV voice hasn’t changed, the updated voice files are things like new commands (eg with NAV “go home” or “take me home”) and updated street names.
  4. Voices from AA come from AA, not from Sync.
  5. As you’re now on an unsupported version of Sync 3.4 (from Ford’s point of view) you’ll never be offered a 3.4.x upgrade, the owners site will only show the last supported version for your vehicle.
