USB Hub help
So i have a 2016 ford fusion se with what originally was the sync 2 sound system. i have upgraded the radio to a sync 3 radio from a 2018 ford fusion s and reprogrammed using forscan. here recently i got a sync 3 usb hub Part Number “GC3T-14F014-BB”. so i took the old usb hub out and noticed that it has the same plugs as my new usb hub. so i plugged it in and it just says that usb hubs are not supported. please remove. i dont know what is wrong.
Install Type: OEM Replacement
Old SYNC Version: 3.4
USB hubs are not supported. please remove.
The old hub is not supported for CarPlay and you will need to replace it.
HC3Z-19A387-B thru F (Wide 2 USB-A Port)
2015-2016 Ford F-150 (Converted to Sync 3)
i ordered a new hub that is a sync 3 hub. and it has the same plugs as my old hub but i’m still getting the usb hub error messege. could it be the mini usb cable?
Part number?
usb 3 hub part number GC3T-14F014-BB
That is an older hub not compatible for CP.. It will work with AA but you will get the error every time you start the vehicle.
oh ok i see. which usb hub do you recommend
