Want to go from 3.0 > 3.4 but worried about unknown APIM
Hello, I bought a 2018 Ford Escape this year that was previously in a front end wreck and thus has a salvage title. So I am unsure of the year the APIM was manufactured. Following the guide on the SYNC 3 program, I created a USB to grab my cars Interrogator file. However, many of the important details around the APIM showed up as “blank”. So im hoping I could get some help here on my next suggested step. I don’t want to go through the update process and find out the hard way I have a newer APIM. I’ve attached the Interrogator file, many thanks!!
Install Type: Unknown
Old SYNC Version: 3.0.20204
New SYNC Version: 3.0.20204
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-11-14" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>  XXXXXXXXXXXXXXXX   </p:VIN>
<p:RequestRole>
</p:RequestRole>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AX</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473432312d4343000000000000000000004a5233542d3134473339312d4345000000000000000000004a5233542d3134473432322d4344000000000000000000004a5233542d3134473432332d434200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>WX886Z8K</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>fc:69:47:34:12:ef</d2p1:Response>
</d2p1:DID>
<d2p1:Response>fc:69:47:34:12:f0</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2022-11-14T22:20:09+00:00" RAM="1045258240" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="29G" available="29G"/>
<d2p1:PartitionHealth type="/fs/tmpfs/" total="128M" available="126M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.4G" available="177M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="11G" available="83M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="5.7G" available="295M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="482M" available="2.5M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="5.1M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1024M" available="620M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1024M" available="40M"/>
<d2p1:PartitionHealth type="/fs/images/" total="26G" available="4.9G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
If you used the -AD file, try the -AC or -AB file.
The installed files are:
JR3T-14G381-AX
JR3T-14G421-CC
JR3T-14G391-CE
JR3T-14G422-CD
JR3T-14G423-CB
This is Sync 3.0.20204 with NA.1.17 (28.01.2018) maps. This is likely an H-series APIM. Run the Interrogator with the -AB or -AC file.
-AB file
-<p:OTAModuleSnapShot xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd" version="2022-11-14" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0">
<p:VIN> XXXXXXXX </p:VIN>
-<p:RequestRole>
</p:RequestRole>
-<p:Node specificationCategory="GGDS" isFlashed="false">
-<d2p1:ECUAcronym name="APIM">
-<d2p1:State>
-<d2p1:Gateway gatewayType="NONE">
-<d2p1:DID responseLength="24" didValue="8033" didType="Embedded Consumer Operating System Part Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="384" didValue="8060" didType="Embedded Consumer Applications Part Numbers 1" didFormat="Packeted">
</d2p1:DID>
-<d2p1:DID responseLength="384" didValue="8061" didType="Embedded Consumer Applications Part Numbers 1" didFormat="Packeted">
</d2p1:DID>
-<d2p1:DID responseLength="4" didValue="D704" didType="ECU Checksum 1" didFormat="HEX">
</d2p1:DID>
-<d2p1:DID responseLength="4" didValue="D705" didType="ECU Checksum 2" didFormat="HEX">
</d2p1:DID>
-<d2p1:DID didValue="DE00" didType="Direct Configuraation DID DE00">
</d2p1:DID>
-<d2p1:DID didValue="DE01" didType="Direct Configuraation DID DE01">
</d2p1:DID>
-<d2p1:DID didValue="DE02" didType="Direct Configuraation DID DE02">
</d2p1:DID>
-<d2p1:DID didValue="DE03" didType="Direct Configuraation DID DE03">
</d2p1:DID>
-<d2p1:DID didValue="DE04" didType="Direct Configuraation DID DE04">
</d2p1:DID>
-<d2p1:DID didValue="DE05" didType="Direct Configuraation DID DE05">
</d2p1:DID>
-<d2p1:DID didValue="DE06" didType="Direct Configuraation DID DE06">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F110" didType="On-line Diagnostic Database Reference Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F111" didType="ECU Core Assembly Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F113" didType="ECU Delivery Assembly Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F124" didType="ECU Calibration Data #1 Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="16" didValue="F141" didType="Private Sub Node #1 Serial Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="1" didValue="F162" didType="Software Download Specification Version" didFormat="State Encoded">
</d2p1:DID>
-<d2p1:DID responseLength="1" didValue="F163" didType="Diagnostic Specification Version" didFormat="State Encoded">
</d2p1:DID>
-<d2p1:DID responseLength="24" didValue="F188" didType="Vehicle Manufacturer ECU Software Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="16" didValue="F18C" didType="ECU Serial Number" didFormat="ASCII">
</d2p1:DID>
-<d2p1:DID responseLength="6" didValue="F1D0" didType="ECU MAC Address 1" didFormat="HEX">
</d2p1:DID>
-<d2p1:DID responseLength="6" didValue="F1D1" didType="ECU MAC Address 2" didFormat="HEX">
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:ODLNetwork d2p1:Pins="6,14" d2p1:DLCName="SAE J1962" d2p1:NetworkProtocol="CAN" d2p1:NetworkName="HS-CAN" d2p1:NetworkDataRate="500"/>
-<d2p1:AdditionalAttributes vmcuVersion="Vector_VMCU_02.02.20" RAM="1061908480" logGeneratedDateTime="2022-11-14T23:24:19+00:00">
<d2p1:PartitionHealth available="29G" total="29G" type="/fs/usb0/"/>
<d2p1:PartitionHealth available="126M" total="128M" type="/fs/tmpfs/"/>
<d2p1:PartitionHealth available="177M" total="1.4G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="83M" total="11G" type="/fs/sd/MAP/"/>
<d2p1:PartitionHealth available="295M" total="5.7G" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="2.5M" total="482M" type="/fs/Nuance/"/>
<d2p1:PartitionHealth available="5.1M" total="1.0G" type="/fs/Nuance/grace"/>
<d2p1:PartitionHealth available="617M" total="1024M" type="/fs/rwdata/"/>
<d2p1:PartitionHealth available="40M" total="1024M" type="/fs/mp/"/>
<d2p1:PartitionHealth available="4.9G" total="26G" type="/fs/images/"/>
<d2p1:SyncData>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</d2p1:SyncData>
</p:Node>
-AC file
<p:VIN> XXXXXXX </p:VIN>
-<p:RequestRole>
</p:RequestRole>
-<d2p1:State>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
-<d2p1:AdditionalAttributes vmcuVersion="Vector_VMCU_02.02.20" RAM="1061842944" logGeneratedDateTime="2022-11-14T23:36:07+00:00">
<d2p1:PartitionHealth available="614M" total="1024M" type="/fs/rwdata/"/>
<d2p1:SyncData>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</d2p1:SyncData>
</p:Node>
Tere is an issue with the APIM not populating the data. Try a master reset of the APIM and try the -AB fileagain, if you want. Otherwise, to verify the APIM, you will need to read the label on the unit or query the APIM with a tool such as FORScan or other OBD reader that can do so.
How difficult is it to gain access to the physical APIM? As the master reset didn’t bring about any new info from running the interrogator again.
It’s behind the screen. Probably not that difficult…
2018 escape remove apim - Google Search
I bought an OBD reader and have accessed my APIM data, I’m just ensuring this data is NOT MY20. Please let me know, thanks!
Bus: HSCAN
Part number: JR3T-14G371-CGA
Calibration level: JR3T-14G371-CJG
Strategy : HB5T-14G374-CA
Calibration: HB5T-14G375-CA
DSP - (Audio) Digital Signal Processing Module
Bus: MSCAN
Part number: GJ5T-18B849-AG
Calibration level: GJ5T-18B849-AG
Strategy : GJ5T-14C589-AG
ACM - Audio Control Module
Bus: MSCAN
Part number: GJ5T-19C107-GE
Calibration level: GJ5T-19C107-GE
Strategy : GJ5T-14D099-GE
IPC - Instrument Panel Control Module
Bus: MSCAN
Part number: JJ5T-10849-TC
Calibration level: JJ5T-10849-TC
Strategy : JJ5T-14C026-BB
Calibration: JJ5T-14C088-CA
Unsure, other JR3T parts are but others are not…
I would not risk it.
Unmount the unit and check the stickers.
Be careful with this one, it is listed as an OEM Service Replacement item. Look for a sticker like this on the module. If it has a 2020 or later date do not reformat the unit.
Thanks for the information guys, I think I will just stick to 3.0.20204 then. However, is it possible for me to update my maps (as I have NAV) to something newer than NA 1.17 without risking if I have a MY20 APIM?
Hey @F150Chief , what do you think?. :point_up: :point_up: :point_up:
Do you think any similar approach to Tutorial: Sync 3.0.20204 with 2022 EU 2.21 (F11) Map Installation could be applied for NA and/or ANZ?.
Thanks.
Yes it can, but the files are not as large so it would not be necessary really.
