Will reformatting delete the map? Even if I choose to keep the map
Will reformatting delete the map? Even if I choose to keep the map. I installed 23188 with reformatting, but chose to keep the map without updating the map. After the update, the map reported an error “Navigation is not Functioning properly”. Can I reformat and install the version with the map to fix this problem? Also, can the universal reformat mod remove the restriction that 23188 cannot reformat? Can I reformat directly without downgrading first?
SYNC Region: CN
Install Type: OEM Replacement
Old SYNC Version: 3.4.23188
Syn3 Updater Version: 2.3
Operating System: Microsoft Windows 10 专业工作站版 (2009)
Version: 3.4.23188
Region: CN
Install Mode Overridden: True
My20 Protection Enabled: 禁用 / 不是20年款
Model: Generic MassStorageClass USB Device
FileSystem: exFATFAT
VOICE=5U5T-14G391-ES_1660786984000.TAR.GZ
GRACENOTES=4U5T-14G423-EC_1615430008000.TAR.GZ
; CyanLabs Syn3Updater 2.13.3.0 Stable - reformat FORCED  Mode - Sync 3.4.23188 CN
FILES (5)
5U5T-14G391-ES_1660786984000.TAR.GZ (188.8MB)
4U5T-14G423-EC_1615430008000.TAR.GZ (381.8MB)
[2025/4/27 19:31:02] Selected Region: CN - Release: Sync 3.4.23188 - Map Version: 保持已有的地图
[2025/4/27 19:31:02] Install Mode: reformat (reformat) Forced: True
[2025/4/27 19:31:02] MY20 Protection: 禁用 / 不是20年款
[2025/4/27 19:31:02] Formatting USB drive
[2025/4/27 19:31:02] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2025/4/27 19:31:10] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025/4/27 19:31:10] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2025/4/27 19:31:10] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025/4/27 19:31:10] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2025/4/27 19:31:10] Checking Existing File: 5U5T-14G391-ES_1660786984000.TAR.GZ
[2025/4/27 19:31:10] Validated: 5U5T-14G391-ES_1660786984000.TAR.GZ (Skipping Download)
[2025/4/27 19:31:10] Checking Existing File: 4U5T-14G423-EC_1615430008000.TAR.GZ
[2025/4/27 19:31:11] Validated: 4U5T-14G423-EC_1615430008000.TAR.GZ (Skipping Download)
[2025/4/27 19:31:11] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025/4/27 19:31:13] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2025/4/27 19:31:13] Preparing USB drive
[2025/4/27 19:31:13] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025/4/27 19:31:13] Copying: 1u5t-14g386-cb.tar.gz
[2025/4/27 19:31:14] Validating: 1u5t-14g386-cb.tar.gz
[2025/4/27 19:31:14] Copied: 1u5t-14g386-cb.tar.gz
[2025/4/27 19:31:14] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025/4/27 19:31:14] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025/4/27 19:31:14] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025/4/27 19:31:14] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025/4/27 19:31:14] Checking Existing File: 5U5T-14G391-ES_1660786984000.TAR.GZ
[2025/4/27 19:31:14] Copying: 5U5T-14G391-ES_1660786984000.TAR.GZ
[2025/4/27 19:31:32] Validating: 5U5T-14G391-ES_1660786984000.TAR.GZ
[2025/4/27 19:31:32] Copied: 5U5T-14G391-ES_1660786984000.TAR.GZ
[2025/4/27 19:31:32] Checking Existing File: 4U5T-14G423-EC_1615430008000.TAR.GZ
[2025/4/27 19:31:32] Copying: 4U5T-14G423-EC_1615430008000.TAR.GZ
[2025/4/27 19:32:08] Validating: 4U5T-14G423-EC_1615430008000.TAR.GZ
[2025/4/27 19:32:09] Copied: 4U5T-14G423-EC_1615430008000.TAR.GZ
[2025/4/27 19:32:09] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025/4/27 19:32:09] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025/4/27 19:33:31] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025/4/27 19:33:33] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025/4/27 19:33:33] Generating reformat.lst
[2025/4/27 19:33:33] Generating autoinstall.lst
[2025/4/27 19:33:33] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
reformat clears all data on the unit.
Thank you. I have two more questions.
  1. Can Universal SYNC 3 Reformat (SyncRenovation) break the limitation that Sync 3.4.19274 and above versions cannot use reformatting?
    If I use it first, can I use reformatting to install in any version?
  2. My current situation is equivalent to not installing the map, so if I only install the map, will it take a long time, about an hour? Will it be faster to reformat and install everything? How long will it take?
Thank you very much again.
The reformat tool is blacklisted above that version, so you need to downgrade below that version to use the tool. That is what the Syn3 Updater does when left in automatic mode.
Leave the SYN3 Updater in AUTOMATIC mode. Select the version you want to install, like 3.4.23188, then select the maps to install. The Syn3 Updater will switch to downgrade, and will install Sync 3.3.19052 to use the reformat tool, and will then reformat and update to the selected Sync version and maps.
This is all explained in the instructions.
Can’t this mod skip the restrictions on reinitialization for this version?
Because I tried to use this mod first
Then install the 23188 system in reformatting mode
I successfully installed it and it seems that there is no downgrade
My question is Universal SYNC 3 Reformat (SyncRenovation)
This mod seems to be able to remove the blacklist of reformatting in this version
can use reformatting in the new version without downgrading
Is my understanding correct?
You should ask that at FMODS, but my understanding is that the blacklisting is intact, as the reformatter does not modify the Sync application.
Okay, thank you anyway.
