XML-file autodetect MY2020 error
I would like to upgrade to version 3.4.23188, after i upload the XML file i am getting:
“XML file doesn’t hava a correct 'ECU Delivery Assambly Number"so therfore cync3update can not check if this is a MY20+ APIM or not”
Date of vehicle registration in the Netherlands = December 2022
Date of first registration in the Netherlands = July 20244.
I am the fist owner.
Install Type: Unknown
Old SYNC Version: 3.4.21194
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2024-08-03" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
  <p:VIN></p:VIN>
  <p:RequestRole>
  </p:RequestRole>
  <p:BroadcastDTCType/>
    <d2p1:ECUAcronym name="APIM">
      <d2p1:State>
            <d2p1:Response>5U5T-14G381-ET</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424648000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424848000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414700000000000000000000345535542d3134473432322d424146000000000000000000345535542d3134473432322d424246000000000000000000345535542d3134473432322d424346000000000000000000345535542d3134473432322d424446000000000000000000345535542d3134473432332d414300000000000000000000355535542d3134473339312d415200000000000000000000</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>N14M00BY</d2p1:Response>
          </d2p1:DID>
          </d2p1:DID>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>
</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>94:a9:a8:52:50:bf</d2p1:Response>
          </d2p1:DID>
            <d2p1:Response>94:a9:a8:52:50:c0</d2p1:Response>
          </d2p1:DID>
        </d2p1:Gateway>
      </d2p1:State>
    </d2p1:ECUAcronym>
    <d2p1:AdditionalAttributes logGeneratedDateTime="2024-08-03T09:51:21+00:00" RAM="1031155712" vmcuVersion="Vector_VMCU_02.02.20">
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.1G" available="892K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.8G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.3G" available="14M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="7.9M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="2.2G" available="17M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.7G" available="21M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="38M" available="396K"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.2G" available="5.7M"/>
      <d2p1:PartitionHealth type="/fs/sd/MAP/" total="3.1G" available="24M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="27M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.9G" available="29M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="4.3G" available="25M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/" total="3.6G" available="35M"/>
      <d2p1:PartitionHealth type="/fs/Nuance/grace" total="1003M" available="21M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/" total="1.2G" available="980M"/>
      <d2p1:PartitionHealth type="/fs/rwdata/quip/" total="90M" available="89M"/>
      <d2p1:PartitionHealth type="/fs/mp/" total="1.4G" available="132M"/>
      <d2p1:PartitionHealth type="/fs/mp/resources" total="71M" available="476K"/>
      <d2p1:PartitionHealth type="/fs/images/" total="54G" available="11G"/>
      <d2p1:InstallationLog/>
      <d2p1:SyncData>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</d2p1:SyncData>
    </d2p1:AdditionalAttributes>
  </p:Node>
</p:OTAModuleSnapShot>
Your car is from 2022 as per your profile, so it’s MY20…
So what to do?
Can i ignore the my20 message and download the update to the usb stick?
What do you think?. Are you really asking if ignoring a MY20 warning about bricking a MY20 unit is a good idea having a MY20 model?.
Sorry, im new to this…
So i cant update my car?
Thanks for your help sandman :slight_smile:
Then you should read our detailed documentation about the process before bricking your unit → Basic Usage - CyanLabs
As long as you keep MY20 protection active at all times and do not reformat the unit, you can use the tool.
There is no need to update your car with Cyanlabs. Ford already offers you the most recent updates.
My version is 3.4.21194.
And map f10.
When i go to the systemsoftware and check for updates…it says that im on the latest version.
Where are you actually getting this info from…your profile on the official Ford site?
Sorry, cannot answer why it says that when there are several later updates.
Suggest you check out the link below from the beginning.
