XML file does not contain the expected output
I am trying to see if my APIM is MY20.
2017 Ford Focus RS
When using the interrogator it says that the xml file doesnt contain the expected output.
Current Sync Model: 2.2.16280
Region: ANZ
Nav: Yes
uploaded all i could find, if need more info lmk!
SYNC Region: ANZ
Install Type: Unknown
Old SYNC Version: 2.2.16280
New SYNC Version: 2.2.16280
Xml files does not contain the expected output
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2018-03-03" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF05XXGCC5HP12306</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>HN1T-14G381-LG</d2p1:Response>
</d2p1:DID>
<d2p1:Response>484235542d3134473432342d444144000000000000000000484235542d3134473432322d444300000000000000000000484e31542d3134473432332d444100000000000000000000484235542d3134473432312d444144000000000000000000484e31542d3134473339312d444500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>b7b7eb26</d2p1:Response>
</d2p1:DID>
<d2p1:Response>335bc39f</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0b6865da9002bc150002</d2p1:Response>
</d2p1:DID>
<d2p1:Response>41530c064002080000800005</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010200</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01001a01020001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>17ca179828be</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>0e033300000000135600000430670069</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HS7T-14G380-BA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HS7T-14G371-DAE</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-DA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>NW3900VD</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-CB</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>60:64:05:23:0c:b9</d2p1:Response>
</d2p1:DID>
<d2p1:Response>60:64:05:23:0c:ba</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2018-03-03T12:24:19+00:00" RAM="1062981632" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/dev/hd0t180" total="16797682688" available="54710240"/>
<d2p1:PartitionHealth type="/dev/hd0t181" total="795034624" available="2097120"/>
<d2p1:PartitionHealth type="/dev/hd0t177" total="136776704" available="2097152"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
As per our DB, that’s not MY20.
You should be fine, but there are only 2 references in our DB and I’ve only found that model in your thread.
