2015 sync 2 to sync 3 upgrade issues
i upgraded the apim to a sync 3 from a 2017. i have a 2015 lariat with the sony system. while it does function some things do not to incude EQ, no volume indicator, sub doesnt seem to be active and the zoom function for the backup camera doesnt work. any help would be appreciated. i will try to attach a pic of the APIM AB
Old SYNC Version: 2.2
no
We can help you thru the APIM asbuilt.
Where did you get the asbuilt? Did it come with the APIM?
Also, your truck is a Lariat, does it have automatic AC or manual? You have the Sony system, any heated or cooled seats?
it came with the APIM. that was a screen shot while i was connected. i do have auto AC with heated and cooled seats
I’ll get back to you…
i appreciate it
HD Radio?
NAV? The asbuilt shows none.
Multi-Contour Seats?
hd radio yes
no nav
no multi contour seats
51/2 ft bed?
yes
OK, based on a 2017 Lariat with the like options and what you described, this should be really close.
41844_7D0_APIM - (SYNC).abt (349 Bytes)
So, what you’ll do is to open FORScan to the APIM asbuilt page in you pic. At the bottom there is a button called “Load ALL”. Select that and select the attached file. Say OK.
FORScan should indicate it loaded the data. Then select “Write ALL”
The unit will reboot and come back up. See how it runs…
ill give it a shot right now. thanks for the help
Read above,
that worked awesome! thank you. only thing that still isnt working is the reverse camera zoom
i gave that a shot but no luck
Did you try the update to 20282 first? Or in this case downgrade…then see if the zoom works. If it does, then upgrade back to 23188.
