2016 F150 updating from sync 3.0 to 3.4 error
attempted to update to latest version 3.4. Took 30 min then said update complete. When I checked my version after the update and it was still the old version. I uploaded the XML file on my computer and it showed this error: The XML file you have selected does not contain the expected output. Syn3 updater has determined you are on 3.0.23219 and may be using overlays. Syn3 Updatere is unable to determine the configuration of your APIM
Old SYNC Version: 3.0.23219
New SYNC Version: 3.0.23219
Syn3 Updater Version: I downloaded it today and it said it was the newest stable version
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2006-02-12" xsi:schemaLocation="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0 ModuleSnapshot.xsd">
<p:VIN>1FTEW1EP4GKD47832</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
<d2p1:DTC DTCValue="908e1208"/>
<d2p1:DTC DTCValue="f000040b"/>
</p:BroadcastDTCType>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AY</d2p1:Response>
</d2p1:DID>
<d2p1:Response>474235542d3134473432322d434a00000000000000000000474235542d3134473432312d434a00000000000000000000474235542d3134473432342d4348000000000000000000004a5233542d3134473339312d4345000000000000000000004a5233542d3134473432332d434200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>41468b97</d2p1:Response>
</d2p1:DID>
<d2p1:Response>d80ac876</d2p1:Response>
</d2p1:DID>
<d2p1:Response>2a2a04060002a906048a</d2p1:Response>
</d2p1:DID>
<d2p1:Response>43410103c402028000000000</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000010300</d2p1:Response>
</d2p1:DID>
<d2p1:Response>01000001000001</d2p1:Response>
</d2p1:DID>
<d2p1:Response>1a681a6838a4</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>45003300000000029a000056569200c8</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-GB5T-14G371-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G380-BC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GJ5T-14G371-CFC</d2p1:Response>
</d2p1:DID>
<d2p1:Response>GB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>VV1340A8</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>GB5T-14G374-AF</d2p1:Response>
</d2p1:DID>
<d2p1:Response/>
</d2p1:DID>
<d2p1:Response>ec:11:27:eb:d8:2b</d2p1:Response>
</d2p1:DID>
<d2p1:Response>ec:11:27:eb:d8:2c</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2006-02-12T16:57:28+00:00" RAM="1234567" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="58G" available="58G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
That APIM is not MY20 and can be reformatted. Just make sure Android Auto and Car Play works before moving forward, since your car is from 2016 you may need to change the usb hub → Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3
I did replace my usb hub with an OEM CarPlay compatible one ahead of doing the update. How do I re-format the APIM
Good, one thing less to worry about then.
I recommend reading the documentation / instructions → Basic Usage - CyanLabs
Remember, based on the log you sent before, your APIM is not MY20.
Do I need to do a factory reset then update to 3.4 again
If it only took 30 minutes it may not have finished the update especially since maps were involved.
Is it possible you removed the flash drive when the message first indicated to do so?
If so, as per Cyanlabs instructions you need to leave it plugged in regardless of this message and allow the system to reboot and complete the upload before removing the stick when advised the second time.
Suggest you try the upload again and do a factory reset at the end.
Ok thank you I will try that again in the morning.
I am going to re-try again. I chose a earlier map version and this time it took quite a bit longer to create to create the USB files. I will let you know how it works out. Here is the log file:
Version: 3.0.23219
Model: Lexar USB Flash Drive USB Device
MAP=4U5T-14G421-CJD_1615428865000.TAR.GZ
MAP=4U5T-14G421-CHD_1615428793000.TAR.GZ
MAP=4U5T-14G421-CGD_1615428721000.TAR.GZ
MAP=4U5T-14G421-CFD_1615428639000.TAR.GZ
MAP=4U5T-14G421-CED_1615428554000.TAR.GZ
MAP=4U5T-14G421-CDD_1615428467000.TAR.GZ
MAP=4U5T-14G421-CCD_1615428361000.TAR.GZ
MAP=4U5T-14G421-CBD_1615428261000.TAR.GZ
MAP=4U5T-14G421-CAD_1615428059000.TAR.GZ
MAP_LICENSE=4U5T-14G424-CD_1616778089000.TAR.GZ
VOICE_NAV=4U5T-14G422-CAJ_1626961442000.TAR.GZ
VOICE_NAV=4U5T-14G422-CBJ_1626962550000.TAR.GZ
VOICE_NAV=4U5T-14G422-CCJ_1626963400000.TAR.GZ
FILES (18)
4U5T-14G421-CJD_1615428865000.TAR.GZ (657.9MB)
4U5T-14G421-CHD_1615428793000.TAR.GZ (989.6MB)
4U5T-14G421-CGD_1615428721000.TAR.GZ (1.1GB)
4U5T-14G421-CFD_1615428639000.TAR.GZ (1GB)
4U5T-14G421-CED_1615428554000.TAR.GZ (1GB)
4U5T-14G421-CDD_1615428467000.TAR.GZ (1.2GB)
4U5T-14G421-CCD_1615428361000.TAR.GZ (1GB)
4U5T-14G421-CBD_1615428261000.TAR.GZ (1.1GB)
4U5T-14G421-CAD_1615428059000.TAR.GZ (1.1GB)
4U5T-14G424-CD_1616778089000.TAR.GZ (1.7KB)
4U5T-14G422-CAJ_1626961442000.TAR.GZ (1.3GB)
4U5T-14G422-CBJ_1626962550000.TAR.GZ (772.4MB)
4U5T-14G422-CCJ_1626963400000.TAR.GZ (549.6MB)
[2025-09-29 8:54:48 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.20 (2020) - NA
[2025-09-29 8:54:48 AM] Install Mode: Auto-Detect (reformat) Forced: False
[2025-09-29 8:54:48 AM] MY20 Protection: Disabled / Not MY20
[2025-09-29 8:54:48 AM] Formatting USB drive
[2025-09-29 8:54:48 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2025-09-29 8:54:56 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025-09-29 8:54:56 AM] Downloading: 1u5t-14g386-cb.tar.gz
[2025-09-29 8:54:58 AM] Validating: 1u5t-14g386-cb.tar.gz
[2025-09-29 8:54:58 AM] Downloaded: 1u5t-14g386-cb.tar.gz
[2025-09-29 8:54:58 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 8:54:58 AM] Downloading: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 8:54:58 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 8:54:58 AM] Downloaded: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 8:54:58 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 8:54:58 AM] Downloading: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 8:55:15 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 8:55:16 AM] Downloaded: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 8:55:16 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 8:55:16 AM] Downloading: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 8:55:33 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 8:55:34 AM] Downloaded: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 8:55:34 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 8:55:34 AM] Downloading: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 8:55:58 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 8:56:00 AM] Downloaded: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 8:56:00 AM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 8:56:00 AM] Downloading: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 8:56:25 AM] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 8:56:26 AM] Downloaded: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 8:56:26 AM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 8:56:26 AM] Downloading: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 8:57:13 AM] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 8:57:17 AM] Downloaded: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 8:57:17 AM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 8:57:17 AM] Downloading: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 8:58:05 AM] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 8:58:09 AM] Downloaded: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 8:58:09 AM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 8:58:09 AM] Downloading: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 8:58:37 AM] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 8:58:41 AM] Downloaded: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 8:58:41 AM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 8:58:41 AM] Downloading: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 8:59:12 AM] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 8:59:15 AM] Downloaded: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 8:59:15 AM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 8:59:15 AM] Downloading: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 8:59:52 AM] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 8:59:57 AM] Downloaded: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 8:59:57 AM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 8:59:57 AM] Downloading: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:00:49 AM] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:00:53 AM] Downloaded: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:00:53 AM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:00:53 AM] Downloading: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:01:37 AM] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:01:40 AM] Downloaded: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:01:40 AM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:01:40 AM] Downloading: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:02:21 AM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:02:24 AM] Downloaded: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:02:24 AM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:02:24 AM] Downloading: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:02:24 AM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:02:24 AM] Downloaded: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:02:24 AM] Checking Existing File: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:02:24 AM] Downloading: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:03:39 AM] Validating: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:03:43 AM] Downloaded: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:03:43 AM] Checking Existing File: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:03:43 AM] Downloading: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:04:21 AM] Validating: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:04:24 AM] Downloaded: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:04:24 AM] Checking Existing File: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:04:24 AM] Downloading: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:04:41 AM] Validating: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:04:43 AM] Downloaded: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:04:43 AM] Preparing USB drive
[2025-09-29 9:04:44 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025-09-29 9:04:44 AM] Copying: 1u5t-14g386-cb.tar.gz
[2025-09-29 9:04:44 AM] Validating: 1u5t-14g386-cb.tar.gz
[2025-09-29 9:04:44 AM] Copied: 1u5t-14g386-cb.tar.gz
[2025-09-29 9:04:44 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 9:04:44 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 9:04:44 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 9:04:44 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 9:04:44 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 9:04:44 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 9:05:07 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 9:05:20 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 9:05:20 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 9:05:20 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 9:05:57 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 9:06:15 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 9:06:15 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 9:06:15 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 9:07:08 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 9:07:37 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 9:07:37 AM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 9:07:37 AM] Copying: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 9:08:19 AM] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 9:08:41 AM] Copied: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2025-09-29 9:08:41 AM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 9:08:41 AM] Copying: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 9:09:44 AM] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 9:10:19 AM] Copied: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2025-09-29 9:10:19 AM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 9:10:19 AM] Copying: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 9:11:28 AM] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 9:12:05 AM] Copied: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2025-09-29 9:12:05 AM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 9:12:05 AM] Copying: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 9:13:12 AM] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 9:13:48 AM] Copied: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2025-09-29 9:13:48 AM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 9:13:48 AM] Copying: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 9:14:55 AM] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 9:15:32 AM] Copied: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2025-09-29 9:15:32 AM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 9:15:32 AM] Copying: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 9:16:54 AM] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 9:17:37 AM] Copied: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2025-09-29 9:17:37 AM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:17:37 AM] Copying: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:18:44 AM] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:19:20 AM] Copied: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2025-09-29 9:19:20 AM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:19:20 AM] Copying: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:20:32 AM] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:21:09 AM] Copied: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2025-09-29 9:21:09 AM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:21:09 AM] Copying: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:22:19 AM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:22:56 AM] Copied: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2025-09-29 9:22:56 AM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:22:56 AM] Copying: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:22:56 AM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:22:56 AM] Copied: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2025-09-29 9:22:56 AM] Checking Existing File: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:22:56 AM] Copying: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:24:21 AM] Validating: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:25:06 AM] Copied: 4U5T-14G422-CAJ_1626961442000.TAR.GZ
[2025-09-29 9:25:06 AM] Checking Existing File: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:25:06 AM] Copying: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:25:53 AM] Validating: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:26:19 AM] Copied: 4U5T-14G422-CBJ_1626962550000.TAR.GZ
[2025-09-29 9:26:19 AM] Checking Existing File: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:26:19 AM] Copying: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:26:54 AM] Validating: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:27:12 AM] Copied: 4U5T-14G422-CCJ_1626963400000.TAR.GZ
[2025-09-29 9:27:12 AM] Generating reformat.lst
[2025-09-29 9:27:12 AM] Generating autoinstall.lst
[2025-09-29 9:27:12 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
From your opening description, this will be the first time you will run a reformat against the unit, it should be ok now. The other run I suspect was for the interrogator log which was produced but with the overlays warning.
If your current usb fails, try with one from a good brand like Sandisk
I did the update to 3.4 and everything is working great. I now have carplay on my 2016 F150
Great!, remember to perform a master reset if you haven’t done so after upgrading.
Well done…you could probably now install the latest maps sometime if you wish.
Good catch!, I didn’t notice that.
Is there anything special I need to do to just install newer maps.
Going to install newer maps
Version: 3.0.23219
FILES (30)
[2025-09-29 6:37:51 PM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: 2.24 (2024) - NA
[2025-09-29 6:37:51 PM] Install Mode: Auto-Detect (reformat) Forced: False
[2025-09-29 6:37:51 PM] MY20 Protection: Disabled / Not MY20
[2025-09-29 6:37:51 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025-09-29 6:37:52 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2025-09-29 6:37:52 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 6:37:52 PM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2025-09-29 6:37:52 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 6:37:53 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[2025-09-29 6:37:53 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 6:37:55 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2025-09-29 6:37:55 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 6:37:58 PM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2025-09-29 6:37:58 PM] Checking Existing File: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:37:58 PM] Downloading: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:38:27 PM] Validating: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:38:30 PM] Downloaded: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:38:30 PM] Checking Existing File: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:38:30 PM] Downloading: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:39:05 PM] Validating: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:39:08 PM] Downloaded: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:39:08 PM] Checking Existing File: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:39:08 PM] Downloading: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:39:40 PM] Validating: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:39:44 PM] Downloaded: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:39:44 PM] Checking Existing File: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:39:44 PM] Downloading: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:40:20 PM] Validating: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:40:24 PM] Downloaded: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:40:24 PM] Checking Existing File: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:40:24 PM] Downloading: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:41:01 PM] Validating: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:41:04 PM] Downloaded: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:41:04 PM] Checking Existing File: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:41:04 PM] Downloading: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:41:42 PM] Validating: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:41:46 PM] Downloaded: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:41:46 PM] Checking Existing File: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:41:46 PM] Downloading: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:42:26 PM] Validating: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:42:31 PM] Downloaded: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:42:31 PM] Checking Existing File: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 6:42:31 PM] Downloading: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 6:42:56 PM] Validating: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 6:43:00 PM] Downloaded: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 6:43:00 PM] Checking Existing File: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 6:43:00 PM] Downloading: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 6:43:33 PM] Validating: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 6:43:37 PM] Downloaded: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 6:43:37 PM] Checking Existing File: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 6:43:37 PM] Downloading: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 6:44:20 PM] Validating: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 6:44:26 PM] Downloaded: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 6:44:26 PM] Checking Existing File: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 6:44:26 PM] Downloading: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 6:44:50 PM] Validating: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 6:44:52 PM] Downloaded: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 6:44:52 PM] Checking Existing File: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 6:44:52 PM] Downloading: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 6:45:07 PM] Validating: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 6:45:09 PM] Downloaded: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 6:45:09 PM] Preparing USB drive
[2025-09-29 6:45:09 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2025-09-29 6:45:09 PM] 1u5t-14g386-cb.tar.gz exists and validated successfully, skipping copy
[2025-09-29 6:45:09 PM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2025-09-29 6:45:09 PM] PU5T-14G386-BB_1690840002000.TAR.GZ exists and validated successfully, skipping copy
[2025-09-29 6:45:09 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2025-09-29 6:45:22 PM] 5U5T-14G391-CS_1660783942000.TAR.GZ exists and validated successfully, skipping copy
[2025-09-29 6:45:22 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2025-09-29 6:45:41 PM] 4U5T-14G423-CC_1615429225000.TAR.GZ exists and validated successfully, skipping copy
[2025-09-29 6:45:41 PM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2025-09-29 6:46:10 PM] NU5T-14G381-AD_1689364279000.TAR.GZ exists and validated successfully, skipping copy
[2025-09-29 6:46:10 PM] Checking Existing File: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:46:10 PM] Copying: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:47:14 PM] Validating: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:47:50 PM] Copied: 4U5T-14G421-CAH_1739451493000.TAR.GZ
[2025-09-29 6:47:50 PM] Checking Existing File: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:47:50 PM] Copying: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:49:04 PM] Validating: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:49:43 PM] Copied: 4U5T-14G421-CBH_1739452251000.TAR.GZ
[2025-09-29 6:49:43 PM] Checking Existing File: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:49:43 PM] Copying: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:50:59 PM] Validating: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:51:39 PM] Copied: 4U5T-14G421-CCH_1739452486000.TAR.GZ
[2025-09-29 6:51:39 PM] Checking Existing File: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:51:39 PM] Copying: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:53:11 PM] Validating: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:54:01 PM] Copied: 4U5T-14G421-CDH_1739454837000.TAR.GZ
[2025-09-29 6:54:01 PM] Checking Existing File: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:54:01 PM] Copying: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:55:15 PM] Validating: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:55:55 PM] Copied: 4U5T-14G421-CEH_1739455023000.TAR.GZ
[2025-09-29 6:55:55 PM] Checking Existing File: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:55:55 PM] Copying: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:57:09 PM] Validating: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:57:48 PM] Copied: 4U5T-14G421-CFH_1739455629000.TAR.GZ
[2025-09-29 6:57:48 PM] Checking Existing File: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:57:48 PM] Copying: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:59:06 PM] Validating: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:59:48 PM] Copied: 4U5T-14G421-CGH_1739455773000.TAR.GZ
[2025-09-29 6:59:48 PM] Checking Existing File: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 6:59:48 PM] Copying: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 7:00:36 PM] Validating: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 7:01:02 PM] Copied: 4U5T-14G421-CJH_1739456204000.TAR.GZ
[2025-09-29 7:01:02 PM] Checking Existing File: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 7:01:02 PM] Copying: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 7:02:09 PM] Validating: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 7:02:44 PM] Copied: 4U5T-14G421-CHH_1739455946000.TAR.GZ
[2025-09-29 7:02:44 PM] Checking Existing File: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 7:02:44 PM] Copying: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 7:04:04 PM] Validating: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 7:04:47 PM] Copied: 4U5T-14G422-CAP_1739450358000.TAR.GZ
[2025-09-29 7:04:47 PM] Checking Existing File: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 7:04:47 PM] Copying: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 7:05:39 PM] Validating: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 7:06:07 PM] Copied: 4U5T-14G422-CBP_1739456391000.TAR.GZ
[2025-09-29 7:06:07 PM] Checking Existing File: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 7:06:07 PM] Copying: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 7:06:41 PM] Validating: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 7:07:00 PM] Copied: 4U5T-14G422-CCP_1739456546000.TAR.GZ
[2025-09-29 7:07:00 PM] Generating reformat.lst
[2025-09-29 7:07:00 PM] Generating autoinstall.lst
[2025-09-29 7:07:00 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
No…just select 'update maps only '. Sometimes you have to reinstall 3.4.23188 along with the new maps.
He has to do a reformat since he is NA. He cannot do the latest maps by themselves as they are ESN locked.
