Upgraded 2018 f150 sync 3 from 4" screens to 8" in center stack and cluster, apim w/navigation, and acm with HD radio and XM. I’ve updated the antenna to XM and added the splitter cable. All swapped components year 2018 aside from APIM which is 2019.
On the screen, I have the XM button, when I press the XM button on screen, I get the beep and no screen change. If I press the xm button, hear the beep and turn the radio dial, the xm screen appears and plays fm radio. In this screen, I can input a channel, however it cannot acquire a channel. I have yet to get the XM home screen or information channel to load. Believe I may have a error with USB also as the button remains black outlined. And for attempts, I cannot get the center channel speaker to work.
ACM shows no errors or DTC, xm signal refresh has been unsuccessful.
Vehicle, 2018 f150 XL, regular cab.
Install Type: OEM Replacement
Old SYNC Version: 3.3.19052
No.
Syn3 Updater Version: 2.13.1.0
Version: 3.4.23188
Model: USB DISK 2.0 USB Device
FileSystem: FAT32
; CyanLabs Syn3Updater 2.13.1.0 Stable - downgrade Mode - Sync 3.4.23188 NA
FILES (17)
[2/16/2025 10:13:59 AM] Selected Region: NA - Release: Sync 3.4.23188 - Map Version: NA - 2025-02-15 - 1739637713
[2/16/2025 10:13:59 AM] Install Mode: Auto-Detect (downgrade) Forced: False
[2/16/2025 10:13:59 AM] MY20 Protection: Auto-Detect
[2/16/2025 10:13:59 AM] Formatting USB drive
[2/16/2025 10:13:59 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2/16/2025 10:14:07 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/16/2025 10:14:09 AM] Validated: 4U5T-14G381-AN_1552583626000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:09 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2/16/2025 10:14:09 AM] Validated: GB5T-14G386-SC_85041.tar.gz (Skipping Download)
[2/16/2025 10:14:09 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2/16/2025 10:14:09 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2/16/2025 10:14:09 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/16/2025 10:14:09 AM] Validated: PU5T-14G386-BB_1690840002000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:09 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/16/2025 10:14:10 AM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:10 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/16/2025 10:14:12 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:12 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/16/2025 10:14:14 AM] Validated: NU5T-14G381-AD_1689364279000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:14 AM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2/16/2025 10:14:16 AM] Validated: 4U5T-14G421-CJG_1709610049000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:16 AM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2/16/2025 10:14:19 AM] Validated: 4U5T-14G421-CHG_1709609492000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:19 AM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2/16/2025 10:14:23 AM] Validated: 4U5T-14G421-CGG_1709608813000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:23 AM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2/16/2025 10:14:26 AM] Validated: 4U5T-14G421-CFG_1709608559000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:26 AM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2/16/2025 10:14:29 AM] Validated: 4U5T-14G421-CEG_1709607297000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:29 AM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2/16/2025 10:14:33 AM] Validated: 4U5T-14G421-CDG_1709589204000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:33 AM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2/16/2025 10:14:37 AM] Validated: 4U5T-14G421-CCG_1709587982000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:37 AM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2/16/2025 10:14:40 AM] Validated: 4U5T-14G421-CBG_1709587496000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:40 AM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2/16/2025 10:14:43 AM] Validated: 4U5T-14G421-CAG_1708029977000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:43 AM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2/16/2025 10:14:47 AM] Validated: 4U5T-14G422-CAN_1709610798000.TAR.GZ (Skipping Download)
[2/16/2025 10:14:47 AM] Preparing USB drive
[2/16/2025 10:14:47 AM] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/16/2025 10:14:47 AM] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/16/2025 10:15:22 AM] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/16/2025 10:15:43 AM] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[2/16/2025 10:15:43 AM] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[2/16/2025 10:15:43 AM] Copying: GB5T-14G386-SC_85041.tar.gz
[2/16/2025 10:15:43 AM] Validating: GB5T-14G386-SC_85041.tar.gz
[2/16/2025 10:15:43 AM] Copied: GB5T-14G386-SC_85041.tar.gz
[2/16/2025 10:15:43 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2/16/2025 10:15:43 AM] Copying: 1u5t-14g386-cb.tar.gz
[2/16/2025 10:15:44 AM] Validating: 1u5t-14g386-cb.tar.gz
[2/16/2025 10:15:44 AM] Copied: 1u5t-14g386-cb.tar.gz
[2/16/2025 10:15:44 AM] Checking Existing File: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/16/2025 10:15:44 AM] Copying: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/16/2025 10:15:44 AM] Validating: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/16/2025 10:15:44 AM] Copied: PU5T-14G386-BB_1690840002000.TAR.GZ
[2/16/2025 10:15:44 AM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/16/2025 10:15:44 AM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/16/2025 10:16:15 AM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/16/2025 10:16:31 AM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[2/16/2025 10:16:31 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/16/2025 10:16:31 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/16/2025 10:17:14 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/16/2025 10:17:38 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2/16/2025 10:17:38 AM] Checking Existing File: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/16/2025 10:17:38 AM] Copying: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/16/2025 10:18:43 AM] Validating: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/16/2025 10:19:20 AM] Copied: NU5T-14G381-AD_1689364279000.TAR.GZ
[2/16/2025 10:19:20 AM] Checking Existing File: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2/16/2025 10:19:20 AM] Copying: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2/16/2025 10:20:18 AM] Validating: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2/16/2025 10:20:48 AM] Copied: 4U5T-14G421-CJG_1709610049000.TAR.GZ
[2/16/2025 10:20:48 AM] Checking Existing File: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2/16/2025 10:20:48 AM] Copying: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2/16/2025 10:22:11 AM] Validating: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2/16/2025 10:22:55 AM] Copied: 4U5T-14G421-CHG_1709609492000.TAR.GZ
[2/16/2025 10:22:55 AM] Checking Existing File: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2/16/2025 10:22:55 AM] Copying: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2/16/2025 10:24:25 AM] Validating: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2/16/2025 10:25:16 AM] Copied: 4U5T-14G421-CGG_1709608813000.TAR.GZ
[2/16/2025 10:25:16 AM] Checking Existing File: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2/16/2025 10:25:16 AM] Copying: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2/16/2025 10:26:52 AM] Validating: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2/16/2025 10:27:41 AM] Copied: 4U5T-14G421-CFG_1709608559000.TAR.GZ
[2/16/2025 10:27:41 AM] Checking Existing File: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2/16/2025 10:27:41 AM] Copying: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2/16/2025 10:29:15 AM] Validating: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2/16/2025 10:30:05 AM] Copied: 4U5T-14G421-CEG_1709607297000.TAR.GZ
[2/16/2025 10:30:05 AM] Checking Existing File: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2/16/2025 10:30:05 AM] Copying: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2/16/2025 10:31:52 AM] Validating: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2/16/2025 10:32:52 AM] Copied: 4U5T-14G421-CDG_1709589204000.TAR.GZ
[2/16/2025 10:32:52 AM] Checking Existing File: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2/16/2025 10:32:52 AM] Copying: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2/16/2025 10:34:33 AM] Validating: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2/16/2025 10:35:24 AM] Copied: 4U5T-14G421-CCG_1709587982000.TAR.GZ
[2/16/2025 10:35:24 AM] Checking Existing File: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2/16/2025 10:35:24 AM] Copying: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2/16/2025 10:37:05 AM] Validating: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2/16/2025 10:37:54 AM] Copied: 4U5T-14G421-CBG_1709587496000.TAR.GZ
[2/16/2025 10:37:54 AM] Checking Existing File: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2/16/2025 10:37:54 AM] Copying: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2/16/2025 10:39:23 AM] Validating: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2/16/2025 10:40:06 AM] Copied: 4U5T-14G421-CAG_1708029977000.TAR.GZ
[2/16/2025 10:40:06 AM] Checking Existing File: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2/16/2025 10:40:06 AM] Copying: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2/16/2025 10:41:46 AM] Validating: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2/16/2025 10:42:40 AM] Copied: 4U5T-14G422-CAN_1709610798000.TAR.GZ
[2/16/2025 10:42:40 AM] Generating reformat.lst
[2/16/2025 10:42:40 AM] Generating autoinstall.lst
[2/16/2025 10:42:40 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
