2018 f150 Sync 3 upgrades, XM radio unable to get working
Can you list the part numbers for the APIM and ACM you used?
Did you have to add the extra wiring for the SDL or was it already there?
  • X40 Setting (X40)
    • 7DO-08-01 xxxX xxxx xxxx (Should likely be ‘7’).
      • MN=Previous asbuilt value.
      • X40 setting=Must be changed from pre-X40 to X40.
      • Message setting=Previous asbuilt value.
      • CCS=Previous asbuilt value.
