TimMKX
(TimMKX)
16 April 2021 14:21
188
I work in customer service, so i know first hand how people don’t want to read documentation and instead just want someone to tell them what to do.
I did want to say thank you for all the documentation, I have certainly read it multiple times now as I prepare to do my own 3.0 to 3.4 upgrade. The documentation, and these forums, are amazing. Keep up the great work!
Raggio
(Raggio)
16 April 2021 14:57
189
The fastest way is try to downgrade and reformat, and install only the maps and voice you need.
Try this after unistall gracenote.
Install only the maps and voice you need creates space for future upgrade.
Bye, Giorgio.
CyanLabs
(Scott)
16 April 2021 15:43
190
I work in IT Support i know, it’s annoying!
After having mem problems I successfully installed map updates f9 2nd update and f10 with cyanlabs ci mode and autoinstall. In order to avoid mem problems I selected only map files and licenses and not voice files. My questions are:
What exactly are voice files and are so big?
Now that I have not update them, the system will use the ones of f9 1st update or will have any problem?
Can I repeat the installation of f10 maps and select only voice files?
F150Chief
(F150Chief)
22 April 2021 20:13
192
Could you post the Interrogator file for the APIM? Let’s see how the unit looks first.
<p:OTAModuleSnapShot xmlns:d2p1=“urn:ford/Vehicle/Module/Information/v3.0” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance ” xmlns:p=“urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0” version=“2021-04-23” xsi:schemaLocation=“urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd”>
<p:VIN>XXXXXXXXXXXXXXXXXXXXX</p:VIN>
<p:RequestRole>
d2p1:Role CONSUMER</d2p1:Role>
d2p1:RoleSource OTA</d2p1:RoleSource>
d2p1:RoleDesc SYNCGEN3</d2p1:RoleDesc>
d2p1:RoleID OTA</d2p1:RoleID>
</p:RequestRole>
<p:BroadcastDTCType/>
<p:Node isFlashed=“false” specificationCategory=“GGDS”>
d2p1:Address 7D0</d2p1:Address>
<d2p1:ECUAcronym name=“APIM”>
d2p1:State
<d2p1:Gateway gatewayType=“NONE”>
<d2p1:DID didFormat=“ASCII” didType=“Embedded Consumer Operating System Part Number” didValue=“8033” responseLength=“24”>
d2p1:Response 5U5T-14G381-ER</d2p1:Response>
d2p1:IsConfig false</d2p1:IsConfig>
</d2p1:DID>
<d2p1:DID didFormat=“Packeted” didType=“Embedded Consumer Applications Part Numbers 1” didValue=“8060” responseLength=“384”>
d2p1:Response 315535542d3134473432312d424148000000000000000000315535542d3134473432312d424248000000000000000000315535542d3134473432312d424348000000000000000000315535542d3134473432312d424448000000000000000000315535542d3134473432312d424548000000000000000000315535542d3134473432312d424647000000000000000000315535542d3134473432312d424748000000000000000000315535542d3134473432312d424847000000000000000000315535542d3134473432312d424a48000000000000000000315535542d3134473635382d414600000000000000000000345535542d3134473432322d424245000000000000000000345535542d3134473432322d424145000000000000000000345535542d3134473432322d424345000000000000000000345535542d3134473432322d424445000000000000000000355535542d3134473339312d414e00000000000000000000315535542d3134473432342d424b00000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“Packeted” didType=“Embedded Consumer Applications Part Numbers 1” didValue=“8061” responseLength=“384”>
d2p1:Response 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“HEX” didType=“ECU Checksum 1” didValue=“D704” responseLength=“4”>
d2p1:Response b09bb150</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“HEX” didType=“ECU Checksum 2” didValue=“D705” responseLength=“4”>
d2p1:Response 1a30f2db</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE00” didValue=“DE00”>
d2p1:Response 086a019a50027c064282</d2p1:Response>
d2p1:IsConfig true</d2p1:IsConfig>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE01” didValue=“DE01”>
d2p1:Response 47520004c08a0890acb8ce04</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE02” didValue=“DE02”>
d2p1:Response 0000010000</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE03” didValue=“DE03”>
d2p1:Response 00001d82390101</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE04” didValue=“DE04”>
d2p1:Response 190819082653</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE05” didValue=“DE05”>
d2p1:Response 80</d2p1:Response>
</d2p1:DID>
<d2p1:DID didType=“Direct Configuraation DID DE06” didValue=“DE06”>
d2p1:Response 0b053300000000642800005656680061</d2p1:Response>
</d2p1:DID>
d2p1:Response DS-1U5T-14G371-EH</d2p1:Response>
</d2p1:DID>
d2p1:Response GU5T-14G380-FE</d2p1:Response>
</d2p1:DID>
d2p1:Response LU5T-14G371-GKF</d2p1:Response>
</d2p1:DID>
d2p1:Response 1U5T-14G375-HA</d2p1:Response>
</d2p1:DID>
d2p1:Response NZ2401GN</d2p1:Response>
</d2p1:DID>
d2p1:Response 00</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
d2p1:Response 1U5T-14G374-EH</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“ASCII” didType=“ECU Serial Number” didValue=“F18C” responseLength=“16”>
d2p1:Response </d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“HEX” didType=“ECU MAC Address 1” didValue=“F1D0” responseLength=“6”>
d2p1:Response xxxxzxxxx</d2p1:Response>
</d2p1:DID>
<d2p1:DID didFormat=“HEX” didType=“ECU MAC Address 2” didValue=“F1D1” responseLength=“6”>
d2p1:Response xxxxxxxxx</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:ODLNetwork d2p1:NetworkDataRate=“500” d2p1:NetworkName=“HS-CAN” d2p1:NetworkProtocol=“CAN” d2p1:DLCName=“SAE J1962” d2p1:Pins=“6,14”/>
<d2p1:AdditionalAttributes logGeneratedDateTime=“2021-04-23T17:38:43+00:00” RAM=“1085894656” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.1G” available=“892K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.8G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.3G” available=“14M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“1.5G” available=“7.9M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“2.2G” available=“17M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.7G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“38M” available=“396K”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.2G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/sd/MAP/” total=“3.1G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.4G” available=“26M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.6G” available=“27M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“4.1G” available=“24M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“3.4G” available=“33M”/>
<d2p1:PartitionHealth type=“/fs/Nuance/” total=“1.9G” available=“8.4M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/” total=“1.2G” available=“822M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/quip/” total=“35M” available=“13M”/>
<d2p1:PartitionHealth type=“/fs/rwdata/quip/” total=“90M” available=“71M”/>
<d2p1:PartitionHealth type=“/fs/mp/” total=“1.4G” available=“133M”/>
<d2p1:PartitionHealth type=“/fs/mp/resources” total=“73M” available=“432K”/>
<d2p1:PartitionHealth type=“/fs/images/” total=“54G” available=“13G”/>
d2p1:InstallationLog/
d2p1:SyncData 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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Can I install voice files and gracenotes with ci, considering the log above?
You have 13GB of free space, so yes.
tsilva30
(tsilva30)
3 May 2021 20:53
196
Hi guys,
I installed all maps and voice nav files to latest versions but I’m unable to use voice navigation… I checked IVSU versions and it only appears one map file (1U5T-14G421-BAH) and one voice nav file (4U5T-14G22-BDF) installed . Is this normal? Maps are working fine but apparently I only have one file…
tsilva30
(tsilva30)
3 May 2021 20:56
197
Versão: 5U5T-14G381-ER
Modelo APIM: 5U5T-14G371-GKC
Tipo APIM: Navigation
Tamanho APIM: 64GB
Espaço Livre APIM: 11G
01/05/2021 10:51:03 +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 892K / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.9M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 21M / 3.7G
/fs/sd/MAP/ = 396K / 38M
/fs/sd/MAP/ = 5.7M / 3.2G
/fs/sd/MAP/ = 24M / 3.1G
/fs/Nuance/ = 27M / 4.7G
/fs/Nuance/ = 29M / 4.9G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/Nuance/grace = 21M / 1003M
/fs/rwdata/ = 946M / 1.2G
/fs/rwdata/quip/ = 27M / 35M
/fs/rwdata/quip/ = 86M / 90M
/fs/mp/ = 133M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 11G / 54G
APIM AsBuilt
DE00: 0A6A019A50027C064082
DE01: 504F010BC00B4890ACB8EE05
DE02: 0000010000
DE03: 00001D8002010A
DE04: 190519052653
DE05: 80
DE06: 0B0033000000005EF100005656600061
According to the Interrogator results you posted, everything is installed. The IVSU info is typical, it does not show all the maps, etc.
Perform a Master Reset. You should have to re-pair your phone.
tsilva30
(tsilva30)
4 May 2021 23:50
199
It was that simple… It worked. Thanks
Raj_K
(Raj K)
5 May 2021 02:42
200
I had a same issue. Try to uninstall sync 3 updater, then reinstall it.
rpad
6 May 2021 09:57
201
Does anyone know if - just recent - a new version from 1U5T-14G421-BAG is released?
1U5T-14G421-BAG (3.2.20071) is from EU F9 maps, the latest version from EU F10 is 1U5T-14G421-BAH (3.2.20339).
LEEJUNE
(LEEJUNE)
11 May 2021 15:31
203
Hi,sir. Where can find CN(2.20) maps?
No link is publically known
How do I find out if the update installed all of the NA 2 2020 map update files? My ISVU only show 2 of the files?
Just run the APIM Interrogator Tool in the tools menu in the Syn3 Updater or separately in the tutorial in the Guides and Info section…
Tutorial: APIM Interrogator Utility - Ford / Guides & Info - CyanLabs Official Community
I ran it, but it makes no mention of file versions installed in the XML file or the interrogator webpage.
