Apim problem update
apim version
Install Type: Unknown
Old SYNC Version: 3.0.2024
Syn3 updater has determined you adre on 3.0.20204 and may be usin overlays
Syn3 updater is unable to dertmine the configuration of your apim
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2026-02-06" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>WF0FXXWPCFGD74937</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType>
  <d2p1:DTC DTCValue="f0000408"/>
</p:BroadcastDTCType>
  <d2p1:ECUAcronym name="APIM">
    <d2p1:State>
          <d2p1:Response>JR3T-14G381-AX</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>484235542d3134473432312d424300000000000000000000484235542d3134473432322d4242000000000000000000004a5233542d3134473339312d414500000000000000000000484235542d3134473432342d4243000000000000000000004a5233542d3134473432332d414200000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>0c71ce3a</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>d9653256</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>086a04921002ac4206c2</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>49540106c00a488000000000</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>0203010000</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>01001d00240102</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>1ac21aa42bd0</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>07003300000000171c000056566c006a</d2p1:Response>
        </d2p1:DID>
        <d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
        </d2p1:DID>
        <d2p1:DID didType="Direct Configuraation DID DE08" didValue="DE08">
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
          <d2p1:Response>DemoAudioProfile</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>DS-GB5T-14G371-CB</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>HB5T-14G380-CA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>HB5T-14G371-FAG</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>GB5T-14G375-FA</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>LV6M007K</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
        </d2p1:DID>
        <d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
        </d2p1:DID>
          <d2p1:Response>GB5T-14G374-CB</d2p1:Response>
        </d2p1:DID>
        </d2p1:DID>
          <d2p1:Response>88:c2:55:88:31:3c</d2p1:Response>
        </d2p1:DID>
          <d2p1:Response>88:c2:55:88:31:3d</d2p1:Response>
        </d2p1:DID>
      </d2p1:Gateway>
    </d2p1:State>
  </d2p1:ECUAcronym>
  <d2p1:ODLNetwork d2p1:NetworkDataRate="500" d2p1:NetworkName="HS1" d2p1:NetworkProtocol="CAN" d2p1:DLCName="SAE J1962" d2p1:Pins="6,14"/>
  <d2p1:AdditionalAttributes logGeneratedDateTime="2026-02-06T14:53:34+00:00" RAM="837623808" vmcuVersion="Vector_VMCU_02.02.20">
    <d2p1:PartitionHealth type="/dev/hd0t180" total="22579436544" available="115781600"/>
    <d2p1:PartitionHealth type="/dev/hd0t181" total="667216896" available="2097120"/>
    <d2p1:PartitionHealth type="/dev/hd0t177" total="37336064" available="2097152"/>
    <d2p1:InstallationLog/>
    <d2p1:SyncData>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</d2p1:SyncData>
  </d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
Just a few words?, ok… lets keep it that way:
Hi
Thank you !!! Downgrade do 2.2.17 and upgrade to 3.0 it work without any problems !!!
Before i try upgrade 3.0 to 3.4 is there any contraindications when i have vehicle from 2016 ?
I understand that in version 3.4 there is a problem with USB ports? (usb hub)
does the problem also occur for version 3.3?
There aren’t known issues with Mondeo, only the HUB that needs replacement. If you already went to 2.2 and then back to 3.0 Android Auto should work for you, and running the interrogator log against the unit should not “fail” like it did before (referencing to overlays). So if you have an Android Phone to test with, Android Auto should work.
It’s not a problem, your car was never meant to run 3.4… But you can replace it with a compatible one and it should be ok. In fact, if you do not use Car Play you do not need to upgrade it, Android Auto should/might work with your current hub on 3.4… But Car Play won’t work with a 2016 HUB.
As far as I remember, yes… but do not quote me on this…
