Compatible usb hub
Is the HC3T-14F014-BC Duel port usb hub compatible with a 2013 Ford Focus ST sync 3 retrofit. I currently have a single port hub installed and that works perfectly, but I’m running wireless android auto off it. So if i need to charge my phone I have to unplug it all the time. So I would like to goto a dual port if possible.
SYNC Region: ANZ
Old SYNC Version: 3.4.23188
No error messages.
Xx
Since it is a retrofit with Sync 3, yes this hub will work.
Is this a single hub in the dash?
Do you have 2 USB ports in the vehicle or just the ine?
If you change the hub from a single to a dual you will lose the funtionality of the downstream hub, or port, as the dual hubs are not pass thru.
HC3T-14F014-BC, HC3T-14F014-BD
2016-2019 Ford Police Interceptor Sedan (Taurus)
2016-2018 Ford Special Service Police Sedan
2016-2019 Ford Taurus Limited, SE, SEL, SHO
2019-2020 Ford Ranger Lariat, XLT
2017-2018 Ford C-Max Hybrid SE, Hybrid Titanium
2017-2018 Ford C-Max Energi SE, Energi Titanium, Hybrid SE, Hybrid Titanium
2015-2019 Ford Escape
2016-2022 Ford Edge
2016-2019 Ford Fiesta
2016-2019 Ford Flex
No, it is a single hub in the center cubbyhole (the one with the lid).
I only have the one usb port, So I won’t need the pass thru function.
Should work.
Thanks for that.
