Download Problems, trying 4 days
I’d like to update my Tourneo Custom (built 11/2018) to Sync 3.4 (currently 3.0) so I can then program the silent mode using Forscan, which can then be switched on and off in the menu.
For the past four days, I’ve been trying to copy the necessary files to a 32GB USB stick using the Cyanolabs tool Synupdater 3.
The download starts smoothly (8 downloads allowed simultaneously), but then it stalls and eventually stops hours later with various errors (host aborted, end of file reached, etc.).
I suspected my internet connection, but even using the 5G network doesn’t change anything.
Is this a known problem? Are Ford’s servers overloaded, and is there a workaround?
Old SYNC Version: 3.0.19502
end of file, intterupted by host
Syn3 Updater Version: newest
the appthe no longer starts yet
Take the number of downloads to 1.
The files are pulled from Ford’s Azure site repository, so you’re going to be limited by whatever Ford has going on any given day.
Set the connections to 1 instead of 8, make sure there’s enough free space on your local device for the download to finish.
Try again and provide the following if it fails:
  • screenshot of the Syn3updater window, showing the log and error.
  • screenshot of the “My PC”, where all devices are shown with their free space shown.
I am not near as versed at this as most in here are, but, personally I would try a different device . I was doing a Sync update and it took way too long , after that I tried to use the same stick and it was defective. Just a thought
Your logic is sound. Alot of people that use sub quality sticks do have problems.
Thank you very much for your support. I connected the laptop with an other cable directly to the router and the download Works. Today in the morning the update was finished.
I updated my sync now to 3.4.23188 and After the generally Reset the Error: PKG_ERROR4 i gone and it should work, also with the Station logotype.
But if I connected Forscan to configure on the APIM the silent mode, I get a warning that the Modul Version is still 3.
What did i do wrong?
SYNC version: SYNC 3. Please make sure the module version is correct.
WARNUNG! It is not allowed to use configuration and programming functions in case of wrong version specified, as it may cause module damage. If the module version is not correct, please remove vehicle profile and reconnect, specifying correct version.
I think you can ignore that, the module is in fact still Sync3.
I remember another topic where that was discussed, but I cannot remember where it was, or if it was related to calibration. So I think you can still use it to program the module.
What you can try is deleting Forscan’s profile and start a new fresh one.
Lets see what others have to say.
Run the Interrogator Utility and post the xml file…
Thank you! I’m new at forsscan and the first thing I do after the error is to delete the profile of the car. No change.
In the configuration screen of Forscan the car is still sync 3. I think thats the reason why forscan makes an error if I try to configure the APIM-modul
SYNC3 is a SYNC generation not the app version, you’ll get more details reading that individual module.
I tried running the tool on the car today, but I’m still getting the PKG_Error4 error message again.
I think I might have made a mistake at the end of the installation process, specifically when I removed the USB stick as prompted and then plugged it back in.
Could reinstalling everything be a solution? As far as I know, no error occurs during normal operation, but I want to program the control unit with FORSCAN so I can then activate silent mode.
May I push this topic again?
The situation is as follows: After updating my Sync 3.0.19205 to version 3.4.23188, I received the error message PKG_ERROR4.
However, Sync 3.4 is working perfectly and no longer reports any errors.
When I try to access the APIM module with Forscan to activate silent mode, I get the message: SYNC version: SYNC 3. Please make sure the module version is correct.
When I then tried to use the interrogator utility recommended by @F150Chief and plugged in the USB stick, the message reappeared.
An acquaintance recommended updating the APIM firmware with Forscan Beta. However, the available firmware is the same one that is already installed on the APIM.
In the Cyanolabs FAQ, I read that a downgrade is recommended for the PKG_ERROR4 error because something is apparently blacklisted.
What would you recommend? Thank you!
This is a normal message and dont worry about it unless you dont have a SYNC 3 module installed. If you dont like the message or think it shouldbe changed than you would need to let the Forscan team know that.
Never heard of silent mode, I just use the mute button.
But before I updated to 3.4. this message doesn’t appear in Forscan if I configured the APIM-module?!
The silent-mode, it’s not for audio :wink: The Silent-Mode disable all the lights of the car, for example on the camping Side. In Sync 3.4 it should be possible to activate and deactivate this in the display and in the Radio of the car. Every time and without Forscan.
I think you mean Dark Car Mode
No, it’s called Silent Mode in Forscan.
Silent means No sound, Dark means no light.
What I need is called SILENT mode in the Ford Tourneo custom. As you can see from the screenshot, it’s also called that in Forscan. It includes the car’s audio and visual elements. It might have had a different name before, as you can read in this article from the Raptor forum.
https://www.fordraptorforum.com/threads/forscan-silent-mode-for-camping-and-or-nefarious-activities.79434/
For my problem, it’s completely irrelevant what it’s called in Forscan :slight_smile:
