Thank you for the warning, I am well aware of the unpacked size of the .img files, it was just a thought, good heads up to avoid going down that road.
@CyanLabs, would you consider having a button on the interface for the Interrogator package for people to find out how much space they have left on the unit?
Hello, I used this method to update the navigation of a Ford raptor, from North America and installed the maps of Spain. It gave me problems after installation, but it worked, even though the voice was in German.
I tried to do a downgrade to reinstall again with more language packs, but I always get an error.
HI. I did like You said, I cut some files and instalation is done now. The problem now is that sync doesnt read the maps? Have someone had problem like that?
@imovane, you have a NON-NAV unit (HP5T-14G371-BAG) with 1.3GB of storage available. You have Gracenotes and are running Sync 3.4.19200, 5U5T-14G381-CD.
Your storage will allow you to upgrade to the latest Sync version. You may need to delete the Gracenotes first to perform the update and then re-install them.
When I bought a car from USA I had an icon Navigation but after upgrade from the ford web page this icon disapeared. Is it any possibility to install any navigation in my device?
Anyone know a way to change regions in MY20 cars ? The application says reformat is not safe for them so how can we change region and maps without reformat
The Syn3 Updater app does not change the region settings in your vehicle, it only enables you to load the maps, etc., for a different region. You will need FORScan, UCDS, or IDS to actually be able to change the region coding in the APIM or ACM. Further up this thread are discussions about this.
Note that CyanLabs does not support changing regions.
Hi!
I bought a ford edge 2020 from USA. I from Poland. I really would like to converse sync 3 to polish maps and language. All right, what I done before:
Originally version of sync3 was 3.4.19274 and I updated this to version 3.4.21098 via tool from ford site.
I made a usb drive via syn3 updater with polish map and language.
The sync3 was updated but not really because when sync3 restarted itself show messege “installation failed, error code: mem_err01”.
I took a usb drive from hub in car and start forscan. In forscan I change values in appropriate adresse like in tutorial.
Now I can see Europe map on dipslay but navigation do not recognize polish cities ( recognize only cities from USA) and I can switch language to polish. Can you help me?
PS next I made a log. I have 25 GB total memory and free space 1.5 GB. Then I remove gracenote and now I have 2.2 GB free space.
