I recently updated my SYNC3 software using the Ford download and more recently updated to F9 maps. Doing some checking recently i noticed that Gracenote doesnt have any version information. Should i be bothered about this or do i need to fix something.
Thanks in advance peoples.
If it doesn’t bother you then leave it alone. If it does, check the IVSU screen. If gracenote (14G423)is not listed then do the upgrade process again. Make sure all files are present in your USB. Including gracenote.
Thankyou for your reply. I’ll have to ignore it then as I’ve uploaded the log file long ago so the download is no longer available to me.
Gracenotes can be installed independently of the upgrade processes providing that there is a proper file available for your location/region.
This would be 4U5T-14G423-AA for EU.
Thats interesting. I’m in the U.K.
Welcome to the forum, check your PM.
I’ve done the update using the steps above and have fixed my issue.
Many thanks for everyone who have given their input.
F150Chief
(F150Chief)
9 September 2020 03:04
9
That’s great. Thanks for the update.
dzidzia
(DziDziA666)
13 March 2021 17:29
10
hi. Can you help me with Gracenote upload? I don’t know exactly in what sense should I rename autoinstal.lst …
dzidzia
(DziDziA666)
13 March 2021 17:39
11
this is what it should look like?
The package should be inside the syncmyride folder.
dzidzia
(DziDziA666)
13 March 2021 18:07
13
Hi. Yes, I have this gracenote file in my folder, the one on the outside is renamed autoinstall.lst
dzidzia
(DziDziA666)
13 March 2021 18:09
14
I don’t know if this was the case with editing autoinstall.lst
or how should I edit a file? i’m lost
You can use the updater app to do this… Syn3 Updater - CyanLabs
dzidzia
(DziDziA666)
13 March 2021 18:22
16
I have a problem with sync update installation
my computer is rubbish
I have the correct gracenote file. I just don’t know how to edit autoinstall
dzidzia
(DziDziA666)
13 March 2021 18:40
18
Yes. I’ve been working on it for over an hour. Is file editing just renaming?
20210313_194255|236x500
Item1 = 4U5T-14G423-AB_1598633764000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-AB_1598633764000.TAR.GZ
Options = Autoinstall
The file is named autoinstall.lst and is in the root of the usb. The GN file is in the SyncMyRide folder.
dzidzia
(DziDziA666)
13 March 2021 18:52
20
Please write me what it means, edit the file.
I totally don’t know how to look at i t:/
dzidzia
(DziDziA666)
13 March 2021 18:56
21
Ok. I have it like now. in the folder there is a zip file with gracenote. How do I edit the autoinstall file?
