No Apple CarPlay after upgrading to Sync 3.4 – am I missing something?
Hey everyone,
I’m a bit confused and hoping someone can point me in the right direction.
I have a 2016 Ford Focus Titanium Hatchback. It originally came with Sync 3 version 1.0 and did not have Apple CarPlay. I recently upgraded to Sync 3.4, and the update went smoothly—everything works great except Apple CarPlay still isn’t available.
I was under the impression that upgrading to 3.4 would enable CarPlay compatibility, but maybe I’m missing a step or requirement? Is there a separate installation needed for CarPlay? Do I need to install new hardware, or is this something I can activate myself?
I feel like I did everything right, but I’m clearly overlooking something. This community has been amazing, so thank you all in advance for any help or insight you can offer!
Old SYNC Version: 1.0
USB hubs are not supported. Please remove.
Syn3 Updater Version: not sure I did it yesterday with the newest version. The date I did it was05/08/2025
I did it on a different computer
Hello.
Does a message about incompatible hub appear? Have you tried with android auto?.
Have you performed a master reset?.
Since your vehicle is 2016, you would need to upgrade the USB hub as well.
Take a look at this guide → Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3
There’s the problem…
How do I fix that?
Thank you very much. I will take a look at that guide and I’ll take a look at upgrading the USB hub appreciate that thank you.
I did order a new USB hub it’ll be here Tuesday. Thank you for the help. Hopefully that fixes the issue.
Ok!, keep us posted.
