Hi CyanLabs. Hope you well.
I’m in South Africa and importer a USA 2018 Sync 3 - 3.0 17276 apim. I installed the apim and LCD myself in my Ford Everest 2016 Model that came with Sync 2. Everything is working perfect with android auto for maps. I found a Vin number of a 2017 model the same like my vehicle but came factory with sync3 without maps and uploaded that vin’s as build to the sync 3 apim
I used the sync 3 updated to create an interrogate tool to check how much memory my sync apim has. I believe it is the 32GB or even more if I calculate all the partitions space together. When I installed the apim, it did display USA maps but after I loaded South African asbuild it did not have maps afterwards. Obviously because its a USA apim. I can post the file the interrogate tool created from my apim for you to make sure I can update it with South African Maps 2020-Q4 or 2019Q4.
I want to use your sync 3 updater and I downloaded the ROW 2019 Q4 maps. Will this update work as is.
I know that you dont support region change but I believe a SA local vin as build same specs as my vehicle model just newer that came with navigation as build should change all required asbuild data that needs to be changed.
Secondly, I see there is a 2020 Q4 South African map update, but it is a paid feature. I’m interested to purchase this update to update my apim with. I would prefer this update
Will this paid feature update work with my apim storage space? I can send you the interrogated file of my sync3
Below is the botom of the sync 3 apim file
<d2p1:PartitionHealth type="/fs/usb0/" total=“29G” available=“29G”/>
<d2p1:PartitionHealth type="/fs/tmpfs/" total=“128M” available=“127M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“1.5G” available=“41M”/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total=“9.1G” available=“57M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“4.7G” available=“243M”/>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“475M” available=“13M”/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total=“1.0G” available=“5.1M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1024M” available=“604M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1024M” available=“173M”/>
<d2p1:PartitionHealth type="/fs/images/" total=“26G” available=“8.3G”/>
Hope yo hear from you soon.
Regards,
Eltiero
Navigation Variant: Yes
Install Type: OEM Replacement
Old SYNC Version: 3.0.17276
New SYNC Version: 3.0.17276
Syn3 Updater Version: 2.10.11.0
<p:OTAModuleSnapShot xmlns:d2p1="urn:ford/Vehicle/Module/Information/v3.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:p="urn:ford/com/productdesign/ipp/ModuleSnapshot/v2.0" version="2022-05-17" xsi:schemaLocation="urn:ford/Vehicle/Module/Information/v3.0 ModuleSnapshot.xsd">
<p:VIN>MNBAXXMAWAFU19491</p:VIN>
<p:RequestRole>
</p:RequestRole>
<p:BroadcastDTCType/>
<d2p1:ECUAcronym name="APIM">
<d2p1:State>
<d2p1:Response>JR3T-14G381-AJ</d2p1:Response>
</d2p1:DID>
<d2p1:Response>4a5233542d3134473432322d4343000000000000000000004a5233542d3134473432312d4342000000000000000000004a5233542d3134473339312d4344000000000000000000004a5233542d3134473432342d4342000000000000000000004a5233542d3134473432332d434100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>60db8807</d2p1:Response>
</d2p1:DID>
<d2p1:Response>f0571ef0</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0a6a04c21b008a4a4090</d2p1:Response>
</d2p1:DID>
<d2p1:Response>53460104c002000000800005</d2p1:Response>
</d2p1:DID>
<d2p1:Response>0000000203</d2p1:Response>
</d2p1:DID>
<d2p1:Response>010024002b0008</d2p1:Response>
</d2p1:DID>
<d2p1:Response>17fe180f2bd4</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>14043b0000000016760000565687005c</d2p1:Response>
</d2p1:DID>
<d2p1:Response>DS-HB5T-14G371-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HS7T-14G380-BB</d2p1:Response>
</d2p1:DID>
<d2p1:Response>JS7T-14G371-KED</d2p1:Response>
</d2p1:DID>
<d2p1:Response>HB5T-14G375-CA</d2p1:Response>
</d2p1:DID>
<d2p1:Response>VWBY05AA</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>HB5T-14G374-CA</d2p1:Response>
</d2p1:DID>
</d2p1:DID>
<d2p1:Response>64:cf:d9:4e:7b:69</d2p1:Response>
</d2p1:DID>
<d2p1:Response>64:cf:d9:4e:7b:6a</d2p1:Response>
</d2p1:DID>
</d2p1:Gateway>
</d2p1:State>
</d2p1:ECUAcronym>
<d2p1:AdditionalAttributes logGeneratedDateTime="2022-05-17T18:06:16+00:00" RAM="1479335936" vmcuVersion="Vector_VMCU_02.02.20">
<d2p1:PartitionHealth type="/fs/usb0/" total="29G" available="29G"/>
<d2p1:PartitionHealth type="/fs/tmpfs/" total="128M" available="127M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="1.5G" available="41M"/>
<d2p1:PartitionHealth type="/fs/sd/MAP/" total="9.1G" available="57M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="4.7G" available="243M"/>
<d2p1:PartitionHealth type="/fs/Nuance/" total="475M" available="13M"/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total="1.0G" available="5.1M"/>
<d2p1:PartitionHealth type="/fs/rwdata/" total="1024M" available="604M"/>
<d2p1:PartitionHealth type="/fs/mp/" total="1024M" available="173M"/>
<d2p1:PartitionHealth type="/fs/images/" total="26G" available="8.3G"/>
<d2p1:InstallationLog/>
<d2p1:SyncData>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</d2p1:SyncData>
</d2p1:AdditionalAttributes>
</p:Node>
</p:OTAModuleSnapShot>
