Hello! I’m using the app trying to update from 19200 to 20196. Everything is downloaded and checked ok, but when i plug the usb drive in the car, the auto update message appears and it stays there forever. Yesterday I’ve waited for 55 minutes and the message didn’t change. Is anything wrong or should I try the reformat way ?
Post the log file, it’s on your USB drive
Here it is:
CYANLABS - SYN3 UPDATER - V1.0.1.1
Operating System: Microsoft Windows 10 Pro (2004)
Version: 3.4.19200
Region: ANZ
Navigation: False
Mode: autoinstall FORCED
USB DETAILS
Model: SanDisk Cruzer Blade USB Device (Size: 58,4GB)
; CyanLabs Syn3Updater - Autoinstall Mode - Sync 3.4.20196 ANZ
Item1 = APPS - 5U5T-14G381-EG_1598634070000.TAR.GZ
Open1 = SyncMyRide\5U5T-14G381-EG_1598634070000.TAR.GZ
Item2 = VOICE - 5U5T-14G391-DM_1598636566000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-DM_1598636566000.TAR.GZ
Item1 = GRACENOTES - 4U5T-14G423-DA_123696.tar.gz
Open1 = SyncMyRide\4U5T-14G423-DA_123696.tar.gz
Options = Delay,Include,Transaction
SYNCMYRIDE FILES (3)
5U5T-14G381-EG_1598634070000.TAR.GZ (848,6MB)
4U5T-14G423-DA_123696.tar.gz (716,5MB)
5U5T-14G391-DM_1598636566000.TAR.GZ (1GB)
INFO: Starting process (Sync 3.4.20196 - ANZ - Non Nav APIM)
INFO: Verifying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Successfully Verified 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Verifying 4U5T-14G423-DA_123696.tar.gz
INFO: Successfully Verified 4U5T-14G423-DA_123696.tar.gz
INFO: Verifying 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: Successfully Verified 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: All downloads completed!
INFO: Re-creating partition table as MBR and formatting as ExFat on selected USB drive
INFO: Creating autoinstall autoinstall.lst
INFO: Copying 5U5T-14G381-EG_1598634070000.TAR.GZ
INFO: Copying 4U5T-14G423-DA_123696.tar.gz
INFO: Copying 5U5T-14G391-DM_1598636566000.TAR.GZ
INFO: PROCESS COMPLETE!
NON-NAV with no room to upgrade because it already has 3.4.19200 installed.
Go read this thread and join it with your issue.
Hi Carlos, the same thing happens to me, I left it up to 50 minutes and nothing.
Could you please run the APIM Interrogator Utility and post the storage data here.
If you used the SYN3 Updater, please post the log file that is on the USB root.
Tried everything on the post, none worked. One question still remains: to get 19200 i did the old manual reformat tutorial, from 3.0.19205 to 3.4.19200. If I do the same for 20196, will work?
The storage (before the gracenote removal):
RAM=“414330880” vmcuVersion=“Vector_VMCU_02.02.20”>
<d2p1:PartitionHealth type="/fs/Nuance/" total=“1.3G” available=“58M”/>
<d2p1:PartitionHealth type="/fs/Nuance/grace" total=“1.1G” available=“63M”/>
<d2p1:PartitionHealth type="/fs/rwdata/" total=“1.2G” available=“991M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“35M” available=“25M”/>
<d2p1:PartitionHealth type="/fs/rwdata/quip/" total=“90M” available=“88M”/>
<d2p1:PartitionHealth type="/fs/mp/" total=“1.4G” available=“144M”/>
<d2p1:PartitionHealth type="/fs/images/" total=“3.0G” available=“403M”/>
Remove Gracenotes, then downgrade to 3.3.19052.
See the tutorial page.
You will get 1.1GB returned to storage and should be able to downgrade.
I see you mention this a lot, is my gracenotes removal not working then?
I think the NON-NAV units are rather finicky about the storage for upgrades, and these in this thread in particular are special cases I think. Remember the conversation about rebooting the unit after running the Gracenotes delete script? I think this is a case where that has been beneficial. I would like to test the theory…
Yup, keep me updated
Hello, this is my first post on here.
Today I successfully updated to Sync 3.4.20196, but when using Syn3 Updater, I selected “Keep Existing Maps”, so maps were not updated.
Is there a way I can update maps from F7 to F9 please?
Thanks in advance, Ian
Repeat the process, make sure to update your current version if not already done and then simply select new maps.
OK, selected new current version as 3.4.20196 in Configuration.
Then in New Sync 3 Version secion, selected
- Region: EU
- Version: Sync 3.4.20196
- Map Version: F9 (2019) - EU (09/2020)
When I do that it shows “Downgrade” in bottom left corner.
I’ve acknowledged prompts to confirm the vehicle is not 2020.
It’s in the process of creating the USB now - Thankfully I already have 27.7GB of tar.gz files that had been saved to my machine, so these do not need downloading again.
Is what I have done correct?
Just want to be 100% sure.
Thanks very much for your help and advice.
Ian!
Looks correct to me.
I had the same problem and it was because my usb drive was not big enough.
yeah, i have recently added file sizes to each package so with a update to the app i can ensure that the size is fine. it’s on my long todo list
Perdoe-me a minha ignorância; como posso ativar os LOGOS das estações de rádio em Portugal?
Ou não é possível?
Obrigado.
Forgive me my ignorance; how can i activate the LOGOS of radio stations in Portugal? Or is it not possible? Thank you.
