My front camera on 2016 smax didn’t work until I changed to 7D0-02-01 xxxx xxx4 E4xx
Thank you!!
Thank you!!
Maybe I have missed it somewhere but is it possible to upgrade to the new maps only? I upgraded from 3.3 with F7 maps to 3.4.20196 with F9 maps a couple of months ago and would ideally like to upgrade to the latest maps.
Sorry if I’ve skipped over something that’s states if it can or can’t be done.
Yes but i recommend using the reformat tool, you can change the install mode in the app to “autoinstall” if you really want to use the normal method but it will take almost twice as long (make sure to unselect apps, gracenotes, enh_dab and voice), may not update due to insufficient storage and may just endlessly say “updating”
Reformat is highly recommended unless you have a My20 unit.
Thank you. My car is a MY19. If I do the reformat I assume I will have to redo any changes to splash screens etc I did with ForScan?
no forscan changes will be needed.
Okay, thank you.
I have started downloading the full package again, 3.4.20196 using the new tool and it has given me a warning about downgrading/not compatible with MY20 cars, will this be an issue?
if you do not have a my20 car then no
@CyanLabs great application mate. Faced some issues after doing the official ford update from 3.3 to 3.4.20136. No logos, laggy, not giving me the option to upgrade to F9 maps after upgrading to 3.4 , emergency call assist error afte starting car each time. Master reset, disconnected battery overnight but still same.
Had been trying to keep official, but as we know the community and Devs like yourself always sort it out.
Anyway did a downgrade/reformat Inc maps to 20196 using syn3 to crate the usb and all my issues are resolved.
learnt alot about the way these systems work from this site over the last week, so much appreciated.
Glad to hear it
i also learnt a lot since starting out this update guide
@CyanLabs @F150Chief
After a day or so the 4G modem including the fordpass localization was working again.
This morning the complete 4G modem including the SOS system has crashed and gives me an notification in my dash and red notice on the ceiling!
I’ve had this problem in the past, when they pushed an OTA update. They had too complete swap the computer and TCU. And now the problem is back… so this is not good news for the 3.4.20196 and not only MY20 (my car is a Focus 2018) issues…
I am wondering if I can go back to the 3.4.20136 (Cyanlabs or Ford Original), the 4G modem did work with that version…
Hey, in want to download the Sync 3.4 for my Ford Kuga 2018. I try that way you post on this site with all the downloads but it doesent work…
Normally you can just install the 20136 version over the 20196 version. It’s the same as doing a downgrade but just back to 20136. If it does not work it is probably because there is not enough storage. It that case, revert to 3.3.19052, then update back again to 20136.
If you downloaded thru the Syn3 Updater, please post the log file on the USB.
I spent ten hours downloading 3.4 . 20196 but it failed to load the final pair of files, I think to USB
and rewards me with err 05lst
Where can I find the log file, please?
this file is not visible in sink my ride but is referenced in the autoinstall file:
Open1 = SyncMyRide\1u5t-14g386-cb.tar.gz. So I suspect it is the key to the problem. Is it possible (and safe,) to add it to the USB drive in Sync my ride?
On the root of the USB. log.txt
LST_ERR05 – Error is LST_PKG_FILE_NOT_FOUND
Thank you. I do not have any text files on the USB just Sync my ride folder , autoinstall, dont index and reformat.
What does the PKG file contain, please?
Are you installing maps? NAV
Are you using the new SYN3 Updater? in automatic (Autoinstall) mode? Or did you use the manual mode?
That file, 1u5t-14g386-cb.tar.gz, needs to be in the SyncMyRide folder.
Thank you for your patience. I used the new updater in automatic mode and I am trying to install Maps in my Nav equipped Fiesta 2017 mk8 Sync 3 model that I have updated to v3.0 using the Ford website. Can the missing file be downloaded to the hard drive and added to USB without having to repeat the whole process?
post both the contents of the autoinstall.lst file and reformat.lst file, please. I want to be sure I have you do the right thing…
Yes the file can be added.
Here is the autoinstall file:
; CyanLabs Syn3Updater - reformat Mode - Sync 3.4.20196 EU
and this is the reformat one:
APPS=5U5T-14G381-EG_1598634070000.TAR.GZ
GRACENOTES=4U5T-14G423-AA_123694.tar.gz
VOICE=5U5T-14G391-AM_1598633466000.TAR.GZ
MAP=1U5T-14G421-BAG_1591726015000.TAR.GZ
MAP=1U5T-14G421-BBG_1591726765000.TAR.GZ
MAP=1U5T-14G421-BCG_1591726913000.TAR.GZ
MAP=1U5T-14G421-BDG_1591727234000.TAR.GZ
MAP=1U5T-14G421-BEG_1591727457000.TAR.GZ
MAP=1U5T-14G421-BFG_1591727753000.TAR.GZ
MAP=1U5T-14G421-BGG_1591728190000.TAR.GZ
MAP=1U5T-14G421-BHG_1591728542000.TAR.GZ
MAP=1U5T-14G421-BJG_1591729086000.TAR.GZ
VOICE_NAV=4U5T-14G422-BAE_1580861780000.TAR.GZ
VOICE_NAV=4U5T-14G422-BBE_1580861854000.TAR.GZ
VOICE_NAV=4U5T-14G422-BCE_1580861916000.TAR.GZ
VOICE_NAV=4U5T-14G422-BDE_1580862152000.TAR.GZ
MAP_LICENSE=1U5T-14G424-BJ_1591719092000.TAR.GZ
