Sync 3.4.20196 - Feedback & Issues
With an 18 Mondeo you should see the logos by updating and using the logo file.
Good night Eng.
I don’t want to waste your time on my subject. But I couldn’t see it. Keep on showing only the letters for each radio station.
Once again, thank you very much for your commitment.
Since updating to 20196 my ambient lighting isn’t working properly. Passenger side footwell led shows different color blue when one of the two blues are selected. White, amber, red, green and purple all work fine. I tried re-updating with 20196 and master reset to no avail. Any thoughts, ideas appreciated. Thanks!
Did you change to the Lincoln themes?
Yes, tried multiple Lincoln themes. No change in colors by theme.
There is a setting in the BCM for changing the color schemes based on the Ford or Lincoln themes. They do not line up. If you changed themes between Ford and Lincoln, you could be out of sync on the colors, which are driven by the BCM, Not the APIM.
Ambient Lighting:
Fixes Incorrect Color Choices When Using Lincoln Theme
BCM Module:
726-31-02 xxxx 07xx xxxx Lincoln Ambient Lighting Colors
Ambient Lighting Door Ajar Color:
Sets the color of the ambient LED for the open door (ajar).
726-31-01 x0xx xxxx xxxx Ice Blue - Ford
726-31-01 x1xx xxxx xxxx Orange - Ford
726-31-01 x2xx xxxx xxxx Soft Blue - Ford
726-31-01 x3xx xxxx xxxx Red - Ford ← Default F150
726-31-01 x4xx xxxx xxxx Green - Ford
726-31-01 x5xx xxxx xxxx Blue - Ford
726-31-01 x6xx xxxx xxxx Purple - Ford
726-31-01 x7xx xxxx xxxx White - Lincoln
726-31-01 x8xx xxxx xxxx Amber - Lincoln
726-31-01 x9xx xxxx xxxx Teal - Lincoln
726-31-01 xAxx xxxx xxxx Red – Lincoln ← Default Lincoln
726-31-01 xBxx xxxx xxxx Blue - Lincoln
726-31-01 xCxx xxxx xxxx Green - Lincoln
726-31-01 xDxx xxxx xxxx Lilac - Lincoln
726-31-01 xExx xxxx xxxx Unknown E
726-31-01 xFxx xxxx xxxx Unknown F
Ambient Lighting Entry Color:
Sets the ambient lighting color when you enter/exit the vehicle…this is independent from the color selected on the APIM screen.
726-31-02 xxxx x0xx xxxx Ice Blue - Ford ← Default F150
726-31-02 xxxx x1xx xxxx Orange - Ford
726-31-02 xxxx x2xx xxxx Soft Blue - Ford
726-31-02 xxxx x3xx xxxx Red - Ford
726-31-02 xxxx x4xx xxxx Green - Ford
726-31-02 xxxx x5xx xxxx Blue - Ford
726-31-02 xxxx x6xx xxxx Purple - Ford
726-31-02 xxxx x7xx xxxx White - Lincoln ← Default Lincoln
726-31-02 xxxx x8xx xxxx Amber - Lincoln
726-31-02 xxxx x9xx xxxx Teal - Lincoln
726-31-02 xxxx xAxx xxxx Red - Lincoln
726-31-02 xxxx xBxx xxxx Blue - Lincoln
726-31-02 xxxx xCxx xxxx Green - Lincoln
726-31-02 xxxx xDxx xxxx Lilac - Lincoln
726-31-02 xxxx xExx xxxx Unknown E
726-31-02 xxxx xFxx xxxx Unknown F
Thanks! I don’t have 726-31-02 in my Asbuilt. Is there anywhere else to modify Ambient lighting?
Just updated the apps only from 3.4.20136 to 3.4.20196 as per the instructions on the top and it worked fine. looks good and only took 5-10 mins.
In the US, so no “DAB” option here, but looking to get logos with Sirius. I have a 2019 manufactured, non-NAV APIM and I’m 99% positive I had logos after I got Sirius working (2014 ACM vs 2019 APIM tweak was req’d) but they disappeared at some point. I found this page, As-Built Databases - #3 by Louage, and this setting:
7D0-02-03 #X##-##
The values for “C” and “D” have the same description though. Is that correct, either C or D will work for non-US users with Sirius ?
You should use ‘4’ in that value. You don’t have a traffic modem, not a US thing.
Online Traffic Modem (TPEG), Calm Screen (CS), Enhanced DAB (ED), AA OE Channel Feature (AACF)
7D0-02-03 x*xx xx
0=TPEG Not Available, CS Not Available, ED Off, AACF Available
1=TPEG Not Available, CS Not Available, ED Off, AACF Not Available
2=TPEG Not Available, CS Not Available, ED On, AACF Available
3=TPEG Not Available, CS Not Available, ED On, AACF Not Available
4=TPEG Not Available, CS Available, ED Off, AACF Available
5=TPEG Not Available, CS Available, ED Off, AACF Not Available
6=TPEG Not Available, CS Available, ED On, AACF Available
7=TPEG Not Available, CS Available, ED On, AACF Not Available
8=TPEG Available with Modem, CS Not Available, ED Off, AACF Available
9=TPEG Available with Modem, CS Not Available, ED Off, AACF Not Available
A=TPEG Available with Modem, CS Not Available, ED On, AACF Available
B=TPEG Available with Modem, CS Not Available, ED On, AACF Not Available
C=TPEG Available with Modem, CS Available, ED Off, AACF Available
D=TPEG Available with Modem, CS Available, ED Off, AACF Not Available
E=TPEG Available with Modem, CS Available, ED On, AACF Available
F=TPEG Available with Modem, CS Available, ED On, AACF Not Available
That’s right you have the old CGEA1.2 structure. I don’t know what value it would be, but it is in there. Explorer’s shared the same structure till just a few years ago, so Explorer forums might be a place to find info.
Haha ! Well, that’s a lot more options/choices than the thread I linked shows. Thanks (again) !!
That is an older thread that was written before the APIM Database was “flushed out”.
See this:
https://cyanlabs.net/ford-apim-asbuilt-db/
I just successfully upgraded from 3.0.19205 to 3.4.20196 without any problems. I have radio logos now and AC can be controlled by touch screen also now. Rear view camera zoom button does not work (after master reset), but doesn’t matter, I have never used it anyway.
Thank you!
Ford Focus Turnier 1.0 Ecoboost Titanium, 2017
Hello to the team.
I just upgraded to 20196 and everything works properly. I didn’t upgrade maps as I have 2020 model Puma and I was afraid trying downgrade. I have 3 questions,
The logos are only supported in dab stations? In fm stations I haven’t seen any logo but I don’t know if it is system problem or Greek stations do not transmit their logo.
After upgrade, no xml file created in order to upload to ford. Is this normal? What can I do?
As soon as I upgraded to 20196 is there a safe way to upgrade the maps?
Thanks in advance.
Hello Kostas,
  1. Logos are DAB and FM, but unfortunately as you say, not in Greece.
  2. Reporting the update to Ford does nothing for you, really. However if you wish to do so, run the Tutorial: APIM Interrogator Utility/Create Interrogator Log
  3. There is no safe way to run the reformat tool. I do not know if there is a stand alone map release from Ford you could run.
This might only be for North America, but try this:
https://syncnavigation.com/ford/home
Thanks for the answer, the only need for reporting to ford is to be informed concerning new updates especially for maps.
You will get the notices regardless.
Hi. Are these the latest updates for 20196?
I only ask cause the picture at the top of this page has 20196 for 3 of the files.
thanks.
For EU, yes. What is your vehicle and year?
