Sync 3.4.20196 - Feedback & Issues
When I want to set the temperature by voice command, he tells me to do it manually
What is gracenotes for?
I’ve heard of that and seen it only once. After a Master Reset it usually fixes it. Seems it got stuck on processing something, like maps, and didn’t finish.
You probably have manual controls only then. Otherwise it would not have responded like that.
Gracenotes is a CDDB music library.
But it has a bi-zone climate control, it’s weird, shouldn’t something be enabled?
It also helps with voice recognition mapping when using voice control, e.g. ā€˜Play a Rolling Stones album’ will do just that.
Was the voice control working in front of the update?
Please check your asbuilt values:
https://forscan.org/forum/viewtopic.php?t=13377
APIM 7D0-01-02 xxxx x*xx xx
0 : Climate control type automatic (Climate voice)
4 : Climate control type manual (Not climate voice)
A good reference for all apim related values is here:
https://cyanlabs.net/ford-apim-asbuilt-db/
@Louage @F150Chief @CyanLabs You guys have done a great job here, i am really stoked
Good evening everyone!!
I stopped by a Ford dealer today to find out how to get the radio station logs. They didn’t know! They stayed to consult Ford and after they told me.
My Ford mondeo / Fusion 2018 with update 3.40196.Made successfully, but with the help of Eng.Who knows, once again, tell me PF.
One small issue i’ve noticed since i got 20196 is with the radio.
for example, i could be listening to the 3rd station on the list and it would be highlighted but when i leave the car for a long time when i get back in, the same station will be playing but is no longer highlighted and if i change channels with the steering wheel controls the first station on the list is selected (it doesn’t go to the station either side of the one i was listening to).
It’s only a minor thing but just thought id mention it.
Other then that I’m happy with the new layout and the couple of extra features.
That is actually normal as far as I know. The preset highlights are not backlit unless you select it.
I’ve never paid attention to that, but the last time I saved my stations I did them in ascending order, left to right. I was being a geek, ok. They always go to the next one with the steering wheel buttons, up or down, from the station I am listening to. Maybe this has something to do with it?
I had lots of issues with getting calm screen to work on my setup. I had some odd firmware that caused forscan to not detect updates. After failing to update and bricking my APIM I got it to download F/W based on Hardware which worked after I fixed the issue with my OBDLink and it’s bad default settings.
Online Traffic Modem (OTM), Calm Screen (CS), Enhanced DAB (ED), AA OE Channel Feature (AACF)
7D0-02-03 x0xx xx <------My default on my Lincoln MKZ
7D0-02-03 x4xx xx <------My current setting to get Calm Screen working.
0=OTM Not Available, Calm Screen Disabled,EnhDAB Disabled, AACF Enabled
4=OTM Not Available, Calm Screen Enabled,EnhDAB Disabled, AACF Enabled
What ObdLink issues did you have? Can you post the settings that worked?
Glad you got it fixed…,
I would not be able to live with station presets if they aren’t in ā€œorderā€. Do people actually have them in random order ? :flushed:
Yes, and it bugs the …, out of me!
I had default settings with everything on FORScan set to auto. I followed this thread here and it explains it better than I ever could. USB adapters performance optimization - FORScan forum
The percent gauge was going at about one percent per minute. and would fail after an hour. After following the settings above and updating my obdlink to the most recent, I was able to finish the flash in about 10-15 minutes.
Thanks, I’ll go Thru it later.
I managed to update my Sync 3 from 3.0.19205 to the newest 3.4.20196 with NA1.19 Maps. Took about 35 minutes then a master reset.
Climate now on the Sync screen and it works but not voice command. So far everything else appears to be working correctly. Just wish I knew about this site before I purchased the NA1.19 Maps a couple of months ago! I like the new look and it boots up faster than before.
Thanks for the great software that made it so easy. Any idea when new Maps might be available?
Maps are a good guess.
Did you have climate control on the screen before?
No climate was not on the screen before
When you say voice command does not work, is that for just the climate control or everything?
You could reload the system voice file. But if you have not done so, perform a Master Reset.
