Sync 3.4.20282 - Feedback & Issues
but Explorer is a US manufactured car and in USA they don´t have DAB+
Sorry I’m not clear on what you’re asking, this seems to be answering your own question?
Unfortunately I guess this forum structure is very confusing
Quote the post you are answering.
Yes, this is true, but exported US cars to EU can be set up for DAB+ via the APIM and ACM asbuilt data, as per the article above.
that means, for DAB I don´t have to replace the ACM???
My original ACM is with SIRIUS and I replaced it with a new ACM from a KUGA with DAB, Was this not necessary?
I suppose you did the format of your hard drive so yes in my opinion not possible anymore.
I have the same but makes no difference it is al the same software and charts.
voice update is 8 gig
Maybe not, but it was a 2014 with older software and hardware. I think you did the right thing.
is there any tutorial for the pair radio station in south america? thanks
Everything is fine but i lost climate on screen. Is ot normal?
Hi… How do i see if my car is made in 2019 or 2020 ? if i look at the engine then it stand Nov. 2019 and it has led headlight as standard from factory and not H7 any more. But it is reg here at august 2020 on numberplate for first time and it is a 2020 model. I just think about the reformat tool will damge my Sync. It has from factory 3.4 19200 on it.
If you did not have climate on screen from the factory then yes it is normal. This is a bug fix in that case.
What vehicle and year?
You can update the app without reformat, which is really only needed for updating the maps. The Syn3 Updater will guide you thru it. Just do not use reformat.
I am not familiar with “Pair radio station” in SA.
@Louage, have you any knowledge about SA?
Its a 2018 Kuga. Right wheel drive. I did not have climate on screen but after an update i had it
Then this is normal. You were not supposed to have the climate screen.
Oooo no. And it was so… cute
Reson i ask, is beacse in my 2019 fiesta vignale it was install with reformat, and it works perfect without any problems. In my new 2020 fiesta vignale its sometimes reboot, startup like it was reset by tell the language is set to danish and the intelligent speedcontrol is tell wrong speedlimted and make my car go 80km/h where there is only 50Km/h. thats why i ask and hope if my new car also can use reformat and maybe make the software works better. The system is also working very slow, and in the old car its was much faster
i just figured out that my car is made in germany december 2019 and first time on road was august 2020
But if you have a right hand drive car, then it didn’t work properly as it’s reversed, therefore pointless.
