With SIRIUS there are the station logos in the preset button. Is this also posiible with DAB+?
Possible to see the navigation in IPC with CarPlay?
After a long struggle managed to download and make USB.
I am not sure if others facing issues with Automated method download and USB creation. Appears to be an issue with voice file 1.4GB from Azure edge. Rest came up without a drop.
Didn’t get a chance to drive longer than 30 minutes. System kept saying updating software and never completed.
I will try it tomorrow as I will be driving for good 4 hours.
I‘m in China, and my car is a Focus ST-Line (MK4) 2020 with package, and I can use the reformatting tools normally and give feedback. Thank you for your excellent tool! (Forgive me for the bad English. )
Perfect… English is good enough
Merry Christmas to all here greetings from Denmark
If you have an online account for SiriusXM you can go there and reset it and send a reset signal to your radio. Follow the directions on the website.
Read this thread, there are some resources that will show you what to check.
Yes, But it depends on the original region of manufacturer for the vehicle. It will probably be this:
7D0-01-02: #X##-####-####
Look at the Asbuilt Database for options.
I tried that several times and their “customer service” tried it from their end as well. I got sent to advanced tech support and their conclusion was it might me a radio issue and I should contact the dealer. I’m wondering if flashing the latest firmware might help.
which thread. I guess it will not possible
okay, which of this possibilities do u think I have to edit?
0 = USB2 Disabled, Navigation Disabled, Rear EFP Disabled
1 = USB2 Disabled, Navigation Disabled, Rear EFP Enabled
2 = USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
3 = USB2 Disabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
4 = USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
5 = USB2 Disabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
6 = Reserved
7 = Reserved
8 = USB2 Enabled, Navigation Disabled, Rear EFP Disabled
9 = USB2 Enabled, Navigation Disabled, Rear EFP Enabled
A = USB2 Enabled, Navigation Enabled (Telenav Common HMI), Rear EFP Disabled
B = USB2 Enabled, Navigation Enabled (Telenav Common HMI), Rear EFP Enabled
C = USB2 Enabled, Navigation Enabled (NNG External HMI), Rear EFP Disabled
D = USB2 Enabled, Navigation Enabled (NNG External HMI), Rear EFP Enabled
What means USB2?
What is your present value at that address using FORScan?
the present value it´s an A
Plz help!!!
Downloaded RoW version of 20282 and attempted updating 2019 EcoSport from 20136 to 20182…
No success even after an hour drive. Attempted master reset and again update…no change…just keeps saying updating software and no progress even after couple of hours drive.
Should I first jump to 20237? Or is it okay to jump directly to 20282.
One more question. Can I use NA version of update for a EcoSport in India??
All apps are the same version worldwide, meaning 3.4.20282 is one file for everyone.
If you have a NON-NAV unit, please read this thread:
Syn3 Updater 2.0 BETA TEST!
Good afternoon and HAPPY HOLIDAYS!
Will I be able to upgrade on my Mondeo 18, with 282?
Thank you very much.
Have you loaded EU maps on the 2014 Explorer? Is it still Sync 2 or has it been converted to Sync 3? If it has been converted, can you provide info on what Sync version it is on?
Yes you should be able to do so.
Looks like that is my problem, Below is the extract from xml:
ON-Line Diagnostic DB Reference Number: 5U5T-14G381-ED
ECU Core Assembly Number: H1BT-14G380-AB
ECU Delivery Assembly Number: JK2T-14G371-BCC
Vehicle Manufacturer ECU Software Number: GB5T-14G374-DG
<d2p1:PartitionHealth available=“54M” total=“1.7G” type="/fs/Nuance/"/>
<d2p1:PartitionHealth available=“1005M” total=“1.2G” type="/fs/rwdata/"/>
<d2p1:PartitionHealth available=“35M” total=“35M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“90M” total=“90M” type="/fs/rwdata/quip/"/>
<d2p1:PartitionHealth available=“142M” total=“1.4G” type="/fs/mp/"/>
<d2p1:PartitionHealth available=“380K” total=“74M” type="/fs/mp/resources"/>
<d2p1:PartitionHealth available=“1.1G” total=“3.0G” type="/fs/images/"/>
Please tell me: just extract the folder for Pen and put it in the car?
