Ok after a little bit of searching on mine the Ford Pass button takes you back to the Ford part of the system.
I have just updated to version 20351. I had decided to wait until the Ford system offered it officially, which finally happened today.
All went well at first glance and the bug where the radio looks like it’s on is finally fixed.
One question though:
I tried hitting the ā€œStationsā€ button which is supposed to show me all FM stations in the area and it kept loading forever. Is that a new bug with this version? I don’t recall having this issue before. I don’t use this button usually but I’m just wondering what’s wrong.
I should also note that I didn’t have the time to perform a master reset yet. If you guys think that will help I’ll give it a shot next time.
i downloaded today via ford website, all ok but no radio logos.
any ideas?
probably need to update your radio package
Cheers. So is that in the database?
Have you a link?
you will find what you need
However i assume you have updated APIM firmware?
…no…,
I’ve just followed the ford website instructions…
I was going to do an update from here but ford released it a few days ago…
So guys, does the stations button list the FM stations for you?
I have all stations… just no logo’s…
To clarify ā€œi assume you have updated APIM firmwareā€ is not ā€œdid you update your APIM firmwareā€ as your car is 2019 i assume you have updated APIM firmware, in which case you just need to potentially enable the radio logos in forscan and/or update the radio logo package.
It did me too, I did the factory settings and after a while maybe after turning off and starting the car it went without a problem.
how long does it take?
Tried again today and even after a master reset, the stations list button keeps loading forever (waited 5 minutes and nothing).
Not sure what’s going on as if I use the >> button it seeks stations just fine. Also presets work fine as does putting in an FM frequency manually.
Replaced my v3.0 non-Nav APIM with a new Nav APIM that came with Sync v3.4 19200. I was somewhat disappointed with the upgrade in regards to performance. Today, I upgraded to v3.4 20351. Performance much better. Didn’t notice any real interface changes between the two. Appreciate the tool provided here. Made the install process simple.
I have the same problem, what was the solution please
Ford Escape from 2018. Uploaded 3.4_20196 F9 map, can I safely upload 3.4_20251 F10 map? Everything works well ? I live in poland.
Do you still have a 32 GB APIM, US import car? Or did you change it?
I have 64GB
You should be fine then…
I have already created a flash drive, but I don’t know if it’s okay, can you see? I can put what and what looks like or log here.
