no, not really, is it causing issues if not just leave it
Agreed.
I’d assume performing a reformat would actually erase it along all other packages…
But why do it if no issues are present…
I have found in the 20351 if listing to music from usb drive that some times the music skip a sec like a cd that has a scrats or been shock
I don’t think this is exclusive to 3.4.20351. I have experienced this in previous builds as well and it happens with pretty much any audio source (Bluetooth, USB, etc). It seems that only radio is unaffected by it. I’ve learned to live with it as it only happens very seldom.
Hello!! I have the same issue. Did you finde whats is the problem? I will try with another cable and lets
see. I do not know if I will have to downgrade or wait to a new update.
I changed the cable, and it seems to be the issue (or solution :D). But, I will know for sure since I will drive tomorrow for an hour, and we will see will it be ok as it was on the shortest drives I had in the last few days.
I think it is fine since, with the old cable, the AA dropped every time in less than half an hour. I drove about 30 - 45 minutes once (with the new cable), and it was fine. So, I am going on a trip tomorrow for at least an hour, and I will see will it be ok. If it is, I think that will confirm it.
I did notice something in this build… I find about 90% when i get a text message, SYNC says i got like 3 and they’re old messages from months ago… Anyone notice this when they receive texts? I’m also connected BT. I never had this issue in any previous builds… Not really an issue, just more of an annoyance.
Decided what the heck and ran through the upgrade. Happy to report that all went smooth. Took about 31 minutes on a reformat. All of my Sync features are still there and so far haven’t found a need to do the Master Reset. Love the change. Glad I found this, the forum, and all the users who chime in.
Have you performed a master reset?
Also, make sure that on your phone there are no unread messages.
Hi, I had same problem with 20351and fixed the same as in previous versions. Unplugging the battery negative wire, waiting for 10 secs and plugging on. No problems since then. Have a great day
Following my comment about the Android Auto dripping, after I changed the cable for the phone, the issue has been resolved. Som, if anyone experienced the same, change your USB cable. :slight_smile:
On the website Ford for Puma website, I have an official update. Everything works fine. Even the live traffic function! Update ~ 885MB, 25min.
Version 20351 officially released by ford here today.
Great, good to know!
Thanks for sharing
Any ideas what this file relates to??
GB5T-14G386-AD
Yesterday :slight_smile:
According to the DB, it’s ā€œutloggingutilityā€, whatever it means…
You can check it in the database…
Hi everyone,
made the update yesterday. etherything works fine.
except the Voice/Command ā€œsearch adressā€. when I try this - software goes back to Home Screen.
What can I do???
Sorry for my bad english.
kr Peter
That is the newest revision of the APIM Interrogator Utility. The use is documented here:
This file creates the xml file to send to Ford.
