I beg the differ. Can you collect their calibration number of their apim? I think that is what is causing this now.
Ok guys I’m upgrading from 3.4.20282 to version 3.4.21098 should my install mode be at autoinstall and forced at yes? Also I’m getting a failed download error in some files.
The voice thing has been that way for the last few builds. The “please say a command” was removed back with one of the first 3.4 builds, I think the second one, 19200?
Thanks. Indeed, 3.0 to 3.4 is a big jump. Without the “please say a command” things gets faster.
No need to force any install method. You should leave it as “auto detect” and it will work if you entered your current configuration details correctly.
The failed downloads are likely problems on Ford’s server side and it’s a known issue. You can either keep trying and it should eventually work, or you can copy the URL, manually download the file, and place it inside the Syn3Updater folder. The app will scan that folder, verify file integrity and skip the download if it’s already there.
So when I did the auto detect the installation is at downgrade, and forced is at no, so that is correct ? ?
Did you choose to upgrade maps too? This will cause it to do a downgrade install on pre-MY20 vehicles as it is a faster process. This is expected and normal in that scenario.
Yes I did. Thanks for the info
It’s all clearly documented:
Hello
First time trying to use Syn3Updater for my 2019 F-150.
I’m on build 3.4.21020 with maps NA 118.
I would like to update to 3.4.21098 and 2020 Maps.
Can you let me know if I setup Syn3Updater right.
In car configuration advanced options I selected install mode: autodetect and release branch: stable. My 20 is toggle off by default, should I toggle it on?
Thank you
This is fine. You do not need MY20 protection.
CYANLABS - SYN3 UPDATER - V2.6.3.0
Version: 3.0.20204
Mode: reformat
My20 Protection Enabled: False
Model: Lexar USB Flash Drive USB Device 28.9GB
VOICE=5U5T-14G391-CN_1615429328000.TAR.GZ
VOICE_NAV=4U5T-14G422-CCH_1615429127000.TAR.GZ
VOICE_NAV=4U5T-14G422-CBH_1615429039000.TAR.GZ
VOICE_NAV=4U5T-14G422-CAH_1615428946000.TAR.GZ
MAP=4U5T-14G421-CJD_1615428865000.TAR.GZ
MAP=4U5T-14G421-CHD_1615428793000.TAR.GZ
MAP=4U5T-14G421-CGD_1615428721000.TAR.GZ
MAP=4U5T-14G421-CFD_1615428639000.TAR.GZ
MAP=4U5T-14G421-CED_1615428554000.TAR.GZ
MAP=4U5T-14G421-CDD_1615428467000.TAR.GZ
MAP=4U5T-14G421-CCD_1615428361000.TAR.GZ
MAP=4U5T-14G421-CBD_1615428261000.TAR.GZ
MAP=4U5T-14G421-CAD_1615428059000.TAR.GZ
MAP_LICENSE=4U5T-14G424-CD_1616778089000.TAR.GZ
; CyanLabs Syn3Updater 2.6.3.0 Stable - reformat Mode - Sync 3.4.21098 NA
FILES (17)
5U5T-14G391-CN_1615429328000.TAR.GZ (385.4MB)
4U5T-14G422-CCH_1615429127000.TAR.GZ (549.6MB)
4U5T-14G422-CBH_1615429039000.TAR.GZ (772.4MB)
4U5T-14G422-CAH_1615428946000.TAR.GZ (1.3GB)
4U5T-14G421-CJD_1615428865000.TAR.GZ (657.9MB)
4U5T-14G421-CHD_1615428793000.TAR.GZ (989.6MB)
4U5T-14G421-CGD_1615428721000.TAR.GZ (1.1GB)
4U5T-14G421-CFD_1615428639000.TAR.GZ (1GB)
4U5T-14G421-CED_1615428554000.TAR.GZ (1GB)
4U5T-14G421-CDD_1615428467000.TAR.GZ (1.2GB)
4U5T-14G421-CCD_1615428361000.TAR.GZ (1GB)
4U5T-14G421-CBD_1615428261000.TAR.GZ (1.1GB)
4U5T-14G421-CAD_1615428059000.TAR.GZ (1.1GB)
4U5T-14G424-CD_1616778089000.TAR.GZ (1.7KB)
[2021-05-28 9:10:55 AM] Selected Region: NA - Release: Sync 3.4.21098 - Map Version: 2.20 (2020) - NA
[2021-05-28 9:10:55 AM] Install Mode: reformat
[2021-05-28 9:10:55 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2021-05-28 9:10:55 AM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[2021-05-28 9:10:55 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2021-05-28 9:10:58 AM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[2021-05-28 9:10:58 AM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[2021-05-28 9:11:00 AM] Validated: 5U5T-14G391-CN_1615429328000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:00 AM] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[2021-05-28 9:11:03 AM] Validated: 5U5T-14G381-ES_1619042260000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:03 AM] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[2021-05-28 9:11:06 AM] Validated: 4U5T-14G422-CCH_1615429127000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:06 AM] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[2021-05-28 9:11:09 AM] Validated: 4U5T-14G422-CBH_1615429039000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:09 AM] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[2021-05-28 9:11:14 AM] Validated: 4U5T-14G422-CAH_1615428946000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:14 AM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2021-05-28 9:11:17 AM] Validated: 4U5T-14G421-CJD_1615428865000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:17 AM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2021-05-28 9:11:21 AM] Validated: 4U5T-14G421-CHD_1615428793000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:21 AM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2021-05-28 9:11:26 AM] Validated: 4U5T-14G421-CGD_1615428721000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:26 AM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2021-05-28 9:11:31 AM] Validated: 4U5T-14G421-CFD_1615428639000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:31 AM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2021-05-28 9:11:35 AM] Validated: 4U5T-14G421-CED_1615428554000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:35 AM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2021-05-28 9:11:40 AM] Validated: 4U5T-14G421-CDD_1615428467000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:40 AM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2021-05-28 9:11:45 AM] Validated: 4U5T-14G421-CCD_1615428361000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:45 AM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2021-05-28 9:11:49 AM] Validated: 4U5T-14G421-CBD_1615428261000.TAR.GZ (Skipping Download)
[2021-05-28 9:11:49 AM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 9:11:50 AM] Validate: 4U5T-14G421-CAD_1615428059000.TAR.GZ (Failed!, Downloading)
[2021-05-28 9:11:50 AM] Downloading: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 9:16:35 AM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 9:16:40 AM] Downloaded: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 9:16:40 AM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 9:16:40 AM] Downloading: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 9:16:40 AM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 9:16:40 AM] Downloaded: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 9:16:40 AM] Preparing USB drive
[2021-05-28 9:16:40 AM] Formatting USB drive
[2021-05-28 9:16:40 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[2021-05-28 9:16:48 AM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[2021-05-28 9:16:48 AM] Copying: 1u5t-14g386-cb.tar.gz
[2021-05-28 9:16:51 AM] Validating: 1u5t-14g386-cb.tar.gz
[2021-05-28 9:16:51 AM] Copied: 1u5t-14g386-cb.tar.gz
[2021-05-28 9:16:51 AM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2021-05-28 9:16:51 AM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2021-05-28 9:18:36 AM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2021-05-28 9:19:07 AM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[2021-05-28 9:19:07 AM] Checking Existing File: 5U5T-14G391-CN_1615429328000.TAR.GZ
[2021-05-28 9:19:07 AM] Copying: 5U5T-14G391-CN_1615429328000.TAR.GZ
[2021-05-28 9:20:11 AM] Validating: 5U5T-14G391-CN_1615429328000.TAR.GZ
[2021-05-28 9:20:32 AM] Copied: 5U5T-14G391-CN_1615429328000.TAR.GZ
[2021-05-28 9:20:32 AM] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[2021-05-28 9:20:32 AM] Copying: 5U5T-14G381-ES_1619042260000.TAR.GZ
[2021-05-28 9:23:00 AM] Validating: 5U5T-14G381-ES_1619042260000.TAR.GZ
[2021-05-28 9:23:43 AM] Copied: 5U5T-14G381-ES_1619042260000.TAR.GZ
[2021-05-28 9:23:43 AM] Checking Existing File: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[2021-05-28 9:23:43 AM] Copying: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[2021-05-28 9:25:17 AM] Validating: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[2021-05-28 9:25:47 AM] Copied: 4U5T-14G422-CCH_1615429127000.TAR.GZ
[2021-05-28 9:25:47 AM] Checking Existing File: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[2021-05-28 9:25:47 AM] Copying: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[2021-05-28 9:28:01 AM] Validating: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[2021-05-28 9:28:41 AM] Copied: 4U5T-14G422-CBH_1615429039000.TAR.GZ
[2021-05-28 9:28:41 AM] Checking Existing File: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[2021-05-28 9:28:41 AM] Copying: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[2021-05-28 9:32:27 AM] Validating: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[2021-05-28 9:33:44 AM] Copied: 4U5T-14G422-CAH_1615428946000.TAR.GZ
[2021-05-28 9:33:44 AM] Checking Existing File: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2021-05-28 9:33:44 AM] Copying: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2021-05-28 9:35:38 AM] Validating: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2021-05-28 9:36:13 AM] Copied: 4U5T-14G421-CJD_1615428865000.TAR.GZ
[2021-05-28 9:36:13 AM] Checking Existing File: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2021-05-28 9:36:13 AM] Copying: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2021-05-28 9:39:10 AM] Validating: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2021-05-28 9:40:04 AM] Copied: 4U5T-14G421-CHD_1615428793000.TAR.GZ
[2021-05-28 9:40:04 AM] Checking Existing File: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2021-05-28 9:40:04 AM] Copying: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2021-05-28 9:43:12 AM] Validating: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2021-05-28 9:44:13 AM] Copied: 4U5T-14G421-CGD_1615428721000.TAR.GZ
[2021-05-28 9:44:13 AM] Checking Existing File: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2021-05-28 9:44:13 AM] Copying: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2021-05-28 9:47:14 AM] Validating: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2021-05-28 9:48:13 AM] Copied: 4U5T-14G421-CFD_1615428639000.TAR.GZ
[2021-05-28 9:48:13 AM] Checking Existing File: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2021-05-28 9:48:13 AM] Copying: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2021-05-28 9:51:21 AM] Validating: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2021-05-28 9:52:20 AM] Copied: 4U5T-14G421-CED_1615428554000.TAR.GZ
[2021-05-28 9:52:20 AM] Checking Existing File: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2021-05-28 9:52:20 AM] Copying: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2021-05-28 9:56:05 AM] Validating: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2021-05-28 9:57:17 AM] Copied: 4U5T-14G421-CDD_1615428467000.TAR.GZ
[2021-05-28 9:57:17 AM] Checking Existing File: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2021-05-28 9:57:17 AM] Copying: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2021-05-28 10:00:22 AM] Validating: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2021-05-28 10:01:20 AM] Copied: 4U5T-14G421-CCD_1615428361000.TAR.GZ
[2021-05-28 10:01:20 AM] Checking Existing File: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2021-05-28 10:01:20 AM] Copying: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2021-05-28 10:04:37 AM] Validating: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2021-05-28 10:05:40 AM] Copied: 4U5T-14G421-CBD_1615428261000.TAR.GZ
[2021-05-28 10:05:40 AM] Checking Existing File: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 10:05:40 AM] Copying: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 10:08:48 AM] Validating: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 10:09:50 AM] Copied: 4U5T-14G421-CAD_1615428059000.TAR.GZ
[2021-05-28 10:09:50 AM] Checking Existing File: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 10:09:50 AM] Copying: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 10:09:50 AM] Validating: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 10:09:50 AM] Copied: 4U5T-14G424-CD_1616778089000.TAR.GZ
[2021-05-28 10:09:50 AM] Generating reformat.lst
[2021-05-28 10:09:50 AM] Generating autoinstall.lst
[2021-05-28 10:09:50 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Updated from 3.0 to 3.4.21098 on my 2016 Lincoln MKX. Only issues so far as I can tell is I no longer have the Lincoln animation on boot or power down. Shows up on hard reset (Power + seek forward) and after the install when powering down the screen would go dark but you could tell the backlight was still on and didnt power off as it usually does after time out. Reloaded my APIM asbuild backup with forscan and it seems to have corrected this, even though none of the coding had changed…who knows why this fixed it or maybe it just needed a few power cycles…? Does boot faster but I did like the animation, also the graphic wall paper was better on 3.0 but no big deal, I did know it would change. Other than this everything seems ok at the moment. I did encounter the same issue other had when trying to get the files through the updater where its says it was forced to close or whatever. Multiple attempts and it finally downloaded successfully.
Thank you for your feedback.
It looks like you got it sorted. Sometimes after this upgrade you have to reload the asbuilt like you did, this is not unusual, but is a good idea to do it anyways. The screen background can be manipulated in the 'Display" menu. There are some choices, but you might want to try selecting ‘night’ mode rather than ‘auto’ to see if you like that better.
Hi, you need to open the settings in cyanlabs tool and you need to follow the steps for creating the interrogator USB by going to settings
Once you complete step 3 on the right side of step 3 "open interrogator log, you will see the status of the memory version and the likes in pic 2
Pic
Hey guys
Nice update
But i have a problem with the navigation maps
It is not appearing and the NAV icon is not working also
Version: 3.4.21098
Mode: autoinstall
Model: USB Flash Memory USB Device 1.9GB
; CyanLabs Syn3Updater 2.6.3.0 Stable - Autoinstall Mode - Interrogator Log Utility
Item1 = TOOL - GB5T-14G386-AD_1606255780000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AD_1606255780000.TAR.GZ
FILES (1)
GB5T-14G386-AD_1606255780000.TAR.GZ (46.1KB)
[5/30/2021 1:56:02 AM] Selected Region: - Release: Interrogator Log Utility - Map Version:
[5/30/2021 1:56:02 AM] Install Mode: autoinstall
[5/30/2021 1:56:03 AM] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:04 AM] Downloading: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:05 AM] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:05 AM] Downloaded: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:06 AM] Preparing USB drive
[5/30/2021 1:56:06 AM] Formatting USB drive
[5/30/2021 1:56:06 AM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[5/30/2021 1:56:31 AM] Checking Existing File: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:31 AM] Copying: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:32 AM] Validating: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:32 AM] Copied: GB5T-14G386-AD_1606255780000.TAR.GZ
[5/30/2021 1:56:32 AM] Generating Autoinstall.lst
[5/30/2021 1:56:32 AM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Operating System: Microsoft Windows 10 Home (2004)
Version: 3.4.21098
Mode: autoinstall
FILES (1)
Version: 3.4.21098
Mode: autoinstall
FILES (1)
MY20 protection is to prevent the reformatting of 2020+ vehicles. If you have a 2020 or newer model year vehicle then you should enable it.
As for updating, you want to make sure that your “previous configuration” in the app reflects what is currently installed on your vehicle and NOT the version you wish to upgrade to.
