I was able to properly load the Updated (3.4 21098) to my SYNC 3 with no Issuesโฆ
Again Thank You for taking the time to read my post and pointing me in the right direction
Make the phone forget the car in the AA submenu. Then reconnect.
No one answer me
From here
Sorry for the delay. You need to post the log file from the usb/app and if you could please run the Interrogator Tool in the Syn3 Updater app. The pictures look like you have no maps loadedโฆ
sorry AA Sub menu? is this in general settings on sync and un link my phone? or is it something else, im new to all of this.
Quick Update:
I had originally upgraded to 21098 from 21020 and lost all Sirius including radio even after a Master Reset. Rolled back to 21020 and things were โsoft-ofโ fine. Still had issues with SiriusXM Link not recognizing my subscription. Sent a new signal and still nothing. I saw in another section to just do an Apps only upgrade with 21098 to fix the SiriusXM issue. That did fix the Sirius problem, but I still had to do another refresh after the Master Reset. Now my system recognizes my subscription and all of the associated services. It has been working for a couple days, so hopefully this will stick. Apologies if others have stated this and I missed it.
Thank you for the feedback on this issue.
In the phone. Either in the AA App or in the Settings/Advanced features AA menu.
CYANLABS - SYN3 UPDATER - V2.7.3.0
Operating System: โโMicrosoft Windows 10 Home (2009)
Version: 3.4.21098
Region: ROW
Install Mode: reformat
Install Mode Overridden: True
My20 Protection Enabled: False
Model: SanDisk Cruzer Blade USB Device
VOICE=5U5T-14G391-FP_1615431939000.TAR.GZ
MAP=4U5T-14G421-FAH_1598637879000.TAR.GZ
MAP_LICENSE=4U5T-14G424-FAH_1598638505000.TAR.GZ
; CyanLabs Syn3Updater 2.7.3.0 Stable - reformat FORCED Mode - Sync 3.4.21098 ROW
FILES (7)
5U5T-14G391-FP_1615431939000.TAR.GZ (1.4GB)
4U5T-14G421-FAH_1598637879000.TAR.GZ (4.9GB)
4U5T-14G424-FAH_1598638505000.TAR.GZ (1.7KB)
[20/10/42 04:26:15 ู
] Selected Region: ROW - Release: Sync 3.4.21098 - Map Version: 2019 Q4 - ROW (All)
] Install Mode: reformat Forced: True
] MY20 Protection: False
] Checking Existing File: 1u5t-14g386-cb.tar.gz
[20/10/42 04:26:16 ู
] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[20/10/42 04:26:18 ู
] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
] Checking Existing File: 4U5T-14G423-FC_1615431949000.TAR.GZ
[20/10/42 04:28:09 ู
] Validated: 4U5T-14G423-FC_1615431949000.TAR.GZ (Skipping Download)
] Checking Existing File: 5U5T-14G391-FP_1615431939000.TAR.GZ
[20/10/42 04:28:33 ู
] Validated: 5U5T-14G391-FP_1615431939000.TAR.GZ (Skipping Download)
] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[20/10/42 04:28:51 ู
] Validated: 5U5T-14G381-ES_1619042260000.TAR.GZ (Skipping Download)
] Checking Existing File: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[20/10/42 04:30:23 ู
] Validated: 4U5T-14G421-FAH_1598637879000.TAR.GZ (Skipping Download)
] Checking Existing File: 4U5T-14G424-FAH_1598638505000.TAR.GZ
] Validated: 4U5T-14G424-FAH_1598638505000.TAR.GZ (Skipping Download)
] Preparing USB drive
] Formatting USB drive
] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[20/10/42 04:30:39 ู
] Copying: 1u5t-14g386-cb.tar.gz
[20/10/42 04:30:40 ู
] Validating: 1u5t-14g386-cb.tar.gz
] Copied: 1u5t-14g386-cb.tar.gz
] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[20/10/42 04:30:46 ู
] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[20/10/42 04:30:47 ู
] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
] Copying: 4U5T-14G423-FC_1615431949000.TAR.GZ
[20/10/42 04:34:20 ู
] Validating: 4U5T-14G423-FC_1615431949000.TAR.GZ
[20/10/42 04:34:50 ู
] Copied: 4U5T-14G423-FC_1615431949000.TAR.GZ
] Copying: 5U5T-14G391-FP_1615431939000.TAR.GZ
[20/10/42 04:37:38 ู
] Validating: 5U5T-14G391-FP_1615431939000.TAR.GZ
[20/10/42 04:38:23 ู
] Copied: 5U5T-14G391-FP_1615431939000.TAR.GZ
] Copying: 5U5T-14G381-ES_1619042260000.TAR.GZ
[20/10/42 04:40:11 ู
] Validating: 5U5T-14G381-ES_1619042260000.TAR.GZ
[20/10/42 04:40:38 ู
] Copied: 5U5T-14G381-ES_1619042260000.TAR.GZ
] Copying: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[20/10/42 04:51:23 ู
] Validating: 4U5T-14G421-FAH_1598637879000.TAR.GZ
[20/10/42 04:54:03 ู
] Copied: 4U5T-14G421-FAH_1598637879000.TAR.GZ
] Copying: 4U5T-14G424-FAH_1598638505000.TAR.GZ
] Validating: 4U5T-14G424-FAH_1598638505000.TAR.GZ
] Copied: 4U5T-14G424-FAH_1598638505000.TAR.GZ
] Generating reformat.lst
] Generating autoinstall.lst
[20/10/42 04:54:04 ู
] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
From that log and the screens you showed before, I get the feeling you had a NA installation before, and now you installed ROW.
So my questions are: is the car imported?.
Did nav work before while it was 3.0?.
I had very similar problems with several different cables. Finally found one that worked for a long while (months, at least) but then it too started having problems. I was first using a Type C to Type C but had better results with a Type A to Type C.
I got it from the dealer
Version: 3.4.21098
Region: ROW
Install Mode: autoinstall
; CyanLabs Syn3Updater 2.7.3.0 Stable - Autoinstall FORCED Mode - Sync 3.4.21098 ROW
[SYNCGen3.0_3.0.1_PRODUCT]
Item1 = MAP_LICENSE - 4U5T-14G424-FAH_1598638505000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G424-FAH_1598638505000.TAR.GZ
Item2 = VOICE - 5U5T-14G391-FP_1615431939000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G391-FP_1615431939000.TAR.GZ
[SYNCGen3.0_3.0.1]
Item1 = MAP - 4U5T-14G421-FAH_1598637879000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G421-FAH_1598637879000.TAR.GZ
Item2 = ENH_DAB - 1U5T-14G658-AF_1598633324000.TAR.GZ
Open2 = SyncMyRide\1U5T-14G658-AF_1598633324000.TAR.GZ
Item1 = GRACENOTES - 4U5T-14G423-FC_1615431949000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-FC_1615431949000.TAR.GZ
Item2 = APPS - 5U5T-14G381-ES_1619042260000.TAR.GZ
Open2 = SyncMyRide\5U5T-14G381-ES_1619042260000.TAR.GZ
FILES (6)
[20/10/42 06:11:45 ู
] Install Mode: autoinstall Forced: True
[20/10/42 06:11:46 ู
[20/10/42 06:11:57 ู
[20/10/42 06:12:13 ู
[20/10/42 06:12:23 ู
[20/10/42 06:13:20 ู
[20/10/42 06:13:31 ู
[20/10/42 06:13:37 ู
[20/10/42 06:15:25 ู
[20/10/42 06:15:55 ู
[20/10/42 06:19:03 ู
[20/10/42 06:19:49 ู
[20/10/42 06:21:39 ู
[20/10/42 06:22:06 ู
[20/10/42 06:32:56 ู
[20/10/42 06:35:34 ู
] Generating Autoinstall.lst
[20/10/42 06:35:36 ู
second time installing
I asked 2 very simple questions, and I only got about half an answerโฆ
You demanded help before, Iโm trying to help you, but you are not providing basic information that Iโm asking.
So my willing to help is decreasing.
Maybe you should contact the dealer.
1- I donโt know if is it imported or not I got it from the dealer
2- yes it was running on version
