You have your previous configuration set as 3.4.21098 which isn’t correct and you are forcing reformat. This will not work. Set your previous configuration to your current version of sync and do not force an install mode. Let it auto detect.
Since one of the screens show that you had NA gracenotes, I feel the issue is that someone changed your car’s region…
Did you perform a master reset after upgrading to 3.4?
it was the cable, tried the wifes Iphone apple carplay worked like a charm, grabbed a new cable and all is well. Thank you for all the help.
Yes i did
In an earlier post, I stated the 21098 fixed the SiriusXM Travel Link subscription bug. While the problem seemed to be corrected with the upgrade, it came back again today. Only the Movie Listings would show as subscribed… Hopefully the next version will address this better. I’ve upgraded so many times now, I don’t know of a good build anymore…
You are forcing installation modes. Do not do this. The 2 previous logs posted showed forced installations and the options were not configured correctly.
The settings should be:
Version: 3.4.20282
Region: ROW
Install Mode: autodetect
My20 Protection Enabled: False
Since you are on 3.4.20282, you need to downgrade the APIM first to Sync 3.3.19052. The Syn3 Updater app will select this for you from the settings above. Once the unit downgrades to 3.3.19052, then the installation will use the reformat tool to wipe the previous versions and install the new Sync version and maps.
However, the navigation will not work correctly if the region information is not changed. This needs to be done in the APIM and ACM. See this tutorial for guidance.
Tutorial: EU Maps to US Car (3.4 Sync, F9 Maps) - Ford / Guides & Info - CyanLabs Official Community
Please note that CyanLabs does not support changing regions.
2019 F250
Previous 3.0.19205
16gb thumb drive
autoloaded 3.4.21098 and 2 20 maps without issue
Internet in the country isn’t the best. Download kept hanging when going through the updater software. Downloaded the last 3 files individually and then put them in the download folder and then re-ran the program and it validated everything. Took 28 minutes to install in the truck.
So far I haven’t come across any glitches.
help needed, ive downloaded the verson ( 21020 ) and f10 maps, after having problems downloading maps from ford ( same verson) Ive put the usb in, it did the first part of the update, and then it shut down to do the map update ( i think) and went onto your loading screen, and it errors, so i cant update it and i cant get to the home screen of the car, I dont know what to do now
Please post your log file from the Syn3 Updater app.
how do i do this
CYANLABS - SYN3 UPDATER - V2.7.3.0
Version: 3.4.21020
Install Mode: downgrade
Mode: Directory
Path: E:\New folder\
VOICE=5U5T-14G391-AN_1615393794000.TAR.GZ
APPS=5U5T-14G381-ER_1615427592000.TAR.GZ
; CyanLabs Syn3Updater 2.7.3.0 Stable - downgrade Mode - Sync 3.4.21020 EU
FILES (21)
1U5T-14G421-BAH_1615430310000.TAR.GZ (2.2GB)
1U5T-14G421-BBH_1615430406000.TAR.GZ (473.7MB)
1U5T-14G421-BCH_1615430471000.TAR.GZ (1.7GB)
1U5T-14G421-BDH_1615430533000.TAR.GZ (1.1GB)
1U5T-14G421-BEH_1615430614000.TAR.GZ (1.6GB)
1U5T-14G421-BFH_1615432204000.TAR.GZ (2.4GB)
1U5T-14G421-BHH_1615430859000.TAR.GZ (2.6GB)
1U5T-14G421-BJH_1615431074000.TAR.GZ (23.9MB)
1U5T-14G424-BK_1616682400000.TAR.GZ (1.7KB)
4U5T-14G422-BAF_1615431156000.TAR.GZ (2.3GB)
4U5T-14G422-BBF_1615431222000.TAR.GZ (2.2GB)
4U5T-14G422-BCF_1615431448000.TAR.GZ (1.6GB)
5U5T-14G381-ER_1615427592000.TAR.GZ (847.1MB)
5U5T-14G391-AN_1615393794000.TAR.GZ (1.5GB)
[02/06/2021 08:50:54] Selected Region: EU - Release: Sync 3.4.21020 - Map Version: F10 (2020) - EU (03 2021)
[02/06/2021 08:50:54] Install Mode: downgrade Forced: False
[02/06/2021 08:50:54] MY20 Protection: False
[02/06/2021 08:50:54] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 08:50:54] Downloading: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 08:51:35] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 08:51:36] Downloaded: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 08:51:36] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 08:51:36] Downloading: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 08:51:37] Validating: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 08:51:37] Downloaded: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 08:51:37] Checking Existing File: 1u5t-14g386-cb.tar.gz
[02/06/2021 08:51:37] Downloading: 1u5t-14g386-cb.tar.gz
[02/06/2021 08:51:39] Validating: 1u5t-14g386-cb.tar.gz
[02/06/2021 08:51:39] Downloaded: 1u5t-14g386-cb.tar.gz
[02/06/2021 08:51:39] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 08:51:39] Downloading: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 08:54:22] Validating: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 08:54:26] Downloaded: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 08:54:26] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[02/06/2021 08:54:26] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[02/06/2021 08:54:26] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 08:54:26] Downloading: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 08:55:38] Validating: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 08:55:41] Downloaded: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 08:55:41] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 08:55:41] Downloading: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 08:56:35] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 08:56:37] Downloaded: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 08:56:37] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[02/06/2021 08:56:42] Validated: 1U5T-14G421-BGH_1615430797000.TAR.GZ (Skipping Download)
[02/06/2021 08:56:42] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[02/06/2021 08:56:43] Validated: 1U5T-14G421-BBH_1615430406000.TAR.GZ (Skipping Download)
[02/06/2021 08:56:43] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[02/06/2021 08:56:43] Validated: 1U5T-14G421-BJH_1615431074000.TAR.GZ (Skipping Download)
[02/06/2021 08:56:43] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[02/06/2021 08:56:50] Validated: 1U5T-14G421-BHH_1615430859000.TAR.GZ (Skipping Download)
[02/06/2021 08:56:50] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 08:56:55] Validate: 1U5T-14G421-BFH_1615432204000.TAR.GZ (Failed!, Downloading)
[02/06/2021 08:56:55] Downloading: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:00:19] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:00:25] Downloaded: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:00:25] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:00:25] Downloading: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:02:49] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:02:53] Downloaded: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:02:53] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:02:53] Downloading: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:04:19] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:04:22] Downloaded: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:04:22] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:04:22] Downloading: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:06:48] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:06:53] Downloaded: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:06:53] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:06:53] Downloading: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:09:57] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:10:03] Downloaded: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:10:03] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:10:03] Downloading: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:10:03] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:10:03] Downloaded: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:10:03] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:10:03] Downloading: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:12:59] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:13:05] Downloaded: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:13:05] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:13:05] Downloading: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:15:29] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:15:33] Downloaded: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:15:33] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:15:33] Downloading: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:19:04] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:19:09] Downloaded: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:19:09] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:19:09] Downloading: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:22:34] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:22:40] Downloaded: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:22:40] Preparing selected directory (No USB Drive Selected)
[02/06/2021 09:22:40] Clearing Selected Folder
[02/06/2021 09:22:40] Checking Existing File: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 09:22:40] Copying: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 09:22:46] Validating: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 09:22:55] Copied: 4U5T-14G381-AN_1552583626000.TAR.GZ
[02/06/2021 09:22:55] Checking Existing File: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 09:22:55] Copying: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 09:22:55] Validating: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 09:22:55] Copied: GB5T-14G386-SC_85041.tar.gz
[02/06/2021 09:22:55] Checking Existing File: 1u5t-14g386-cb.tar.gz
[02/06/2021 09:22:55] Copying: 1u5t-14g386-cb.tar.gz
[02/06/2021 09:22:56] Validating: 1u5t-14g386-cb.tar.gz
[02/06/2021 09:22:56] Copied: 1u5t-14g386-cb.tar.gz
[02/06/2021 09:22:56] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 09:22:56] Copying: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 09:23:17] Validating: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 09:23:51] Copied: 5U5T-14G391-AN_1615393794000.TAR.GZ
[02/06/2021 09:23:51] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[02/06/2021 09:23:51] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[02/06/2021 09:23:51] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[02/06/2021 09:23:51] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[02/06/2021 09:23:51] Checking Existing File: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 09:23:51] Copying: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 09:23:59] Validating: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 09:24:15] Copied: 5U5T-14G381-ER_1615427592000.TAR.GZ
[02/06/2021 09:24:15] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 09:24:15] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 09:24:20] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 09:24:34] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[02/06/2021 09:24:34] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[02/06/2021 09:24:34] Copying: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[02/06/2021 09:24:57] Validating: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[02/06/2021 09:25:28] Copied: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[02/06/2021 09:25:28] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[02/06/2021 09:25:28] Copying: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[02/06/2021 09:25:31] Validating: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[02/06/2021 09:25:32] Copied: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[02/06/2021 09:25:32] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[02/06/2021 09:25:32] Copying: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[02/06/2021 09:25:33] Validating: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[02/06/2021 09:25:33] Copied: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[02/06/2021 09:25:33] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[02/06/2021 09:25:33] Copying: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[02/06/2021 09:26:09] Validating: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[02/06/2021 09:26:58] Copied: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[02/06/2021 09:26:58] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:26:58] Copying: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:27:23] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:28:04] Copied: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[02/06/2021 09:28:04] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:28:04] Copying: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:28:20] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:28:47] Copied: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[02/06/2021 09:28:47] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:28:47] Copying: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:28:56] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:29:17] Copied: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[02/06/2021 09:29:17] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:29:17] Copying: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:29:36] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:30:17] Copied: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[02/06/2021 09:30:17] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:30:17] Copying: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:30:42] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:31:20] Copied: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[02/06/2021 09:31:20] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:31:20] Copying: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:31:20] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:31:20] Copied: 1U5T-14G424-BK_1616682400000.TAR.GZ
[02/06/2021 09:31:20] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:31:20] Copying: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:31:40] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:32:10] Copied: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[02/06/2021 09:32:10] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:32:10] Copying: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:32:26] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:32:50] Copied: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[02/06/2021 09:32:50] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:32:50] Copying: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:33:12] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:33:51] Copied: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[02/06/2021 09:33:51] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:33:51] Copying: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:34:21] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:35:09] Copied: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[02/06/2021 09:35:09] Generating reformat.lst
[02/06/2021 09:35:09] Generating autoinstall.lst
[02/06/2021 09:35:09] ALL FILES DOWNLOADED AND COPIED TO THE SELECTED FOLDER SUCCESSFULLY!
You should insert the USB again (eventually a different disk that you have recreated in the app). It should start installing again.
As I do not use Android Auto, I am not sure of the AA app removal. I have confirmed that Webex is still working for me in the “Apps” section of SYNC 3 thru SDL. If it does not appear there, there’s a problem on your end.
If it’s related to Android Auto is not related to the SYNC version
Glad to see this thread has stayed on topic… NOT!
@CyanLabs question for you regarding profile settings, I am wanting to upgrade to 21098 from 21020.
What should install mode be set to, by default it is set to autoinstall but some above have said it needs to be autodetect?
Installed on Focus MY2019. No issue, except for the traffic info when connected to FordPass.
When linked, if I try to go under nav menu → traffic info it freeze all so I force to use a reset with two radio button.
