haha okay. We’ll figure it out on the fly then ![]()
With the appropriate license loaded on the system and autoinstall file, yes, they can be loaded later. See the NA Maps Voice file installation in the NA maps tutorial for the procedure.
Thank you very much. I know about the offer… of the v/ commitment and to know. I tried only to pass the maps, but it didn’t let… I had to do the whole package. Is it correct?. Because I had already done the update.
Once again, thank you very much.
It is best to reformat to install the maps…
I mean; do everything. Right? Big hug.
Just installed new version and NA 2021 maps. It shows 2.21 NA for the maps on SYNC 3. Everything worked smoothly, as expected. I drove five minutes and GPS was fine, signal locked. Will be driving few hours tomorrow. I’ll see for any issues. Thanks again mate! ![]()
Yes, if you are asking about the reformat.
Stop replying here, i split your post to a new topic.
Excellent thanks for the info on the version
I have a US 2020 Escape. I updated my Maps last year using this software but don’t recall a reformat step. I don’t remember a NA license issue. Was that part of the procedure last year?
The NA license has now been found but unfortunately is ESN locked so reformat for non my20 is the only option
Hi, do you recon the aftermarket camera problem been sorted for this new version
I remember your posts. DO NOT REFORMAT your MY20 system.
Unknown if the aftermarket camera issue was addressed.
EDIT: Responses indicate it was not.
i just wanted to be 150% clear before proceeding, im currently running 3.4.22048, in order to update, i need to make this a reformat type install? and i noticed the file batch did not include a license file thats ok? im in NA, not my20.
Correct
and comparing it to your screen on the beginning of this post, mine says forced? yes. otherwise it matches what you had on the screenshot on your post expect i have my usb drive plugged in and selected.
It shouldn’t say forced unless you have overridden the install mode post some screenshots
i had to override them because the install mode was registering as a downgrade not a reformat
