As far as the flickering goes, there seems to be zero change on my C-Max in that behavior. Definitely has not improved any at the very least.
As far as the auto-dim toggle, at minimum a couple of us C-Max owners have been able to confirm having an updated APIM calibration (My H series is on the -DA level calibration if memory serves? I’d have to load up Forscan again to check.) brings it back. May or may not be the same on the other affected vehicles.
SiriusXM station icons no longer disappear in the preset row upon a restart. Before they would be text-only until actually listening to a station. Now the logos are present before even listening to a station.
does this version still have the same USB song skip(sometimes at the end of a song it will skip the next song ie: end of song 1 skips 2 goes to 3) and song hiccup(1 or 2 seconds of the song get cut several times while listening) problems as all the other versions?
these problems are the reason why I can’t get any version over 19101 although I still get the song skip issue with this version.
19052 doesn’t have these issues but it has an issue seeing the USB drive when starting the car so 19101 is a happy medium.
I updated to the latest version 22251, and I noticed that the information subtitles, for example radio , gps and others read more sofft, or I will be seeing it wrong. Among other indications of pairing between the cell phone.
After update 22251 i found in my sync3.4 with navi eu and bang olufsen and dab radio that usb playback has a lot of problem like jumping and make noise and “digital noise” so it is a big problem in this version. I have make master reset and battei off to make system reboot and also forscan reset for the audio system.
The center navigation between the Speedo dials doesn’t show roundabouts if they have multiple exits. Also other roundabout symbols show the wrong direction.
