I’ve created usb flash with only nav voices using syn3updater (autoinstall method) and it doesn’t work either, same error.
Not one of you have posted a log or even the contents of a autoinstall.lst file so i can continue to guess all day…
Version NU5T-14G381-AC
APIM model: 5U5T-14G371-GMD
APIM type: Navigation
APIM size: 64GB
APIM freespace: 10G
Partition Type = Free / Total
/fs/sd/MAP/ = 804K / 1.2G
/fs/sd/MAP/ = 15M / 2.9G
/fs/sd/MAP/ = 14M / 2.4G
/fs/sd/MAP/ = 7.6M / 1.5G
/fs/sd/MAP/ = 17M / 2.3G
/fs/sd/MAP/ = 21M / 3.8G
/fs/sd/MAP/ = 308K / 40M
/fs/sd/MAP/ = 4.5M / 3.3G
/fs/sd/MAP/ = 26M / 3.2G
/fs/Nuance/ = 27M / 4.6G
/fs/Nuance/ = 29M / 4.8G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 907M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 85M / 90M
/fs/mp/ = 84M / 1.4G
/fs/mp/resources = 332K / 72M
/fs/images/ = 10G / 54G
Installed Packages
1U5T-14G421-BAK
1U5T-14G421-BBK
1U5T-14G421-BCK
1U5T-14G421-BDK
1U5T-14G421-BEK
1U5T-14G421-BFK
1U5T-14G421-BGK
1U5T-14G421-BHK
1U5T-14G421-BJK
1U5T-14G658-AH
4U5T-14G422-BAH
4U5T-14G422-BBH
4U5T-14G422-BCH
4U5T-14G422-BDH
4U5T-14G423-AC
5U5T-14G391-AT
1U5T-14G424-BM
Autoinstall.lst from Ford package:
[SYNCGen3.0_3.4.23088]
Item1 = 4U5T-14G422-BAK
Open1 = SyncMyRide\4U5T-14G422-BAK.tar.gz
Item2 = 4U5T-14G422-BBK
Open2 = SyncMyRide\4U5T-14G422-BBK.tar.gz
Item3 = 4U5T-14G422-BCK
Open3 = SyncMyRide\4U5T-14G422-BCK.tar.gz
Item4 = 4U5T-14G422-BDK
Open4 = SyncMyRide\4U5T-14G422-BDK.tar.gz
Item1 = GB5T-14G386-AD
Open1 = SyncMyRide\GB5T-14G386-AD.tar.gz
Item2 = LU5T-14G386-CA
Open2 = SyncMyRide\LU5T-14G386-CA.tar.gz
Autoinstall.lst created using Syn3updater:
Item1 = VOICE_NAV - 4U5T-14G422-BAK_1682464728000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BAK_1682464728000.TAR.GZ
Item2 = VOICE_NAV - 4U5T-14G422-BBK_1682464776000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G422-BBK_1682464776000.TAR.GZ
Item3 = VOICE_NAV - 4U5T-14G422-BCK_1682464838000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G422-BCK_1682464838000.TAR.GZ
Item4 = VOICE_NAV - 4U5T-14G422-BDK_1682464885000.TAR.GZ
Open4 = SyncMyRide\4U5T-14G422-BDK_1682464885000.TAR.GZ
Thanks, so yeah nothing is wrong here,
MEM_ERR01 – Error is MEM_NOSPACE_TO_COPY
So either do less packages at once, which might work, or reformat. not an issue on my end!
Autoinstall files are basically identical, the 2 packages above are
- a autoinstall.lst rename to autoinstall.bak
- interrogator log.
Yes, I know. I don’t blame syn3updater. A bit weird, that 10GB is not enough space. Before updating to F12 maps, I had 11G free space. I cannot do reformat (MY20), so there is probably no way to do a proper update.
Do 1 or 2 of the 4 files at a time…
I upgraded to 3.4.23088 on both my 2016 F150 and my wife’s 2019 Escape. I’m having to do frequent soft resets on both vehicles to recognize plugged in iPhones. Rarely if ever had to do this on previous builds. Anyone else?
Did you do a master reset?
Obviously that will clear your phones and then you can try pairing them again.
Updated from 22251 to 23088 and 2.22 NA maps today. 2016 Edge. Master reset after install. Zero problems so far
5 posts were split to a new topic: AM missing
@JacquesA try with this autoinstall options. This morning it worked for me. When possible I will check if the new files have been written. The problem is that isn’t possible to installa all 4 files in one single block (not enough space on APIM)
; SYNC3 Assembly Upgrade - Voice_Map F12 Release 3.2.23088_PRODUCT - Only for Nav/EU assemblies.
[SYNCGen3.0_3.4.23088_PRODUCT]
Item1 = 4U5T-14G422-BBK
Open1 = SyncMyRide\4U5T-14G422-BBK.tar.gz
Item2 = 4U5T-14G422-BCK
Open2 = SyncMyRide\4U5T-14G422-BCK.tar.gz
Item1 = 4U5T-14G422-BDK
Open1 = SyncMyRide\4U5T-14G422-BDK.tar.gz
Thx, will try! But this is all weird, that 10G freespace is not enough, when whole F12 map installation worked just fine :-/
Same for me
This works! All new nav voice packages installed and log uploaded to ford, no new updates now.
perfect.
Hallelujah! The speak and spell bug is gone!
Is anyone having troubles with gps signal with this version on retrofitted Sync3 systems? I mean we are using no oem gps antena.
I did some others retrofit and no oem antena works ok, maybe respone time is lower than oem, but it works. I am supposing that with this version 23088 gps signal is lost easily and we need to reset apim to get signal again, even changing the location of antenna do not help.
I am asking, not assuring that there is an error, because the version works ok in oem systems.
The trouble with no nav systems still present, maybe some relation with my problem. I will downgrade to 21194 and see what happen.
Car: Ford Ranger 2017 with sync2 upgraded to sync3.
Regards
This has always been a issue, use a genuine antenna for best performance, also note that there is antenna location configuration in asbuilt for the APIM
I have currently 3.4.22110 and F11.
Also have fmods.net like overclock, video and camera on demand installed mods.
In note says “Does JB works? YES” but, I am not sure, sorry if already asked ![]()
If update to 3.4.23088 will it keep all my fmods installed or I should do maps update only (really do not want to install all mods from scratch again)?
Just FYI - Ford has consistently not done the autoinstalls for the NAV Voice files correctly, which ends up in the memory errors. I have outlined this in several tutorials and posts before. Splitting the installation into 2 separate instances usually solves the issue for both EU and NA file sets. If you have already installed the F12 package, you will not need to include the license.
