Two Step Installation for Sync 3.0 Versions (2.3 thru 3.0) from Sync 3.0 Early Versions (1.0 thru 2.1) Maintaining CarPlay.
NOTES:
- This process does not use the reformat tool and is safe for MY20+ Service Replacement APIM’s.
- This tutorial does NOT apply to upgrading to Sync 3.2+ as that process utilizes the reformat tool.
- This tutorial is targeted for Ford and Lincoln vehicles originally equipped with Sync 3.0 with or without factory navigation. DO NOT attempt to place maps on a NON-NAV Sync APIM.
- Run the APIM Interrogator Utility to determine the specifics of your Sync APIM installed in your vehicle. This can be done thru the Syn3 Updater or manually following the tutorial, Tutorial: APIM Interrogator Utility - CyanLabs.
- It is recommended using a USB 3.0 drive with at least 32 GB of storage.
- This installation may consist of multiple reboots, in which the vehicle ignition must remain on throughout the process. DO NOT REMOVE THE USB UNTIL THE ENTIRE PROCESS HAS COMPLETED.
- A ‘Master Reset’ will be performed at the end of this procedure.
- This procedure does NOT include installation of maps on NAV APIM’s. This is only the Sync app installations. Map installations require they be downloaded from Ford - Sync3 Map Update to obtain the map license as the maps are ESN locked for NA.
Overview
If you have updated your Sync 3.0 NA NAV or NON-NAV APIM to Sync 3.0.20204 (or recent Sync 3.0 version) and do not have Apple CarPlay, despite having upgraded the USB hub, it is likely due to an incorrect Sync installation. The Ford released upgrade for Sync 3.0 does not include the installation of Sync 2.2.17011 which was the first production version to include Apple CarPlay. It is assumed by Ford that the upgrades would be accomplished in a step basis which would naturally include the installation of upgrades thru the Sync 3.0 lifespan. In theory this is the ideal method, however, this is the real world. This issue can be corrected using the procedures in this tutorial.
This tutorial covers the installation of Sync 2.2.17011 and Sync 3.0.20204 or 23219 with the associated Sync Voice and Gracenote files maintaining the Apple CarPlay feature. This will be accomplished in two separate steps, regardless of the Sync version presently installed on the APIM.
Sync Apps Package USB Preparation Instructions for NAV APIM
Install Sync 2.2.17011 then move on to install Sync 3.0.20204 or 23219.
Sync 2.2.17011 NA Apps Package Installation for NAV APIM
- Download the required files. The files can be downloaded from the Software Database - CyanLabs.
Sync App: HN1T-14G381-SA_64817.TAR.GZ
Sync System Voice: HN1T-14G391-CC_57609.TAR.GZ
Gracenote: HN1T-14G423-CA_57608.TAR.GZ
Interrogator Utility: GB5T-14G386-AB_134244.TAR.GZ
NOTE: Gracenote is optional, but the entry in the autoinstall.lst file must be removed if Gracenote will not be installed.
- Format a 32GB USB for ExFAT/MBR using Windows. Place the files on the USB drive.
a. Open the Downloads folder on the computer used to download the files.
b. Select the files and transfer them to the USB under the SyncMyRide folder.
c. In the root of the USB, place file DONTINDX.MSA. This is a blank text file with an MSA extension to prevent indexing by the Sync system. This can be used from previous installations if you have one. This file is optional. - Create the autoinstall.lst file.
a. In a plain text editor, like notepad, create a file named “autoinstall.lst”. Make sure there is not a .TXT extension, this must be a .LST extension.
b. Copy and paste (as plain text) the following text into the autoinstall.lst file and save the file.
; SYNC3 Consumer Assembly Upgrade — Only for Nav/NA assemblies.
[SYNCGen3.0_2.2.17011_PRODUCT]
Item1 = HN1T-14G381-SA_64817.TAR.GZ
Open1 = SyncMyRide\HN1T-14G381-SA_64817.TAR.GZ
Item2 = HN1T-14G391-CC_57609.TAR.GZ
Open2 = SyncMyRide\HN1T-14G391-CC_57609.TAR.GZ
Item3 = HN1T-14G423-CA_57608.TAR.GZ
Open3 = SyncMyRide\HN1T-14G423-CA_57608.TAR.GZ
Item1 = GB5T-14G386-AB_134244.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AB_134244.TAR.GZ
- Copy the file to the root of the USB.
- The file structure for the USB should now be like this:
USB (root)
autoinstall.lst
DONTINDX. MSA (optional)
SyncMyRide (folder)HN1T-14G381-SA_64817.TAR.GZ
Sync 3.0.20204/23219 NA Apps Package Installation for NAV APIM
NOTE: The procedure shows the installation of Sync 3.0.20204. For the installation of version 23219, replace:
JR3T-14G381-AX_1599788486000.TAR.GZ
with
JR3T-14G381-AY_1695755892000.TAR.GZ.
Sync App: JR3T-14G381-AX_1599788486000.TAR.GZ
Sync System Voice: JR3T-14G391-CE_1557247163000.TAR.GZ
Gracenote: JR3T-14G423-CB_1548263512000.TAR.GZ
Interrogator Utility: GB5T-14G386-AC_1587495565000.TAR.GZ
[SYNCGen3.0_3.0.20204_PRODUCT]
Item1 = JR3T-14G381-AX_1599788486000.TAR.GZ
Open1 = SyncMyRide\JR3T-14G381-AX_1599788486000.TAR.GZ
Item2 = JR3T-14G391-CE_1557247163000.TAR.GZ
Open2 = SyncMyRide\JR3T-14G391-CE_1557247163000.TAR.GZ
Item3 = JR3T-14G423-CB_1548263512000.TAR.GZ
Open3 = SyncMyRide\JR3T-14G423-CB_1548263512000.TAR.GZ
Item1 = GB5T-14G386-AC_1587495565000.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-AC_1587495565000.TAR.GZ
USB (root)
autoinstall.lst
SyncMyRide (folder)JR3T-14G381-AX_1599788486000.TAR.GZ
Sync Apps Package USB Preparation Instructions for NON-NAV APIM
Sync 2.2.17011 NA Apps Package Installation for NON-NAV APIM
Gracenote Removal: GB5T-14G386-SC_85041.TAR.GZ
; SYNC3 Consumer Assembly Upgrade — Only for NonNav/NonEU assemblies.
Item1 = GB5T-14G386-SC_85041.TAR.GZ
Open1 = SyncMyRide\GB5T-14G386-SC_85041.TAR.GZ
[SYNCGen3.0_2.2.17011]
Item1 = HN1T-14G381-SA_64817.tar.gz
Open1 = SyncMyRide\HN1T-14G381-SA_64817.tar.gz
Item2 = HN1T-14G423-CA_57608.TAR.GZ
Open2 = SyncMyRide\HN1T-14G423-CA_57608.TAR.GZ
[SYNCGen3.0_ ALL]
USB (root)
autoinstall.lst
Sync 3.0.20204/23219 NA Apps Package Installation for NON-NAV APIM
with
[SYNCGen3.0_3.0.20204]
Item2 = JR3T-14G423-CB_1548263512000.TAR.GZ
Open2 = SyncMyRide\JR3T-14G423-CB_1548263512000.TAR.GZ
[SYNCGen3.0_ ALL]
USB (root)
autoinstall.lst
Sync Apps Package Installation Instructions
NOTE: This installation consists of at least 2 reboots, in which the vehicle ignition must remain on throughout the process. DO NOT REMOVE THE USB UNTIL THE ENTIRE PROCESS HAS COMPLETED.
- Insert the USB in the vehicle, the “Updating Software” message will appear. Once the software has been installed, the system will display a Key Cycle or Reboot message. DO NOT interfere with the process, the APIM will reboot on its own and continue the installation. Be patient and wait.
- Once the second reboot has completed, the “Updating Software” message will appear again. This is running the Interrogator Utility, which should be quick. Once this is completed, the system will display an “Installation Complete” message. It is safe to remove the USB.
Master Reset Required
Once the Sync system seems stable and the maps are loaded, perform a ‘Master Reset’. This is not optional. Once the reset is finished and the system has rebooted, you can now re-pair your phones and make other adjustments.
