2020 North America Edge ST NA 2.20 Map Installation
i think so. whateever the cyan utility puts in.
OK, it’s CN.
3rd reboot… 36 mins after 2nd… shutting down car… will post pic in a sec. great news coming!!!
Let it reboot and process the loading of the NAV stuff completely before you do a master reset if needed.
I turn off the car, open the door, then shut, and left the USB in. Start up the car and after about a minute it says remove USB. Sorry was too excited to take a pic
Congratulations. Looks like it worked just fine. I say we have a winner!
Log before reload of apps, gracenotes and voice… im hungry. lol
Version: 5U5T-14G381-ER
APIM Model: 5U5T-14G371-CKC
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 5.3G
4/7/2021 1:44:27 AM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 13M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.8M / 937M
/fs/sd/MAP/ = 8.5M / 1.3G
/fs/sd/MAP/ = 14M / 1.7G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 7.2M / 1.4G
/fs/Nuance/ = 16M / 1.6G
/fs/Nuance/ = 10M / 1.1G
/fs/Nuance/ = 25M / 2.6G
/fs/Nuance/ = 940K / 244M
/fs/rwdata/ = 763M / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 80M / 90M
/fs/mp/ = 133M / 1.4G
/fs/images/ = 5.3G / 25G
reboot after apps, gracenotes, and voice complete. will get logs in a sec
Take a break. Tomorrow (well later today) I’ll write up a tutorial and include the info from all this. I’ll send it to you to proof. I’ll roll up this part of the thread into a new thread…
Minus GN, the storage use is spot on. Once you load up the GN and make it all current, just post the log.
im already running it. lol
Time to eat! Apps reload with gracenotes and voice. My guess. No need to remove gracenotes and install small voice to make this work.
APIM Size: 32GB
APIM Free Space: 5.1G
4/7/2021 1:57:33 AM +00:00
/fs/Nuance/ = 3.0M / 465M
/fs/rwdata/ = 756M / 1.2G
/fs/rwdata/quip/ = 33M / 35M
/fs/images/ = 5.1G / 25G
I see you reloaded the NA System Voice, 465M. It looks like you had the Chinese (CN) voice installed, 244M. It has English voice in it.
GN install should bring it to about 4.3GB free. I don’t see it installed. (/fs/Nuance/grace/)
I agree, no need to remove gracenotes and install small voice to make this work.
S*! Do I need to load another file! Lol And I totally recommend a factory reset.
You need to load the GN file.
Tutorial: No Gracenotes After Sync 3.4 Installation. Manual Installation Instructions - Ford / Guides & Info - CyanLabs Official Community
Always Master Reset!
@MKFlyers2K ,
This looks really good. Thanks for working on this and your help.
I’m pretty much done for tonight. I’ll catch up tomorrow. I have some work to do during the day but I’ll be free in the evening again.
@avdonr ,
Read thru the thread and bring up any caution points for the tutorial if you would, please.
Thank you
Read through it, and honestly there isn’t much that I think needs to be cautioned. This process is essentially a very long AutoInstall with some reboots.
I’d just make a strong note about the reboots and the length of time required for the entire process to complete. Navigation units should have no issues with space so the process should complete if the USB is properly created (which it should be if the flow is added to the updater app).
Thank you. I am going to include a timeline with the pics about the reboots and actions.
1st reboot about 22 minutes.
2nd reboot about 26 minutes.
3rd reboot about 36 minutes.
After 3rd reboot, the Installation Complete message appears.
Sounds good. I guess this would all just be specific to NA. More testing would probably need to be done to create the same workflow for other regions.
I have the scripting for the F9 package, from that I’m sure it can be modified for F10. That install is really long…but only 2 reboots.
I was able to get the latest gracenotes back in. Ill upload log when i get to my car. Ill see if I can find SIriusXM forum.
OK, after gracenotes load. Everything look good? Missing anything?
APIM Size: 32GB
APIM Free Space: 4.3G
4/7/2021 2:50:02 PM +00:00
/fs/Nuance/grace = 5.5M / 777M
/fs/rwdata/ = 771M / 1.2G
/fs/rwdata/quip/ = 84M / 90M
/fs/images/ = 4.3G / 25G
