This was caused by the theme, if it was set to MY20 it would work if it was set to Ford Timeless (i think) it would show the Ford logo instead
:laughing: much better indeed
Is it not having Gracenotes for ROW Non Map version? Thnks.
4U5T-14G423-FB 919Mb Sync3 v3.3.20178 1.1.1.2220 (GL-0011) (24.05.2020): ROW (4)
Ford APIM IVSU Database - CyanLabs
Means it is to be updated seperately after updating 20351?
You could, yes.
Follow this:
Tutorial: No Gracenotes After Sync 3.4 Installation. Manual Installation Instructions - Ford / Guides & Info - CyanLabs Official Community
Followed the tutorial. Was having 1.1 Gb of space left but could not install gracenotes file of 741 Mb after last update of 3.4.20282. Let me try this time but to install latest update again I have to downgrade.
Downgrade to 3.3.19052 using the Syn3 Updater and use reformat option to install the app, voice, and Gracenotes at one time.
I can confirm, it shows the ST animation on my ST.
This exactly why we don’t include Gracenotes for ROW as most don’t have space for it.
Should I try after downgrading then reformating with 3.4.20351 ROW Non Navigation package with Gracenotes included in the Syncmyride folder. Thnx.
you can try it probably won’t work but it might.
Can anyone confirm that the volume indicator is still square (3.4) versus round (3.0) ?
Also, does disconnect of Android Auto put the stereo into mute/audio off? I needed to know if the new update corrects old issues I am having with the previous version. Can those be corrected with ForScan?
Honestly you can have either by adjusting the asbuilt settings with FORScan, but by default they are round.
I have not seen that issue with the newer software.
Hi i have sync 3.4 20196 with gracenote 1.1.1.1322 ROW
IF I UPDATE to 3.4.20351 does it come with gracenote not .or can i update gracenote i only need new version 1.1.1.2220
Since I have a 2021 Bronco Sport with special Bronco animation, I wonder… by upgrading to this, would I lose that Bronco animation? I’d hate to screw something like that up LOL
I dont think so, since the vehicles that used to have the ST badge lost it when upgrading to 3.4, but since you have the bronco sport from the factory with the animation with 3.4, you shouldn’t lose it.
Just upgraded my SYNC to 3.4.20351. Took about 40 minutes… No issues… Master Reset. Works like a charm! NAV does seem a tad faster. Thank you CyanLabs!
You will not loose the animations. That is still in the new version. If it does loose it, you could set it back with FORScan.
Thank you for the feedback, @Psihawk
