May I ask how to solve this problem?
Hello - I have Sync 3.4.22251. Voice commands donāt work for music. Message āSync is downloading information from your deviceāā¦or message is ādonāt understand commandā. I am using applicable commands. Even more irritating I also have to confirm all basic Sync settings every time I start my truck.
F150 2019 (April) NA with maps
Not sure of previous Sync version - I have auto-update active.
Iāve tried soft re-set, hard re-set and factory re-set, no change. I tried the Cyan Labs Autoinstall USB option, no change. I would like to try the Cyan Labs reformat option but I am unsure how to determine if I have MY20 or not. Per Cyan Lab instructions I ran the Interrogator Log. Info as follows:
Version NU5T-14G381-AB
APIM Model: KU5T-14G371-CDF
APIM Type: Navigation
APIM Size: 32GB
APIM Free Space: 4.3G
4/22/2023 9:11:27 AM +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 12M / 1.5G
/fs/sd/MAP/ = 12M / 1.4G
/fs/sd/MAP/ = 10M / 1.4G
/fs/sd/MAP/ = 2.9M / 951M
/fs/sd/MAP/ = 8.6M / 1.3G
/fs/sd/MAP/ = 14M / 1.8G
/fs/sd/MAP/ = 17M / 1.7G
/fs/sd/MAP/ = 6.7M / 1.4G
/fs/Nuance/ = 9.9M / 1.6G
/fs/Nuance/ = 6.4M / 1.1G
/fs/Nuance/ = 24M / 2.5G
/fs/Nuance/ = 3.2M / 465M
/fs/rwdata/ = 0 / 1.2G
/fs/rwdata/quip/ = 35M / 35M
/fs/rwdata/quip/ = 88M / 90M
/fs/mp/ = 84M / 1.4G
/fs/images/ = 4.3G / 25G
Installed Packages
4U5T-14G422-CBC
4U5T-14G421-CHE
4U5T-14G421-CBE
4U5T-14G422-CAK
4U5T-14G421-CCE
4U5T-14G421-CGE
4U5T-14G421-CDE
4U5T-14G423-CC
4U5T-14G421-CAE
4U5T-14G422-CCC
5U5T-14G391-CS
4U5T-14G421-CFE
4U5T-14G421-CJE
4U5T-14G421-CEE
4U5T-14G424-CE
APIM AsBuilt
DE00: 2A2A000600022904048A
DE01: 55530103C002409080004005
DE02: 0000010100
DE03: 000014030E0001
DE04: 1A681A6838A4
DE05: B0
DE06: 40003300000000029A000056568800C8
I hope this is the information that you need. Is the reformat option recommended?
Thanks
Hello there.
This is a problem thatās been recently reported/noticed, thereās no space left for that partition.
Go and read these threads ā Version 22251 Issues Arising? & Some APIM Settings Going Back to Default.
Itās yet to be determined if this issue affects 22251 or other builds as well.
But basically, ideally, you need to reformat the unit if possible.
Review the quoted thread, if you have any feedback or questions about it, post them there.
Thanks for the reply. I had searched the threads but I had missed the one that you linked.
It does seem that the reformat is the next logical step and I am assuming that I donāt have MY20 as my truck was built in April 2019. I donāt want to ābrickā the APIM, is there a way to definitely determine if MY20 is present?
Yep, to unmount the unit and check the manufacture date on the APIM and screenās part number.
Syn3updater will also help you determine if itās MY20 or not with a high level of accuracy, but itās not 100% certain. Sync3updater will say that based on your APIM model KU5T-14G371-CDF, itās not MY20, so you should be ok.
Thanks.
I ran the reformat function and within 30 seconds of the software update starting I received āInstallation Failed Error Code PKG_ERR04ā. SYNC appears to be functioning no different now than before - no worse off due to the error but not any better. Suggestions?
Download Log
Version: 3.4.22251
Install Mode Overridden: True
Model: SanDisk Ultra USB Device
; CyanLabs Syn3Updater 2.11.8.0 Stable - reformat FORCED Mode - Sync 3.4.22251 NA
FILES (4)
[4/23/2023 1:40:48 PM] Selected Region: NA - Release: Sync 3.4.22251 - Map Version: Keep Existing Maps
[4/23/2023 1:40:48 PM] Install Mode: reformat (reformat) Forced: True
[4/23/2023 1:40:48 PM] MY20 Protection: Disabled / Not MY20
[4/23/2023 1:40:48 PM] Formatting USB drive
[4/23/2023 1:40:48 PM] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[4/23/2023 1:40:58 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[4/23/2023 1:40:59 PM] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[4/23/2023 1:40:59 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/23/2023 1:41:03 PM] Validated: 5U5T-14G391-CS_1660783942000.TAR.GZ (Skipping Download)
[4/23/2023 1:41:03 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/23/2023 1:41:09 PM] Validated: 4U5T-14G423-CC_1615429225000.TAR.GZ (Skipping Download)
[4/23/2023 1:41:09 PM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/23/2023 1:41:29 PM] Validated: NU5T-14G381-AB_1665525837000.TAR.GZ (Skipping Download)
[4/23/2023 1:41:29 PM] Preparing USB drive
[4/23/2023 1:41:29 PM] Checking Existing File: 1u5t-14g386-cb.tar.gz
[4/23/2023 1:41:29 PM] Copying: 1u5t-14g386-cb.tar.gz
[4/23/2023 1:41:33 PM] Validating: 1u5t-14g386-cb.tar.gz
[4/23/2023 1:41:33 PM] Copied: 1u5t-14g386-cb.tar.gz
[4/23/2023 1:41:33 PM] Checking Existing File: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/23/2023 1:41:33 PM] Copying: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/23/2023 1:41:46 PM] Validating: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/23/2023 1:41:49 PM] Copied: 5U5T-14G391-CS_1660783942000.TAR.GZ
[4/23/2023 1:41:49 PM] Checking Existing File: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/23/2023 1:41:49 PM] Copying: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/23/2023 1:42:07 PM] Validating: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/23/2023 1:42:12 PM] Copied: 4U5T-14G423-CC_1615429225000.TAR.GZ
[4/23/2023 1:42:12 PM] Checking Existing File: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/23/2023 1:42:12 PM] Copying: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/23/2023 1:42:39 PM] Validating: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/23/2023 1:42:46 PM] Copied: NU5T-14G381-AB_1665525837000.TAR.GZ
[4/23/2023 1:42:46 PM] Generating reformat.lst
[4/23/2023 1:42:46 PM] Generating autoinstall.lst
[4/23/2023 1:42:46 PM] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
From Interrogater Log:
APIM Size: 32GB
4/23/2023 2:01:37 PM +00:00
/fs/rwdata/ = 121M / 1.2G
/fs/rwdata/quip/ = 90M / 90M
Installed Packages
4U5T-14G422-CBC
4U5T-14G421-CHE
4U5T-14G421-CBE
4U5T-14G422-CAK
4U5T-14G421-CCE
4U5T-14G421-CGE
4U5T-14G421-CDE
4U5T-14G423-CC
4U5T-14G421-CAE
4U5T-14G422-CCC
5U5T-14G391-CS
4U5T-14G421-CFE
4U5T-14G421-CJE
4U5T-14G421-CEE
4U5T-14G424-CE
APIM AsBuilt
DE02: 0000010100
DE04: 1A681A6838A4
DE05: B0
This is not the place for these kind of questions.
Do not force things if you do not what you are doing.
That will never work.
If you have issues after correcting that, read the documentation or post on the referenced threads, or create a new one.
I have already told you that:
Hello all,
I used the updater to update to this latest build and everything is working great except for one bug. I saw it mentioned in the beginning of the the thread with Carplay, but same thing is happening with Android Auto. Pressing the phone icon does not launch the Android Auto phone āsystemā like in older versions, it just brings you to the Sync 3 phone screen. Pressing the maps icon launches google maps like always and all other Android Auto functions appear to work. When a phone call is incoming, it wonāt answer until I select the Android Auto icon and then I can answer it.
The last few days Iāve been having issues with version 22251. Radio starts up with English language and starts up on AM like itās done a little reset of some sort. My language is Danish. Have done a master reset and removed the battery poles for 5 minutes without success. It also freezes at times and makes a blue screen and restarts. Others experiencing this and have a solution
Have had it successfully installed since release and currently have map F11 installed
@Jan_Christensen , check the threads linked in the Community Spotted Issues on the 1st message
Now Iām not very geeky so whatās the solution? Do I have to go to Ford with the car or what can I do myself? has a paying forscan program as well as the real OBD2 if it is to be used for this⦠I am really tired of it and dare not try to update it again as it might freeze
Just read, the solution is on the threads Iāve quoted.
Yes, and there are hundreds of posts and I canāt make sense of what they all write. Something with reformat, but I canāt use that because mine is a MY20. I would not have asked for help if I had understood everything they wrote. Maybe you should make a guide to what you can do instead of forcing someone to read through a hundred posts
Iām sorry, are you paying CyanLabs for support?.
Or all what you are getting is for free and under your own responsibility?.
If you want some kind of āsilver platterā service I would advice paying a fee to a local āguruā or Ford Service representative, then you would be entitled to make requirements or demands. It would not be free, right?, but someone else will fix it for you.
If you do not care about spending some time researching in order to fix your issue, then you can be sure I canāt care less about you fixing your issue. The fact you didnāt read the very first message, where a ātutorialā is found for troubleshooting this issue, tells me you do not really want to spend time on this⦠and of course neither do Iā¦
Take care and good luck.
Would you like to commission this guide? yeah i didnāt think so⦠CyanLabs is free, if you canāt be bothered to read thats not our problem.
That said, if anyone wants to constructively suggest what CyanLabs should work on please post here ![]()
I apologize many times. I didnāt see there was a 3rd link in what he shared. found only the two links where the problem was discussed. As I said Iām not that good at software but more hardware man⦠once again sorry, got it to work by doing 3 soft resets by holding down the 2 buttons on sync and then doing a master reset and then downgrading to 22200ā¦
