Trying to revert from Sync 3.0.20204 to 2.2.17011
Hi,
I recently purchased this 2016 Ford Fiesta ST and the previous owner updated the software to 3.0.20204, unsure with what method, but he was not able to get Android Auto or Carplay to work.
Now I am taking a shot at it and am running into some issues.
I initially plugged in my phone with a known working data USB 3.0 to USB C cable. While my Pixel 10 Pro is able to switch to charging only/File transfer/Android auto etc, etc I get no response from the headunit
And then I came upon this post 2016 Mustang Sync3 1.0 updated to 3.0 and no Apple Carplay! - #10 by SaNdMaN by Sandman describing a similar issue I am having and have tried following those steps to revert back to 2.2.17011 and I get the “Updating System Software…” message to pop up and wait for over 10 minutes and nothing else happens.
The red activity LED on the usb stick initially turns on but turns off after a while.
Maybe the previous owner fitted a new USB hub that is faulty?
I also read about a reformat tool? Do I need to put that on the USB stick?
I wanted to use the Syn3 updater tool, but after entering in my details, the only option is to go up in version, I don’t see an option to go down.
I did see a Create Downgrade USB tool, but the description didn’t fit my situation
I have the LST file set to what Sandman posted, SyncMyRide folder with the 2.2 zip file in it, there’s a couple extra files from the Syn3 tool, log text file and DONTINDX.MSA file. USB drive is formatted to EXFAT and is MBR. Not sure what else I could be doing wrong.
Thanks in advance
Old SYNC Version: 3.0.20204
New SYNC Version: 3.0.20204
Hello.
There’s absolutely no way of knowing what the previous owner did, so one thing you should confirm right now is if the hub the car has is the required one. You can check it here → Media Hub, CarPlay Compatible - 2015-2020 Ford/Lincoln - SYNC 3
Disclaimer: upgrading the HUB might not be necessary for Android Auto to work.
Now, try running the interrogator log against the unit and share the produced XML file (redact the VIN from the file’s title and content if you care about it).
So I pulled the hub out and found that the part number is HC3T-14F014-BE does not seem to be on that list of Apple Carplay compatible hubs, but shouldn’t be necessary since I’m using an Android phone.
I tried using the interrogator log utility but I had the same issue, “Updating System Software…” would pop up, red blinky light on the USB stick would eventually go out, and nothing happens after 5 minutes of waiting.
Any advice?
Have you master reset?, does it work?.
performed a master reset
still same result
Well, if the unit can’t process a single package then there’s no solution for your current predicament.
Other than trying with a different usb pendrive or port, I’m already running out of ideas.
another thing to add is even before trying to do anything with updating, I would randomly receive error messages like “USB device not recognized, please remove” with nothing at all plugged into the USB ports
and just now I was trying to run the interrogator again and got another error message like “USB hubs are not supported, please remove”
cool, I hadn’t see this thread yet but it describes what I think is happening to my car, the software being updated to 3.0.xxx without having first been updated to 2.0.xxx
I’ve prepared the USB drive and will try tomorrow and if that doesn’t work I have ordered USB hub HC3Z-19A387-F and maybe that will do something
One question, when I do try it tomorrow, how long from initially inserting the USB drive and the “Updating System Software…” message should something else happen. From the videos I’ve watched on the process, usually it takes less than a minute for the screen to switch over to a green loading bar screen. After how much time should I concede that the updating process isn’t working.
Thanks again Sandman and F150Chief
Good, I was going to recommend that.
It depends on what the USB is for, but the interrogator log should take “a few” seconds, well under a minute.
Nope, plugged in the thumb drive and left it alone for over 10 minutes, this is the screen it stayed on and the LED on the thumb drive stopped blinking. Here are all the files and such I have on the thumb drive and a picture of the screen that the car is stuck on.
Next step will be to install the new USB hub when it gets here and I’ll even try a different USB stick
so I tried to update to 2.2 on the 22nd and didn’t think the update worked so I pulled the usb stick and left the car alone for a few days.
then on the 27th, went for a drive and saw a notification pop up on the head unit saying system updated and I check the software version changed to 2.2
So I guess the update worked? I tried plugging in my android phone into the usb hub with a random cable I knew supported data but no Android Auto. Tried clicking around my phone, the headunit, enabled phone apps, etc etc, nothing
Now I’ve ordered a nicer USB C to USB A 3.1 cable and maybe that does something?
Still waiting on the hub to arrive, will try the cable when it gets here, maybe I need to try to update back up to 3.0.20204?
Will update
Still no progress
Ordered and tried a new USB-A 3.1 to USB-C cable
Ordered and tried 2 different HC3Z-19A387-F USB modules, which both turned out to be same as the one that I already have (HC3T-14F014-BE) due to that being the “part number” which is different than the “engineering number”
When I plugged in the new USB hubs I am still getting the “This USB device is not supported. Please remove.” error message. This is with just the USB hub, nothing plugged in to the hub.
Do I try to update to Sync3 version 3 anyways even though Android auto isn’t working with the current version 2.2?
Is it possible there is a bad connection somewhere?
I am considering a nuclear option of just purchasing an entirely new APIM with 3.4 preinstalled, that would HAVE to fix whatever is wrong right??
Where did you get to on this? Is it resolved?
No this is not resolved, I am still having issues and haven’t touched the car since my last post
So you were able to downgrade the unit to Sync 3 ver 2.2.17011. The HC3Z-19A387-F hub is correct as long as it is a good working hub. Use a USB 3.0 cable and install the new hub. Update to Sync 3.0.23219 with the appropriate voice files, etc.
[SYNCGen3.0_3.0.23219_PRODUCT]
Item1 = JR3T-14G381-AY_1695755892000.TAR.GZ.
Open1 = SyncMyRide\JR3T-14G381-AY_1695755892000.TAR.GZ
Item2 = JR3T-14G391-CE_1557247163000.TAR.GZ
Open2 = SyncMyRide\JR3T-14G391-CE_1557247163000.TAR.GZ
Item3 = JR3T-14G423-CB_1548263512000.TAR.GZ
Open3 = SyncMyRide\JR3T-14G423-CB_1548263512000.TAR.GZ
Do you still have maps on the unit? If so, what version?
Hello, I’m dealing with this same thing. I’d like to add android auto back on my truck after accidentally deleting it, then updating. I’m not sure how to acquire the interrogator log either? Any help would be greatly appreciated
You don’t have to install AA, it is a function in the Sync app. If you connect your Android phone and grant permission to use AA it should appear.
Yea but it’s not showing up on the screen or working at all. I updated the app on the phone and tried seceral cables. The icon used to even be on there but I deleted it an update or so back… now Im jumping in the rabbit hole again
Also, when I plug in the USB to charge/connect, it’s pulses. What does that indicate?
