Sorry for the stupid question.
You mean this
OR this
Hi again
Succesfully did the downgrade from 3.4.20196 to 3.3.19052.
Everything works fine.
At this point do you think I have to do all the incremental upgrades one by one up to 3.4.20196 or do you think I may do only some of them which according to your opinion are milestone subversions? (may be for example 3.4.19274 and then 20136?)
In the mean time my new About SYnc screen follows:
but by google search among others I found the following screen as the 3.3 About Sync screen:
Do you think my 3.3 About Sync screen shows something wrong?
Since 3.4.19200 and 19274 seem to be very stable versions, use one of those to upgrade at this point. I expect everything should work fine. Upgrade the voice file and app together always. (Not the NAV Voice, the System Voice.) The table below shows NA files.
|Sync OS Version||Voice Version|
|Sync File|-->|Voice File|
3.3.19052 3.2.19049
4U5T-14G381-AN --> 4U5T-14G391-CJ
3.4.19101 3.2.18241
5U5T-14G381-AP --> 5U5T-14G391-CB
3.4.19200 3.2.19164
5U5T-14G381-CD --> 5U5T-14G391-CH
3.4.19274 3.2.19258
5U5T-14G381-CJ --> 5U5T-14G391-CK
3.4.20021 3.2.19345
5U5T-14G381-EB --> 5U5T-14G391-CL
3.4.20136 3.2.19345
5U5T-14G381-ED --> 5U5T-14G391-CL (No new release)
3.4.20196 3.2.20142
5U5T-14G381-EG --> 5U5T-14G391-CM
Your screen looks fine. One pic is Ford Classic, the other is another theme but in night mode. These can be changed with FORScan.
Ford APIM (Accessory Protocol Interface Module) AsBuilt Database – CyanLabs
Go to the above and select themes.
Looks good.
5U5T-14G391-AK would be the right voice file for EU. Sorry, my chart is for US files.
5U5T-14G391-AK 1.5Gb Sync3 v3.2.19258
-AK is for the following countries:
ARW,CZC,DAD,DUN,ENG,FIF,FRF,GED,ITI,NON,PLP,PTP,RUR,SPE,SWS,TRT
Upgrade from 3.3.19052 to 3.4.19274 was fine!
All navigation voice commands working now.
Many thanks for your great support!
PS In the mean time I talked to 3 other friends being in 3.4.20196 and they have the same problem as me (they can not set any destination by using navi voice commands). They get the same response (“Navigation is still loading - Try again later”). Seems to me it may be a 20196 bug…
In case I upgrade to a higher version and want to go back again to 19274 can I do it directly using SynUpdater or do I have to go back to 3.3. again?
You can go directly back to 3.4.19274 as long as you do not need to use the reformat tool for new maps. In that case, it would be required to go back earlier than 19200, so we encourage 3.3.19052 because it frees up extra space for upgrades to work properly.
You can go direct from where you are forward and backwards as long as it is just app updates/changes.
Glad you got it all sorted. It’s nice when it works right. I think there might be an installation bug based on order of package installation or maybe a storage space issue related to that. Yours worked, so share that with them.
Again many thanks for your support! Really appreciate!
The next upgrade will be a milestone because it will reveal if 3.4.20196 has this bug with voice navi or not.
In any case I will post the results and keep you informed.
Many thanks again!
In the mean time do you have any idea re. this question:
I commented on the other thread, but I don’t have experience with this since I live in the US.
Having the same issue, after upgrading from 3.0 to 3.4.21098 navigation voice commands come up with “not ready yet”
this is the log file
CYANLABS - SYN3 UPDATER - V2.7.3.0
Version: 3,0,20204
Install Mode: reformat
My20 Protection Enabled: False
VOICE=5U5T-14G391-AN_1615393794000.TAR.GZ
; CyanLabs Syn3Updater 2.7.3.0 Stable - reformat Mode - Sync 3.4.21098 EU
FILES (19)
1u5t-14g386-cb.tar.gz (8,5MB)
1U5T-14G658-AF_1598633324000.TAR.GZ (58,8MB)
5U5T-14G391-AN_1615393794000.TAR.GZ (1,5GB)
5U5T-14G381-ES_1619042260000.TAR.GZ (847,2MB)
4U5T-14G422-BCF_1615431448000.TAR.GZ (1,6GB)
4U5T-14G422-BBF_1615431222000.TAR.GZ (2,2GB)
4U5T-14G422-BAF_1615431156000.TAR.GZ (2,3GB)
[4/6/2021 9:51:46 μμ] Selected Region: EU - Release: Sync 3.4.21098 - Map Version: F10 (2020) - EU (03 2021)
[4/6/2021 9:51:46 μμ] Install Mode: reformat Forced: False
[4/6/2021 9:51:46 μμ] MY20 Protection: False
[4/6/2021 9:51:46 μμ] Checking Existing File: 1u5t-14g386-cb.tar.gz
[4/6/2021 9:51:46 μμ] Validated: 1u5t-14g386-cb.tar.gz (Skipping Download)
[4/6/2021 9:51:46 μμ] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[4/6/2021 9:51:46 μμ] Validated: 1U5T-14G658-AF_1598633324000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:46 μμ] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[4/6/2021 9:51:48 μμ] Validated: 4U5T-14G423-AC_1615425645000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:48 μμ] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[4/6/2021 9:51:51 μμ] Validated: 5U5T-14G391-AN_1615393794000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:51 μμ] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[4/6/2021 9:51:53 μμ] Validated: 5U5T-14G381-ES_1619042260000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:53 μμ] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[4/6/2021 9:51:58 μμ] Validated: 1U5T-14G421-BGH_1615430797000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:58 μμ] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[4/6/2021 9:51:59 μμ] Validated: 1U5T-14G421-BBH_1615430406000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:59 μμ] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[4/6/2021 9:51:59 μμ] Validated: 1U5T-14G421-BJH_1615431074000.TAR.GZ (Skipping Download)
[4/6/2021 9:51:59 μμ] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[4/6/2021 9:52:05 μμ] Validated: 1U5T-14G421-BHH_1615430859000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:05 μμ] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[4/6/2021 9:52:10 μμ] Validated: 1U5T-14G421-BFH_1615432204000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:10 μμ] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[4/6/2021 9:52:14 μμ] Validated: 1U5T-14G421-BEH_1615430614000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:14 μμ] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[4/6/2021 9:52:17 μμ] Validated: 1U5T-14G421-BDH_1615430533000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:17 μμ] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[4/6/2021 9:52:21 μμ] Validated: 1U5T-14G421-BCH_1615430471000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:21 μμ] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[4/6/2021 9:52:26 μμ] Validated: 1U5T-14G421-BAH_1615430310000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:26 μμ] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[4/6/2021 9:52:26 μμ] Validated: 1U5T-14G424-BK_1616682400000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:26 μμ] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[4/6/2021 9:52:30 μμ] Validated: 4U5T-14G422-BDF_1615431510000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:30 μμ] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[4/6/2021 9:52:34 μμ] Validated: 4U5T-14G422-BCF_1615431448000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:34 μμ] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[4/6/2021 9:52:39 μμ] Validated: 4U5T-14G422-BBF_1615431222000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:39 μμ] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[4/6/2021 9:52:44 μμ] Validated: 4U5T-14G422-BAF_1615431156000.TAR.GZ (Skipping Download)
[4/6/2021 9:52:44 μμ] Preparing USB drive
[4/6/2021 9:52:44 μμ] Formatting USB drive
[4/6/2021 9:52:44 μμ] Re-creating partition table as MBR and formatting as ExFat on selected USB drive
[4/6/2021 9:52:52 μμ] Checking Existing File: 1u5t-14g386-cb.tar.gz
[4/6/2021 9:52:52 μμ] Copying: 1u5t-14g386-cb.tar.gz
[4/6/2021 9:52:52 μμ] Validating: 1u5t-14g386-cb.tar.gz
[4/6/2021 9:52:52 μμ] Copied: 1u5t-14g386-cb.tar.gz
[4/6/2021 9:52:52 μμ] Checking Existing File: 1U5T-14G658-AF_1598633324000.TAR.GZ
[4/6/2021 9:52:52 μμ] Copying: 1U5T-14G658-AF_1598633324000.TAR.GZ
[4/6/2021 9:53:00 μμ] Validating: 1U5T-14G658-AF_1598633324000.TAR.GZ
[4/6/2021 9:53:01 μμ] Copied: 1U5T-14G658-AF_1598633324000.TAR.GZ
[4/6/2021 9:53:01 μμ] Checking Existing File: 4U5T-14G423-AC_1615425645000.TAR.GZ
[4/6/2021 9:53:01 μμ] Copying: 4U5T-14G423-AC_1615425645000.TAR.GZ
[4/6/2021 9:54:37 μμ] Validating: 4U5T-14G423-AC_1615425645000.TAR.GZ
[4/6/2021 9:55:09 μμ] Copied: 4U5T-14G423-AC_1615425645000.TAR.GZ
[4/6/2021 9:55:09 μμ] Checking Existing File: 5U5T-14G391-AN_1615393794000.TAR.GZ
[4/6/2021 9:55:09 μμ] Copying: 5U5T-14G391-AN_1615393794000.TAR.GZ
[4/6/2021 9:58:47 μμ] Validating: 5U5T-14G391-AN_1615393794000.TAR.GZ
[4/6/2021 10:00:02 μμ] Copied: 5U5T-14G391-AN_1615393794000.TAR.GZ
[4/6/2021 10:00:02 μμ] Checking Existing File: 5U5T-14G381-ES_1619042260000.TAR.GZ
[4/6/2021 10:00:02 μμ] Copying: 5U5T-14G381-ES_1619042260000.TAR.GZ
[4/6/2021 10:01:58 μμ] Validating: 5U5T-14G381-ES_1619042260000.TAR.GZ
[4/6/2021 10:02:38 μμ] Copied: 5U5T-14G381-ES_1619042260000.TAR.GZ
[4/6/2021 10:02:38 μμ] Checking Existing File: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[4/6/2021 10:02:38 μμ] Copying: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[4/6/2021 10:07:11 μμ] Validating: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[4/6/2021 10:08:46 μμ] Copied: 1U5T-14G421-BGH_1615430797000.TAR.GZ
[4/6/2021 10:08:46 μμ] Checking Existing File: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[4/6/2021 10:08:46 μμ] Copying: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[4/6/2021 10:09:51 μμ] Validating: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[4/6/2021 10:10:13 μμ] Copied: 1U5T-14G421-BBH_1615430406000.TAR.GZ
[4/6/2021 10:10:13 μμ] Checking Existing File: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[4/6/2021 10:10:13 μμ] Copying: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[4/6/2021 10:10:16 μμ] Validating: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[4/6/2021 10:10:17 μμ] Copied: 1U5T-14G421-BJH_1615431074000.TAR.GZ
[4/6/2021 10:10:17 μμ] Checking Existing File: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[4/6/2021 10:10:17 μμ] Copying: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[4/6/2021 10:16:19 μμ] Validating: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[4/6/2021 10:18:24 μμ] Copied: 1U5T-14G421-BHH_1615430859000.TAR.GZ
[4/6/2021 10:18:24 μμ] Checking Existing File: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[4/6/2021 10:18:24 μμ] Copying: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[4/6/2021 10:24:04 μμ] Validating: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[4/6/2021 10:26:00 μμ] Copied: 1U5T-14G421-BFH_1615432204000.TAR.GZ
[4/6/2021 10:26:00 μμ] Checking Existing File: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[4/6/2021 10:26:00 μμ] Copying: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[4/6/2021 10:29:48 μμ] Validating: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[4/6/2021 10:31:07 μμ] Copied: 1U5T-14G421-BEH_1615430614000.TAR.GZ
[4/6/2021 10:31:07 μμ] Checking Existing File: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[4/6/2021 10:31:07 μμ] Copying: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[4/6/2021 10:33:37 μμ] Validating: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[4/6/2021 10:34:28 μμ] Copied: 1U5T-14G421-BDH_1615430533000.TAR.GZ
[4/6/2021 10:34:28 μμ] Checking Existing File: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[4/6/2021 10:34:28 μμ] Copying: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[4/6/2021 10:38:25 μμ] Validating: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[4/6/2021 10:39:47 μμ] Copied: 1U5T-14G421-BCH_1615430471000.TAR.GZ
[4/6/2021 10:39:47 μμ] Checking Existing File: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[4/6/2021 10:39:47 μμ] Copying: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[4/6/2021 10:45:00 μμ] Validating: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[4/6/2021 10:46:47 μμ] Copied: 1U5T-14G421-BAH_1615430310000.TAR.GZ
[4/6/2021 10:46:47 μμ] Checking Existing File: 1U5T-14G424-BK_1616682400000.TAR.GZ
[4/6/2021 10:46:47 μμ] Copying: 1U5T-14G424-BK_1616682400000.TAR.GZ
[4/6/2021 10:46:47 μμ] Validating: 1U5T-14G424-BK_1616682400000.TAR.GZ
[4/6/2021 10:46:47 μμ] Copied: 1U5T-14G424-BK_1616682400000.TAR.GZ
[4/6/2021 10:46:47 μμ] Checking Existing File: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[4/6/2021 10:46:47 μμ] Copying: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[4/6/2021 10:51:29 μμ] Validating: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[4/6/2021 10:53:04 μμ] Copied: 4U5T-14G422-BDF_1615431510000.TAR.GZ
[4/6/2021 10:53:04 μμ] Checking Existing File: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[4/6/2021 10:53:04 μμ] Copying: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[4/6/2021 10:56:54 μμ] Validating: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[4/6/2021 10:58:13 μμ] Copied: 4U5T-14G422-BCF_1615431448000.TAR.GZ
[4/6/2021 10:58:13 μμ] Checking Existing File: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[4/6/2021 10:58:13 μμ] Copying: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[4/6/2021 11:03:20 μμ] Validating: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[4/6/2021 11:05:04 μμ] Copied: 4U5T-14G422-BBF_1615431222000.TAR.GZ
[4/6/2021 11:05:04 μμ] Checking Existing File: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[4/6/2021 11:05:04 μμ] Copying: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[4/6/2021 11:10:25 μμ] Validating: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[4/6/2021 11:12:15 μμ] Copied: 4U5T-14G422-BAF_1615431156000.TAR.GZ
[4/6/2021 11:12:15 μμ] Generating reformat.lst
[4/6/2021 11:12:15 μμ] Generating autoinstall.lst
[4/6/2021 11:12:15 μμ] ALL FILES DOWNLOADED AND COPIED TO THE USB DRIVE SUCCESSFULLY!
Should i do the same as the user above? downgrade and then upgrade?
The log indicates no issues. Have you performed a master reset on the APIM? If not, do so and see if that corrects the issue.
If this does not fix it, run the APIM Interrogator Tool in the Syn3 Updater app and post the results here.
Yes, i have performed a master reset. The navigation works normally, no issues other than the voice command. The rest of the voice commands work just fine, switch fm-am, set temperature etc. I will run the interrogator and post the result.
You can try to just re-install the NAV-Voice files independently and see if that fixes the issue.
These files go into the USB SyncMyRide folder:
Autoinstall.lst
Item1 = VOICE_NAV - 4U5T-14G422-BDF_1615431510000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G422-BDF_1615431510000.TAR.GZ
Item2 = VOICE_NAV - 4U5T-14G422-BCF_1615431448000.TAR.GZ
Open2 = SyncMyRide\4U5T-14G422-BCF_1615431448000.TAR.GZ
Item3 = VOICE_NAV - 4U5T-14G422-BBF_1615431222000.TAR.GZ
Open3 = SyncMyRide\4U5T-14G422-BBF_1615431222000.TAR.GZ
Item4 = VOICE_NAV - 4U5T-14G422-BAF_1615431156000.TAR.GZ
Open4 = SyncMyRide\4U5T-14G422-BAF_1615431156000.TAR.GZ
autoinstall.lst (591 Bytes)
What language is the APIM set to?
What country are you in?
If you set the language to English, does it work?
The APIM is set to English. The country is Greece, but of course sync 3 does not support it, hence the English
VIN: WF0AXXWPMAGY73xxx
Version 5U5T-14G381-ES
APIM Model: HB5T-14G371-FAH
APIM Type: Navigation
APIM Size: 64GB
APIM Free Space: 11G
17/6/2021 9:52:39 πμ +00:00
Partition Type = Free / Total
/fs/sd/MAP/ = 892K / 1.1G
/fs/sd/MAP/ = 14M / 2.8G
/fs/sd/MAP/ = 14M / 2.3G
/fs/sd/MAP/ = 7.9M / 1.5G
/fs/sd/MAP/ = 17M / 2.2G
/fs/sd/MAP/ = 21M / 3.7G
/fs/sd/MAP/ = 396K / 38M
/fs/sd/MAP/ = 5.7M / 3.2G
/fs/sd/MAP/ = 24M / 3.1G
/fs/Nuance/ = 27M / 4.7G
/fs/Nuance/ = 29M / 4.9G
/fs/Nuance/ = 25M / 4.3G
/fs/Nuance/ = 35M / 3.6G
/fs/Nuance/ = 8.4M / 1.9G
/fs/rwdata/ = 920M / 1.2G
/fs/rwdata/quip/ = 34M / 35M
/fs/rwdata/quip/ = 88M / 90M
/fs/mp/ = 133M / 1.4G
/fs/mp/resources = 432K / 73M
/fs/images/ = 11G / 54G
APIM AsBuilt
DE00: 0B6845929002BE530002
DE01: 475201044003480000000005
DE02: 0400010000
DE03: 01001C00250007
DE04: 18061810295F
DE05: 80
DE06: 17003B0000000000FA00000430750057
This is the interrogator log. Then i attempted to install only the voice files as per your instructions but i immediately got a memerror_01 if i am not mistaken
Also found a similar if not identical case.
Panos
having being dealing with this problem for a long time, I tend to beleive that this is a bug in the 3.4 software. I know about ten (10) 3.4 installations in Greece having the same problem. The only case I got it to work correctly is by reverting to 19274. Any upgrade higher that that results in the same problem “Navigation is still loading…Try again later”
Very frustrating!
Note: as long as you set a destination all voice commands work fine (!!!)
Thank you for the input. I was under the impression that you were successful in restoring the voice commands by rolling back to a previous version, then upgrading again.
In any case i don’t really care, i don’t use voice commands for navigation. I am just a bit of a perfectionist and would like anything that can work to work
But since this issue appears on cars even with the official update, there might still be hope from Ford fixing it.
It is a pitty that Ford Greece has been lacking behind the whole competition by NOT offering Greek localization in both menus and messages/GUI.
And it is really a dissapointment, that now we loose even some of the English voice commands…
It’s not a matter of perfectionism, it is just a matter of making things work as they have to!
PS You may also be aware that the greek Giota character is wrongly displayed as the english equivalent (“i” instead of “ι”) and in addition to that the Greel capital Lamda is again wrongly displayed as the english V ( “V” instead of “Λ”)…
Yes i noticed that too. There is a guy in the Cyanlabs Discord server that claims that he will be most probably working on the bugtracking of Sync3. Maybe we can report these issues and hopefully get them fixed.
