Sync 3.4.20282 - Feedback & Issues
I misunderstood the issue. Back in the original thread posted above was the answer about the NAV Voice issue. The procedure was to downgrade to 3.4.19052 and then upgrade to the desired version.
Try to downgrade to the version you were on previously (3.4.19274) and see if the NAV Voice works. If this works then try to upgrade again.
I was chatting with a Ford representative about album art on siriusxm, and they said they have removed the art for all vehicles, since it takes a lot of processor speed to organize all of the art for each channel on this version.
Hello, I live in China too, I wondering if you select the option ā€œkeeping existing mapsā€ or ā€œ1.19ā€ in the tool, because the tools says that if your car is macufacted in 2020 , the reformed mode will brick the sync module ,and should only use the option ā€œkeeping the existing mapā€. Thanks for advise.
If you have a 2020 vehicle then you must select ā€œkeep existing mapsā€. Do NOT select maps to install, this will brick your unit like the warning states.
Hello, I live in China too and the same car as you, I wondering if you select the option ā€œkeeping existing mapsā€ or ā€œ1.19ā€ in the tool, because the tools says that if your car is macufacted in 2020 , the reformatting mode will brick the sync module ,and should only use the option ā€œkeeping the existing mapā€. So which choice do you choose . Thanks for advise.
Thanks for advise! I will try it later use the option ā€œkeeping existing mapsā€.
Disappointing but at least they acknowledged it !
if you have activated the steering wheel controls and heated seats with forscan, it will always go to the home screen for safety reasons so as not to distract from driving. This happened to me when I activated those two commands on the sync screen. 3.4. I hope I was helpful. sorry for my english i write from italy.
FYI - This has been the behavior in all Sync 3.0 thru 3.4 versions.
Just updated tonight from 3.0 to 3.4 20282 in my 2018 Edge Sport. All went well and everything seems to work. I do have a couple of things regarding feedback/question. I have NAV and it shows the latest maps installed. When I look at the APIM settings I see the Country code is WS and Language is English (UK). Being in North America, specifically Canada, are there any changes I need to make?
hi
i am currently running build 20196 in which you can browse usb stick can someone confirm this feature has gone or can you still browse when stationary
thanks
yes you can browse while stationary still, this is the most stable build in a longtime
you can change it to US for US or CA for Canada i believe, but i’m not sure what WS is
Sync 3.4.20237 - Feedback & Issues - Ford / Sync 3 - CyanLabs Official Community
I wish you a good evening.
I just updated from the official version: 3.4 20136.
New version: 3.4 20282 solved a fundamental thing: When I start and turn off the radio, I see on the screen that the radio is turned on. When I turn it on, it turns on. After switching off, the logo was spilled and the logo was written on the radio. The new version really pays off. The system feels smoother.
As for skipping songs, I’ve been able to do it since 3.3 and I didn’t find any mistakes.
Currently on 3.4.20196 Non Nav version region ROW trying to autoinstall 3.3.20282 not completing for more than 1 hour it kept on showing " Updating System Software". Not moving ahead tried no. of time. Can someone guide me please. Last version had taken 10 minutes perhaps. What could be the reason?
A little late to the party but just wanted to let you guys know that auto install worked perfectly on my 2018 Fiesta ST-Line. Upgraded from 3.0.19205 to 3.4.20282 and all appears to be working well with no issues to report, such an improvement on the old interface. Thanks a lot for all the hard work.
I was just checking out the forums and seen your post…
On the climate control issue I wanted to ask a question … I have a mustang but quite sure same info. I currently have sync 3 and want to do the 3.4 update. I had bought the 4 inch to 8 upgrade and it has the climate control on screen will I still have them after update ?
