Ok, thank you once more for your quick responses. ![]()
4 posts were split to a new topic: Issue with retrofit
A post was split to a new topic: 3.4.23188 asking for auto-updates on each start
The 188 update , keeps saying downloaded successfully. Anyone else have this happen?
2020 f150
Thatās the desired outcome, hopefully everyone gets that result.
It does the same notice every day. Maybe I didnāt word it right. It looks like a new update loaded and when I check it, it the same build number.
Did you do a master reset?
I will try that. Just donāt want to lose all my settings.
Thanks
How did you apply .23188 ?
This can happen if you didnāt follow the official USB update process and then upload the xml to Fordās site, an OTA uploads it directly.
Easiest thing to do to get rid of the nag if you used another method is to turn off auto update.
Is this the latest release? Are the latest Maps just 2022?
Thank you
Latest NA is NA2.22, the next maps should show up in the wild around May/June 2024 and Ford official is usually Aug/Sept.
The map year is always one year behind the calendar year.
5 posts were split to a new topic: Issues with Car Play after APIM replacement and upgrade
During the day they wonāt come on. Try it at night or in the garage with the headlights on.
You may want to drop down to .21265
That build was pretty much rock solid and it didnāt have the read/write partition filing bug.
Quick summary:
I recently got an iPhone 15 Pro which is USB-C only. I struggled to find a cord that worked with the stock USB ports in my 2019 F450. The Apple Lighting to USB-C adapter didnāt work, but the Belkin USB-A to C does (If anyone needs a solution).
At any rate, I spilled a drink in my 2019 F450 and fried the OEM USB hub. I found a replacement HC3T-14D202-BA on Amazon that has one USB A and one USB C connection, then downloaded this update to a thumb drive.
The update took about 30 minutes, but works flawlessly.
Thank you!
Updated vehicle from 3.4.23088 and only thing Iāve noted is an issue is the clock doesnāt seem to be updating. Manually set it and it stays at that number. Set it to update to GPS time and it jumps to 12:00 and stays there⦠basically the clock doesnāt work?
Master reset it a few times and still the same.
How did you do the update and to what build?
Ford official, via the updater or a USB you built yourself?
Version: 3.4.23088
Mode: Directory
Path: E:\
; CyanLabs Syn3Updater 2.12.5.0 Stable - Autoinstall Mode - Sync 3.4.23188 NA
If you have FORScan reload the entire APIM asbuilt at once and then perform a master reset.
I do have FORScan, Iāve not done that before⦠reload the entire APIM asbuilt though. Does FORScan do that on its own or ? I got the VIN and pulled the ASBUILT info for the vehicle and could enter it manually I suppose. Also DLād the full .ab file for the vehicle.
Sorry if thatās a dumb question, havenāt loaded a module that I didnāt save and restore locally before.
