No Gracenote After Sync 3.4 Installation. Manual Installation Instructions
After installing Sync 3.4 thru the Syn3 Updater, depending on the region you may not see Gracenote installed on the APIM. This is due to Sync hardware storage limitations for current or future installations and the deletion of Gracenote was necessary to upgrade to Sync 3.4 because of the increased file size of the newer app. (Sync 3.4 is nearly twice the size as Sync 3.2/3.3) However, depending on the storage available after the upgrade, it is sometimes possible to re-install Gracenote manually.
Read this document fully before starting any actions. It is your responsibility to follow the instructions as outlined below.
NOTE:
All the files needed can be found at Software Database - CyanLabs.
If you decide to install Gracenote…
- Something to keep in mind is that CyanLabs does not implement this in the Syn3 Updater application. Therefore, they do not officially support this procedure.
- It is not guaranteed that Gracenote will install successfully on your unit.
- NON-NAV units will generally not have the storage available to install Sync 3.4 app, voice, and Gracenote.
- NAV units may have enough storage based on the unit originating region, and the region in which they are currently programmed.
- It is advised that you run the APIM Interrogator Utility to determine the specifics of your particular Sync unit installed in your vehicle. This is optional but can be found here:
Installation Instructions:
Ensure that Gracenote is not installed by looking at the IVSU screen in the unit, or the About Sync Info page. The Gracenote file will not be listed if not installed, and the About Sync Info page will not show a version. On the IVSU screen, we are looking for 4U5T-14G423-xx. In the example below, the file does not appear, as it is not installed on the unit.
Download the appropriate file you need for your region. Below are the current Gracenotes files for Sync 3.4. The files can be found in the APIM IVSU Database.
4U5T-14G423-AC 689Mb Sync3 v3.3.20342 1.1.1.2316 (EU-0020) (17.10.2020): EU (1)
4U5T-14G423-BC 927Mb Sync3 v3.3.20342 1.1.1.2325 (GL-0011) (19.10.2020) Global (2)
4U5T-14G423-CC 564Mb Sync3 v3.3.20342 1.1.1.2323 (NA-0020) (18.10.2020): NA (9)
4U5T-14G423-DC 896Mb Sync3 v3.3.20342 1.1.1.2325 (GL-0011) (19.10.2020): ANZ (8)
4U5T-14G423-EC 382Mb Sync3 v3.3.20342 1.1.1.2313 (CN-0020) (17.10.2020): ENU,MNC (10)
4U5T-14G423-FC 924Mb Sync3 v3.3.20342 1.1.1.2325 (GL-0011) (19.10.2020): ROW (4)
- (*) See Language/Country Definitions below.
- This installation will be run identically to an app or voice file install. Follow the instructions below:
a. Create a USB drive (format as EXFAT) with a SyncMyRide folder.
b. Copy the Gracenotes file downloaded above into the SyncMyRide folder.
c. In the root of the USB is the autoinstall.lst and DONTINDX.MSA files which you can obtain from any upgrade you have previously performed.
d. You will need to edit the autoinstall.lst file so it looks like the example below but with the actual file name you downloaded.
Item1 = 4U5T-14G423-CC_1615429225000.TAR.GZ
Open1 = SyncMyRide\4U5T-14G423-CC_1615429225000.TAR.GZ
Options = Autoinstall
Insert USB in vehicle and wait for the installation to complete. You should see a message indicating completion. If you do not see the ‘Updating System Software…’ message at the top of the screen and more than 10 minutes have passed, the installation has probably aborted due to insufficient storage space.
Remove the USB drive and reboot Sync. (Sync may reboot by itself. If not, shut down ignition and open door. Wait for vehicle to fully shut down.)
Start ignition and check the About Sync Info page or the IVSU screen for confirmation of successful installation.
NOTE:
This procedure can be used for any version of Sync 3.2, 3.3, and 3.4. The same procedure can be used for Sync 3.0 with the appropriate files.
Language/Country Definitions:
(1) DUN,ENG,FRF,GED,ITI,PTP,RUR,SPE,TRT
(2) DUN,ENA,ENG,ENI,ENU,FRC,FRF,KOK,MNC,PTB,PTP,SPE,SPM
(3) DUN,ENA,ENG,ENU,FRC,FRF,MNC,PTB,PTP,SPM
(4) DUN,ENG,ENI,ENU,FRC,FTF,GED,ITI,MNC,PTP,RUR,SPE,SPM,TRT
(5) DUN,ENG,ENU,FRF,GED,ITI,MNC,PTP,RUR,SPE,TRT
(6) DUN,ENG,FRF,GED,ITI,PTP,RUR,SPE,TRT
(7) ENA,ENG,ENU,FRF,GED,PTB,RUR,SPM,TRT
(8) ENA,ENG,ENU,GED,PTB,RUR,SPM,TRT
(9) ENU,FRC,SPM
(10) ENU,MNC
ARW - Arabic
CZC - Czech
DAD - Danish
DUN - Dutch
ENA - Australian English
ENG - British English
ENI - Indian English
ENU - American English
FRC - Canadian French
FRF - French
GED - German
ITI - Italian
KOK - Korean
MNC - Chinese Mandarin
MNT - Taiwanese Mandarin
NON - Norwegian
PLP - Polish
PTB - Brazilian Portuguese
PTP - Portuguese
RUR - Russian
SPE - Spanish
SPM - Mexican Spanish
SWS - Swedish
THT - Thai
TRT - Turkish
- Thanks to aziz al-ali for the nice pictures…
As a troubleshooting aid you can also remove Gracenote from your Sync system if desired: Tutorial: Removal of Gracenote
